Televisons - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-24-2013, 04:09 AM - Thread Starter
tyler94's Avatar
I have a Panasonic TX-L32C4B everytime I turn it on a Viera Link Connection pop-up appears. How do I make it stop? It is annoying. Like an ad on the internet
tyler94 is offline
post #2 of 2 Old 01-24-2013, 07:39 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
Even though that's an LCD TV, the menu should be like our Plasma TVs. Try going into the SETUP menu and scroll down to Viera Link Settings and you should be able to turn it off.
If you're seeing ads and banners when you first turn on the TV, you can turn these off also:
Go to Setup > scroll down to Advanced Setup > select Viera Connect Banner > the change it to OFF
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
