Panasonic ST50 w/ slight flicker, blink? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-25-2013, 12:40 PM - Thread Starter
tealboy's Avatar
Quoted: 17 Post(s)
I have not owned the tv long enough to have clarity around what is happening but while watching netflix, I notice a slight and rapid flicker every few minutes. It is so subtle that is does not cause any problems, in fact, you almost miss it but when watching in a dark group, you see it. Just a very very fast blink. I tried watching the same show using the smart blu ray and did not notice the flicker. I have not watched enough cable tv to see if it is happening w/ that source but thought in the meantime, i'd toss it out there to see if this sounds familar.
55st50 panasonic
tealboy is offline
post #2 of 9 Old 01-25-2013, 12:47 PM
jerrolds's Avatar
Quoted: 32 Post(s)
Known issue - it flickers when the Netflix quality changes. Kind of annoying - but it seems to only do it from Highest <-> 2nd highest
At first i thought i was blinking, but no. Doubt they'll ever fix it. Workaround is to use another device for Netflix like an Xbox
jerrolds is offline
post #3 of 9 Old 01-26-2013, 05:55 AM - Thread Starter
tealboy's Avatar
Quoted: 17 Post(s)
that's surprising and disappointing. i just bought two new smart plasmas and the samsung has no hint of this. i just watched another movie last night and it did it 20 times or so, appx. Is there another thread on this subject with additional commentary?
tealboy is offline
post #4 of 9 Old 01-26-2013, 06:26 AM
dmaul1114's Avatar
It seems a lot of TV apps have issues with the streaming.
Seems the safer way to to go is to just get another device for that. I don't bother with the apps on my TV as I have the ones I need on my Bluray player, and also my Xbox 360 and PS3. Those are already hooked up to the receiver for 5.1 sound etc., so just easier than bothering with the TV apps and getting sound from the TV to the receiver etc.
But I guess it's a bigger nuisance for people who don't have home theaters and just use the TV sound, and an added cost if you don't have a device with the apps on it already to hook up to the TV.
dmaul1114 is offline
post #5 of 9 Old 01-26-2013, 09:09 AM
SHOWM3URBO0BYZ's Avatar
Ii just got my tv and was watching the thunder basketball game last night and mine was doing this, I watched a blu ray and nothing happened I also flipped it to.another channel and didn't see anything. I wasn't on any aps or anything please help
SHOWM3URBO0BYZ is offline
post #6 of 9 Old 02-15-2013, 09:35 AM
fallentrumpet's Avatar
Same issue here, but slightly different view and details.
I ordered a Panasonic TC-P50ST50 and accepted delivery Jan 28, 2013. I observed the "Netflix issue" (TV appears to lose sync or to insert one or more black frames each time Netflix changes their adaptive bit rate streaming to match my perceived Internet connectivity). Unfortunately for me, when streaming Netflix HD, Netflix needs something greater than 6Mbps for the best quality level, and my DSL DL is rated at ~6Mbps, max. So Netflix streaming HD continually toggles between "High HD" and "Medium HD", so the "blink" happens typically every few seconds.
As others have noted, the issue is not observed on most other streaming services (HuLu, YouTube, etc.), because (a) many are not streaming HD and (b) most are not using "adaptive birate streaming".
NOTE: I streamed Netflix HD for at least several months or more through a Panasonic Blu-Ray player (model DMP-BDT220) to an inexpensive Sony Bravia HDTV and never had this issue.
As a test, I moved the DMP-BDT220 to the new Panasonic TC-P50ST50 and the TV does NOT "blink" when Netflix streams through the Blu-Ray player, like it "blinks" when streaming directly to the TV. (Note... same Internet connectivity, same DSL modem, same Netflix adaptive streaming... same everything for these two tests, except in one instance streaming directly to the TV and in the other instance, streaming through the Blu-Ray player and then to the TV over HDMI).
In the 19 days since I received the TV:
(1) I Googled for this issue and found MANY references to this issue, including prior posts in this forum. Some references believe the problem to be caused by Netflix, while most agree the problem is the Panasonic TV.
(2) I emailed Panasonic technical support within 24 hours of receiving the TV, asking them about the issue, documenting the issue. Panasonic initially informed me that they believed the problem was that the TV was on my WiFi network and my WiFi AP was more than 10 feet (!) away from the TV. (Panasonic doesn't seem to understand that a 54Mbps WiFi network is constrained by the 6Mbps DLS link.) I repeated the test with the TV wired (ethernet) to my DSL router/modem/AP... same "blink" issue. And there is NOTHING (?) on Panasonic's web site or in their TV documentation indicating that the WiFI Access Point must be within 10 feet of the TV.
(3) I've since opened a formal ticket with Panasonic and have talked by phone to various levels of technical support at Panasonic during the past 19 days. Email support folks at panasonic cannot help any further, I'm told. Everything must be phone. Each time I've talked to Panasonic, they have confirmed (a) they have never heard of such an issue - which is difficult to believe, since I can google and find many, many references to this issue, (b) they confirm Netflix's assertion that the TV should NOT flicker or blink when netflix changes their bitrate and (c) they cannot explain why the flicker occurs when Netflix streams directly to the TV but does not occur when netflix streams through an intermediate device, such as a Panasonic Blu-Ray player.
(4) Most recently, Panasonic escalted this to their "engineering department", with a promise to contact me by next Wednesday, 5pm eastern, Feb 20, 2013.
Note: Panasonic customer service has been... less than stellar, let's say. At a minimum, I expect to be contacted by the date they tell me. yet, I'm sensing a trend... is this actually typical of Panasonic customer service or is my experience abnormal?
* Sunday, Feb 3 - opened case with Panasonic. Promised someone would contact me by Wed, Feb 6. yet, not one contacted me.
* Thur, Feb 7, I phoned Panasonic for status and was told they "mis routed" my case, so no one would EVER have phoned me. But they promised they would "escalate" and someone coulwd contact me by Saturday, Feb 9.
* No one contact me by noon, Sat, Feb 9, so I phoned Panasonic for a status update. I was promised Panasonic would contact me by close-of-business that same day! Yet, no one contacted me.
* Monday, Feb 11, I contacted Panasonic for a status update. I was promised someone would contact me by Wed, Feb 13, 5pm central. Yet, no one contacted me.
* Wednesday, Feb 13, 6pm, I phoned Panasonic for a status update. I I was promised someone will contact me by next Wednesday, Feb 20, 5pm eastern (4m central). So I wait, not knowing if this is a Panasonic stall tactic, hoping I'll tire of pursuing the issue. (They don't know me...). NOTE... Feb 20 will be "day 24" since I received the TV, nearing my "30 day" window of opportunity to choose to return the TV. (I don't "want" to return the TV, but have saved all packaging, just in case I decide Panasonic customer support has left me no other option.)
Of course, one concern is that the TV may h ave other "hidden problems" that I've not yet discovered, since Panasonic seems to be in denial about a problem I so easily discovered and that has been so widely reported on the Internet.
At a minimum, I expected Panasonic customer service to contact me by the promised dates and provide an update, even if just to say they "need more time". But I have not once received that simple courtesy.
SO MY QUESTION for members of this forum...
I purchased this directly from Panasonic online. Panasonic online has a 30 day return policy. If Panasonic customer support continues with these delays and I reach day 29-30, should I just return the TV (on principle, as much as anything) and perhaps buy a LG or Samsung (or other?) Plasma? How does other (LG, Samsung, etc.) Customer Service, compare?
I know I can "work around" the TV issue by using a Blu-Ray player, or similar, but on principle, I should not need to "work-around" an issue on a brand new TV. Yet, I do like the picture quality, brightness, etc... would similar priced Plasma TVs from competitors provide equally pleasing picture quality?
Fred
fallentrumpet is offline
post #7 of 9 Old 03-03-2013, 03:05 PM
Pasonic technical support promised seven (7) different times to contact me with status updates... not once did they call. Each time I followed-up with them after one of their missed commitments, they said they needed more time and I should be patient.
Panasonic engineers confirmed they replicated the issue in their labs on an ST50, but no response yet whether they can make any corrections or whether other Panasonic TVs have the same issue.
As much as I like the picture quality, I was more frustrated with Panasonic's (lack) of communication regarding the issue, so Panasonic "sales" has promised to refund my purchase price and to pay return shipping for the "defective" TV.
post #8 of 9 Old 03-03-2013, 03:22 PM
JSpectre88's Avatar
Liked: 54
JSpectre88 is offline
post #9 of 9 Old 03-20-2013, 03:25 PM
New TC-P50ST60 arrived today... NO flicker issue at all with Netflix adaptive bit rate. Glad I went through the trouble of returning the ST50.
Menu structure is different on ST60... slight cosmetic differences... have to adjust colors and get used to the differences, but after just a couple of hours, am happy thus far. (Assuming Panasonic eventually refunds my money from the ST50...).
