Samsung PN51D8000 & Brandsmart USA - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-12-2013, 01:08 PM - Thread Starter
ZiggyGod's Avatar
I bought this TV in January of 2012 and I got the 3 yr extended warranty. My nephew was playing Wii and flung the controller to the TV. -_- The TV started to show me a crazy trippy visual show before it went all black and started to make a loud hum. The red led light just flashed red when on. There is a crack in the bottom center of the TV.
I called Brandsmart and told them my TV does not work and makes a loud hum, so they are sending a Brandsmart repair tech on Tuesday. Im pretty sure the repair guy will see the crack and be like oooh your extended warranty won't cover that and etc. My question is how much do you think I will get charged to fix it?
ZiggyGod is offline
post #2 of 2 Old 01-12-2013, 01:16 PM
UGAd13's Avatar
Quoted: 100 Post(s)
Liked: 121
if it's the panel, which it sounds like it is, those usually cost the same to repair as to buy a new one.
good luck.
My living room budget build: Samsung PN51E530 / Denon AVR1613 / DefTech PC1000 / DefTech PM60 / DefTech ProSub 60 / Dayton Sub1200
UGAd13 is offline
Samsung Pn51d8000 51 Inch 1080p 3d Ready Plasma Hdtv 2011 Model
