what to buy a friend wants a new tv 1500$ to spend - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 01-23-2013, 08:04 PM - Thread Starter
bsmithoh23's Avatar
a friend of mine is getting a new tv after he came over and seen how nice my vt50 was . he wants a led tv cause of how bright it is . i told him he should go with the gt50 or the st50 in 55' i myself would never get an led .anyways what do you guys think any leds would help also plasmas of course thanks fellas
bsmithoh23 is offline
post #2 of 11 Old 01-23-2013, 08:09 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
lovinthehd is offline
post #3 of 11 Old 01-23-2013, 08:45 PM
hotskins's Avatar
Quoted: 60 Post(s)
Liked: 68
ST50 is the best bang for the buck
hotskins is offline
post #4 of 11 Old 01-23-2013, 08:55 PM - Thread Starter
bsmithoh23's Avatar
yah i seen the pnd8000 also im just trying to find the best 55 or larger and pq 3d is something wanted to
post #5 of 11 Old 01-23-2013, 09:00 PM - Thread Starter
bsmithoh23's Avatar
the only reason i would get an led is if i was going to do a pc home theater hook up . i would like to do that though i do alot of stuff on the net.he wants a good picture and 3d
post #6 of 11 Old 01-23-2013, 09:09 PM
wiggindude's Avatar
Hi,
Why would you only go with and LED to use with HTPC? Any reasons why a Plasma would be good with HTPC? I'm asking because I have a HTPC and the ST50 is the one I'm looking at. Thanks.
wiggindude is offline
post #7 of 11 Old 01-23-2013, 09:15 PM - Thread Starter
bsmithoh23's Avatar
my wife does photography and edits alot and the same menu is on there for 6 8 or even 10 hrs at a time
post #8 of 11 Old 01-23-2013, 09:18 PM
lovinthehd's Avatar
Liked: 4775
?? it's 59 inches. pq and 3d are excellent, probably better than the Panasonic. Also supposedly less prone to IR.
post #9 of 11 Old 01-23-2013, 09:52 PM
wiggindude's Avatar
Oh, I see. You're using it as a PC also, in that case, LED is the way to go.
post #10 of 11 Old 01-23-2013, 09:57 PM
Yukon Trooper's Avatar
Liked: 26
If you're going to go Samsung, go with the E6500. Same PQ as the 7000/8000 minus the super-thin casing and some of the superfluous features. David Katzmaier at Cnet even said the PQ on the E6500 was slightly superior, for whatever that's worth. At your friend's price-point he can grab the 60".
Yukon Trooper is offline
post #11 of 11 Old 01-24-2013, 10:40 AM - Thread Starter
bsmithoh23's Avatar
well the vt50 is on sale for 1600 so i think hes gonna go with that thanks for the input fellas
