LG 60PA6500 Plasma - Need Help please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-11-2013, 09:50 PM - Thread Starter
Ellrotts's Avatar
Hi i Just picked up one of these and its great, that not the issue.
I use the TV to display by BR player of course. When i turn off the display either with the remote or manually with the button it turns off my BR player. Which is not what i want as I use the BR player to play music through the surr sound and there is no real reason to have the TV Burning a playlist into itself.
Does anyone know how to disable this feature? your assistance would be greatly appreciated.
Ellrotts is offline
post #2 of 2 Old 01-19-2013, 08:47 AM
42Plasmaman's Avatar
Quoted: 20 Post(s)
Liked: 37
You need to disable the HDMISimplink(CEC).
You may want to ask your question here.
http://www.avsforum.com/t/1390332/lg-50pa6500-and-lg-60pa6500-plasmas/1140
2016
42Plasmaman is offline
Lg 60 Inch Pa6500 Plasma Hdtv
