Is it my Plasma? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-15-2013, 05:23 AM - Thread Starter
Cooljust's Avatar
Good morning! I recently moved into a new construction home and had the family room and theater pre-wired for surround with HDMI installed on the wall. I have a Panasonic Viera 46" 1080p plasma, Model # TC-46pz80u that worked just fine prior to mounting it on the wall yesterday.
Here's the issue. I'm using a Harman Kardon AVR-1700 with HDMI out into the wall and the HD cable box video displays with no issue. However, now my Blu-ray player video (there is audio) will not display on the television. I have a 32" LED tv that I plugged in for troubleshooting purposes and the video displayed fine. Both are 1080p so I'm not sure what the issue is.
Please help!
Cooljust is offline
post #2 of 3 Old 01-15-2013, 07:00 AM
SiGGy's Avatar
Quoted: 381 Post(s)
Liked: 332
Please help!
Did you plug the LED TV into the same HDMI cable where the plasma is installed?
-SiGGy
SiGGy is offline
post #3 of 3 Old 01-15-2013, 07:07 AM - Thread Starter
Cooljust's Avatar
Yes. I powered down everything, unplugged the HDMI cable from the plasma, plugged it into the LED, turned everything back on and it worked just fine. Upon powering on the AVR, I immediately got the "1080p" notification displayed on the television as well as the front panel on the AVR.
Cooljust is offline
