prep slides on panasonic st50 question - AVS Forum | Home Theater Discussions And Reviews
Old 01-18-2013, 06:47 PM - Thread Starter
speeder799's Avatar
I will be getting the 55 inch next week from best buy and was wanting to know, Is it okay to run the slides for a 100 hours strait or do i need to split up the time? this is my first plasma, thanks for any info
speeder799 is offline
Old 01-18-2013, 06:59 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
You can run the slides in any increments you want. Hours is hours, doesn't matter how you break it up (or not).
Why are you breaking it in for 100 hours?
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Old 01-18-2013, 07:31 PM - Thread Starter
speeder799's Avatar
thanks I didn't know if 100 continuos hours was bad, I have read that that was the recommended time to run the slides to age the phonsphers enough to calibrate it. I will be gaming as well so i head this will help lessin IR due to the aging
Old 01-19-2013, 08:24 AM
dmaul1114's Avatar
Yep. The main reason to run the slides is to age the phosphors evenly before calibrating.
Running the slides doesn't make the panel any more resistant to IR. The only help there is that running them when not using the TV helps you blow through the first 100 hours or so hours faster, and panels tend to be more prone to IR early on. But after that period, the TV isn't any more resistant to IR than if you just used it normally for 100 or 200 hours or whatever. Just gets you to that point faster--which is a good thing IMO. With stores having 14-30 day return periods most of the time it's good to get it broken in the first week or so and have time to make sure you like the picture, aren't getting IR more than normal etc. before the return window is past.
dmaul1114 is offline
Old 01-19-2013, 08:56 AM - Thread Starter
speeder799's Avatar
Thanks thats exactly how I understood it, I will be getting The tv from bestbuy just so i can get there protection plan for 5 years which covers burn in and image retention
