HDTV switch for the Panasonic UT50 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-26-2013, 11:14 AM - Thread Starter
miken1012's Avatar
Hi all,
I just brought the P60UT50. It is a great HDTV. The only problem I am coming across is the HDTV only provided 2 HDMI output. Do any of you guys know of a HDMI switch that you guys are using and is compatible with this model? I tried to buy one from Amazon, but when I plugged it in to the HDTV, the screen would go blank. mad.gif Thank you very much in advance for all of you guys help!
This is the 3 in 1 HDMI switch i brought from Amazon.
http://www.amazon.com/HDMI-3-In-1-Out-Switch-Cable/dp/B0018DQYQ2/ref=sr_1_4?ie=UTF8&qid=1359224259&sr=8-4&keywords=hdmi+switch
miken1012 is offline
post #2 of 2 Old 01-27-2013, 01:48 AM
BriscoCountyJr's Avatar
Quoted: 33 Post(s)
Liked: 42
Try the excellent HDMI switches at monoprice.com
BriscoCountyJr is offline
