Panasonic Plasma TH-50PX80U HDMI Inputs Quit Working - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-21-2013, 09:05 AM - Thread Starter
Gowolfpack83's Avatar
I have a Panasonic Plasma HDTV Model # TH-50PX80U and all three HDMI inputs quit working. I have tried multiple HDMI cables and devices and nothing works. All of the other inputs work using the same devices, but not the HDMI. I have reset the tv by unplugging for 10 minutes and also by holding the vol - and menu button, causing the tv to do a system check and then hit the power button causing a reset. Even after the reset, the HDMI inputs do not work. Has anyone had this issue, and if so, where you able to fix it?
Gowolfpack83 is offline
post #2 of 2 Old 08-06-2013, 01:21 PM
klutch's Avatar
You ever find a resolution to this? Mine is doing the same thing and it's the exact same model
klutch is offline
Panasonic Viera Th 50px80u 50 Inch 720p Plasma Hdtv
