Horizontal black lines on Samsung plasma. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 01-10-2013, 11:56 AM - Thread Starter
Gnashide's Avatar
Here's my story:
I was browsing Kijiji as usual and I spotted this TV for $50. It was being sold so low because of the lines that appeared on the TV. I quickly gave the guy a call, offered him $40 and he accepted. It's now in my room and I've been using it daily ever since. It's a fantastic TV, but the black lines that appear are very annoying, which is why I have come to you guys.
How would I go about fixing this?
I have already checked the connections in the back and they seem to be fine. Could it be one of the boards that is causing this problem? If so, which one?
Any help here is GREATLY appreciated!
TV model number: PN50C540G3FXZC
Gnashide is offline
post #2 of 23 Old 01-10-2013, 12:03 PM
Zarich's Avatar
Quoted: 16 Post(s)
You can't
I have this issue. It is common with Samsungs.
I have called samsung. The panel is bad and needs to be replaced.
Costs about $1000.
Some think the y buffer is bad. Others think the y sys is bad.
The boards are $100 a piece.
But the repair guys I talked to said.. bad panel.
Gnashide likes this.
Zarich is offline
post #3 of 23 Old 01-10-2013, 12:07 PM - Thread Starter
Gnashide's Avatar
I see. Do you think I should take the risk and try to replace the boards or should I just leave the TV as it is? Ebay sells the boards for pretty cheap.
After a while, you forget that the lines are even there.
Gnashide is offline
post #4 of 23 Old 01-10-2013, 01:41 PM
Yukon Trooper's Avatar
Liked: 26
Go for it, especially if the boards have a return policy.
Yukon Trooper is offline
post #5 of 23 Old 01-10-2013, 03:01 PM - Thread Starter
Gnashide's Avatar
Yeah, I'll think I'll do that.
Thanks for the advice guys!
Gnashide is offline
post #6 of 23 Old 01-10-2013, 04:33 PM
Zarich's Avatar
Quoted: 16 Post(s)
I have trouble believing either board is bad since you get picture, but I am not a repair guy.
You can take the tv apart and re-seat all the connections first. I have heard the ribbon cables on the left side of the tv (when facing the back) can get loose.
Zarich is offline
post #7 of 23 Old 01-11-2013, 08:46 AM - Thread Starter
Gnashide's Avatar
It's either a bad panel or one of the boards that is causing this problem. I guess we'll just have to wait and see.
Gnashide is offline
post #8 of 23 Old 01-11-2013, 09:09 AM
Zarich's Avatar
Quoted: 16 Post(s)
Okay. Good luck.
This Google Search May offer you more insight.
Zarich is offline
post #9 of 23 Old 01-11-2013, 09:12 AM
tomwil's Avatar
Liked: 26
If the boards are cheap, it might be worth a shot. You can always resell them on eBay if they do not solve the problem.
This document seems to support that the panel is bad, but on most of the samples, the lines are just one, not multiple. However, figures 49-52 seem to replicate what you have.
Please let us know your final result!
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse. (Romans 1:19-20)
tomwil is offline
post #10 of 23 Old 01-11-2013, 09:23 AM
Zarich's Avatar
Quoted: 16 Post(s)
Figure 38 is what I have.. that one black line.
I didn't know there were so many ways a plasma panel could go bad.
Zarich is offline
post #11 of 23 Old 01-11-2013, 09:44 AM
Zarich's Avatar
Quoted: 16 Post(s)
Here is some info about the buffers. Based on it I don't think your Y-buffers are bad
http://www.ehow.com/info_12226500_symptoms-bad-ybuffer.html
Zarich is offline
post #12 of 23 Old 01-11-2013, 10:19 AM - Thread Starter
Gnashide's Avatar
I was just doing some research and I found this:
http://www.justanswer.com/tv-repair/6dlpt-samsung-plasma-tv-thin-black-line-goes.html
Same TV, and the same problem.
The technician on that site recommends replacing the buffer, so I think I'm going to try that first.
Gnashide is offline
post #13 of 23 Old 01-11-2013, 10:42 AM
Zarich's Avatar
Quoted: 16 Post(s)
Let me know how it goes. I may try that before I pony up for a new tv. I was hoping to hold out until OLED was affordable.
Zarich is offline
post #14 of 23 Old 02-01-2014, 07:57 AM
cliff54's Avatar
Here's my story:
cliff54 is offline
post #15 of 23 Old 02-01-2014, 08:02 AM
cliff54's Avatar
I have the exact black line you show. I had a tv repair person look at it for $115.00. He said it's the board on the left side or the panel. He had checked all conections and stil no change. The shop called to tell me they would order the board and install for $380.00. If no change I would be charged a restocking fee only. A new panel is obviously out of the question. I can put up with the line until I find a new set.
cliff54 is offline
post #16 of 23 Old 05-03-2014, 02:17 PM
CoffeeHawk's Avatar
Quoted: 99 Post(s)
Liked: 47
Do more research on this issue, there is a big group of Samsung Plasmas with this issue, and the issue gets worse over time (new lines will keep appearing):
These are from a June 2010 PN50C7000YFXZA
CoffeeHawk is online now
post #17 of 23 Old 10-17-2014, 04:17 AM
Liked: 0
Hello, i have a Samsung Plasma 50" TV and i have the exact same problem.. it all began with 1 thin line.. then three months later 2 more apeared. but today i noticed that the very first line is now gone/dissapeared ? does this mean it is fixable?
Mocro Issy is offline
post #18 of 23 Old 10-17-2014, 08:00 AM
Liked: 0
I have a similar issue that I cannot figure out, but my line is a flicker and depends on the scene.
JediL1C1OUS is offline
post #19 of 23 Old 11-10-2014, 10:49 AM
CoffeeHawk's Avatar
Quoted: 99 Post(s)
Liked: 47
Samsung will tell you have you have to replace the plasma panel, if the lines don't go away. This means it's cheaper to buy a new TV.
https://www.google.com/search?q=how+...sm=93&ie=UTF-8
post #20 of 23 Old 11-11-2014, 02:45 AM
Liked: 0
Damn that sucks. Samsungs look really nice but this is a travesty.
downstairslounge is offline
post #21 of 23 Old 11-15-2014, 07:06 AM
ke4pym's Avatar
Quoted: 54 Post(s)
I've got a 64" 8000 series 2012 set that has been doing it off and on for about a month. This week it has been continuous. Good thing I got an extended warranty. I will be placing a service call on Monday.
ke4pym is offline
post #22 of 23 Old 11-17-2014, 01:36 PM
CoffeeHawk's Avatar
Quoted: 99 Post(s)
Liked: 47
I think the permanent black line issue was for certain low and middle range models between 2008 and 2012, you can find info online about it.
Never buy an extended warranty on anything. They would not be offered unless they were profitable for the company. The cost of Ex. W's is greater than the cost of replacing a TV or other major purchase over some time period where 98% of what you buy won't fail.
post #23 of 23 Old 11-17-2014, 05:28 PM
nipalikewalnuts's Avatar
Quoted: 38 Post(s)
^ Extended warranties (especially third party) are rather like lottery tickets.
nipalikewalnuts is offline
Samsung
