Help troubleshoot a Panasonic Plasma - AVS Forum | Home Theater Discussions And Reviews
Old 01-12-2013, 09:26 AM - Thread Starter
Mark617's Avatar
Quoted: 26 Post(s)
This bar runs directly down the middle of the screen. It comes and goes, and not in any sort of discernible pattern. Just randomly appears and goes away. Panasonic TC-P46S2, less than two years old.
I have seen threads on fixing a black line / bar running vertically down the screen, and the fix was a cheap secondary board and a little handy work. A tech looked at my screen and said this issue is the panel. He didn't test it or open it up, he simply looked and said it is the PDP. I am curious if any experts out there can confirm things one way or the other simply by looking. If it is not the panel, is this something a fairly efficient, mechanically inclined person can fix on their own?
As you can see, sometimes the issue is a full two inch bar (last two pictures), other times it is merely a horizontal line running that two inch length, every inch and a half or so vertically.
Mark617 is offline
Old 01-13-2013, 11:50 AM
inc77's Avatar
I have the same exact problem. Mine is less than 3 weeks old though. Will contact Panasonic and see what they can do.
http://www.avsforum.com/t/1451567/vt50-image-problem
Oh and my model is the TC-P55VT50
inc77 is offline
Old 01-22-2013, 09:18 AM - Thread Starter
Mark617's Avatar
Quoted: 26 Post(s)
Today, the bar went from what I showed earlier, to a solid black bar. As I stated initially, I have read posts where the solid black bar ends up not being the panel and is instead some secondary board, often pretty cheap and only mildly difficult to change. Do these new photos suggest it could be a secondary board, or is this just the evolution of a bad / dying panel?
Mark617 is offline
Old 01-22-2013, 10:24 AM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
It could be the panel, the wiring to it, or one of the boards. Sometimes the connector can back off the panel and just needs pushed back on.
You may find a factory manual here if it will help http://elektrotanya.com/?q=keres
whipit is offline
Old 01-22-2013, 11:53 AM - Thread Starter
Mark617's Avatar
Quoted: 26 Post(s)
So, after reading more on this type of issue I found one post that suggested squeezing the TV along the edges, near the problem area(s). While squeezing did not work, banging along the top of the TV above the problem area did. The line got worse / better / went away / came back, basically changed, sometimes for the better, sometimes for the worse, but banging did have a noticeable affect on the display. Does this sway the prevailing thought that perhaps it is not the panel, and more than likely a wiring or connection issue?
I will take it apart, but want to be as informed as possible first, mainly because I do not want to electrocute myself, since I have never worked on a plasma TV before, or any television for that matter.
Also, if it ends up being a connection issue, likely toward the top of the TV, perhaps the ribbon cables etc., is it merely a matter of pushing them in, or should I be prepared / do more research as the fix could be a bit more in depth?
Mark617 is offline
Old 01-22-2013, 01:01 PM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
Make sure the tv is unplugged, remove the cover, touch the frame to get rid of the static charge. Stay away from the power supplies capacitors. Use a bright flashlight and do a visual inspection for burnt areas near the panel connectors and on the boards they go to. Reseat the connectors and if it looks good try plugging in the tv with the cover off and see how it goes. Never put both hands in there with it on. Just some quick thoughts while I'm busy at work. Keep us posted, good luck:)
whipit is offline
Old 01-22-2013, 01:53 PM - Thread Starter
Mark617's Avatar
Quoted: 26 Post(s)
Well I took it apart, and there were three connectors that were barely connected. Also, on one of the ribbon cables near the bottom, there was, what looked like, a piece of clear plastic that looked like it wedged itself between the ribbon sections (4 little sections of ribbon). I pulled that out, reset all the connections (staying away from any re: the power source) and then cleaned everything up. The picture below shows where the plastic piece was wedged, but I had already removed it.
The only thing I noticed that looked odd, was on the board on the left hand side (when looking into the back of the TV). As you can see, around what looks like thermal paste on the sqaure pieces.
Not sure what those white areas are, maybe just dried glue etc., but I did not notice anything else odd, other than the clear plastic piece I removed from the ribbon section and the loose connectors.
So far it is working, but that doesn't mean much. One thing I will note, when they replaced the panel they said I was getting a new one, and I would have demanded as much. The paperwork even says new panel, yet the panel I have clearly says refurbished on it. While this is probably within warranty parameters, I find it pretty freaking annoying I was told it would be new, because I would have never accepted a refurbished panel on a warranty issue. I paid new panel price and would expect a new panel replacement. But again, this is more me venting than anything haha!
Mark617 is offline
Old 01-23-2013, 06:26 AM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
Great that you found the problem and thanks for the update. That stain could also be some kind of out-gassing. from assembly soldering.
whipit is offline
Old 01-24-2013, 08:52 PM
arturomco's Avatar
Awesome find. I came accross that exact same issue today. I will be taking mine apart tomorrow to check the ribbon and other connections. Is everything still working for you? No "Return of the Black Bar", right?
arturomco is offline
Old 01-24-2013, 09:46 PM - Thread Starter
Mark617's Avatar
Quoted: 26 Post(s)
So far, so good. But, with my luck, simply responding to this thread will doom my TV and the line will return rolleyes.gif
Mark617 is offline
Old 02-02-2013, 08:29 PM
wolfuss's Avatar
I have a similar problem, my TC-P42S2 has a black line from top to bottom above the 4th ribbon. I pulled it apart and i cant see anything wrong. When i pull the non responding ribbon out and pull another functioning one out they change to a rainbow colour but the 4th one has a bright white outline and still remains black when i plug it in.
Im not sure whether it is the board ribbon or panel (hopefully not) can anyone help
wolfuss is offline
