Tc-p55vt50 help , please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-16-2013, 08:31 AM - Thread Starter
william77's Avatar
HI,
i just bought a panasonic VT50 and its the first plasma i have owned
theres so much info on this site i have a couple of questions.
1. do i calibrate first then break in or the other way around?
2.everyone says turn the brightness way down do i turn down contrast as well ? what level or how low do i need to set it at ?
3 what is the suggested software to break in (preferably a USB way unless thats not recommended) and what to use to calibrate it?
i just dont want to screw the VT50 up and im going to be heavily gaming on it once broke in
Thanks everyone:)
william77 is offline
post #2 of 3 Old 01-16-2013, 04:05 PM
BillP's Avatar
Quoted: 266 Post(s)
Liked: 203
First, you should not calibrate until you log >150 hours on the display. Second, you should post in the VT50 thread where they can help you out.
BillP is offline
post #3 of 3 Old 01-18-2013, 07:54 AM - Thread Starter
william77's Avatar
ok thanks will post there
Panasonic Viera Tc P55vt50
