e6500 question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-25-2013, 03:34 PM - Thread Starter
theaero's Avatar
To achieve the lowest input lag (PC mode trick) can I be using component cables and set the label to game mode, or do I have to use HDMI?
Also, are there any benefits to HDMI over Component 1080p? (For Xbox 360 in this case)
Finally, should I have game mode turned on even if I have the input set to PC?
theaero is offline
post #2 of 2 Old 02-06-2013, 08:56 PM - Thread Starter
theaero's Avatar
Bump.
Also, is it possible to use the PC label input lag trick for sources other than HDMI? Composite for example?
theaero is offline
