Cleaning plasma screen help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-21-2013, 09:19 AM - Thread Starter
jeff6666p's Avatar
I tried to clean it with some water on a microfiber cloth but it just made it worse there were smears all over the screen. I then did it over but this time I used one dry cloth and one wet, I wiped the screen with the dry cloth as soon as I used the wet wet one and that got rid of it in that area. Is there any easier why do clean it? Why did the screen get cloudy when I cleaned it the first time?
jeff6666p is offline
post #2 of 4 Old 01-21-2013, 10:48 AM
Otto Pylot's Avatar
Quoted: 1668 Post(s)
Liked: 1042
Panel cleaning comes up from time to time. The safest way to clean any type of panel is distilled water (warmed if need be) and a clean, microfiber cloth. For small stubborn areas, you might try a good quality eye glass cleaner (like what you get from your optometrist). As to the smearing, it sounds like there may have been something on the microfiber cloth that caused the smearing on the panel.
Otto Pylot is online now
post #3 of 4 Old 01-21-2013, 11:44 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 527 Post(s)
Liked: 782
If you cleaned it when the screen was hot or even warm then that may be why it doesn't get the cloudiness off. It's kinda like when you clean your car's windshield when the sun is beating down on it dries before you can wipe it all off.
Glass should be cleaned when it's cold or cool, not warm and especially not when hot. And if your particular brand/model is one that has an Anti-Reflective Filter then be extra careful and don't rub too hard as you can damage the delicate coating on the glass.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #4 of 4 Old 01-21-2013, 12:17 PM
Otto Pylot's Avatar
Liked: 1042
^^^^ good points.
