Pansonic GT50 and upconversion/upscaling with my Tivo Premier box - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-27-2013, 02:58 PM - Thread Starter
kevreh's Avatar
I'm trying to make sure everything is setup right. I guess the root of my question is, what does the Panasonic do with 480 and 720 signals. Does it always upconvert to 1080 or keep it "native". What about the "i" and "p"? Does it convert to 1080i or "p"?
Trying to figure out if I should choose the option in my Tivo box to send all video as 1080i, or let it send 480 and 720, content depending of course. I can set these in the Tivo video menu.
With my LG blu-ray player, I don't see an option for settings, so I assume its always sending content as 1080. Does the DVD player dictate "i" or "p"? Or the movie?
Kevin
kevreh is offline
post #2 of 5 Old 01-27-2013, 03:05 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
I have tried all the various combinations on my Tivo S3 and a couple of different cable co DVRs and the best setting for all of my TVs (including my GT50) are to set the box to output everything at 1080i fixed. It gives a crisper more detailed image (to varying extents on my various Plasma and LCD TVs) and also makes channel changing go much quicker.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 5 Old 01-27-2013, 03:27 PM - Thread Starter
kevreh's Avatar
Thats surprising it makes the channel changing faster, you think it would be slower due to processing the upconversion.
I was seeing some dithering and artifacts, especially in areas a little darker and with movement. After reading in one of the Panasonic plasma threads (can't recall if it was the VT/GT/or other one) I turned off the 720 video out setting on my Tivo, and sent everything out as 1080 as you suggested. That helped....A LOT. Not saying every scene and every image, but I was able to do a before and after test with the same video clip and the issue goes away when I force 1080 out of my Tivo box.
So, I guess upconverting from 720 on the Panasonic side is....*lacking*.
Kevin
kevreh is offline
post #4 of 5 Old 01-27-2013, 04:31 PM
jbdan's Avatar
My comcast Motorola dvr has a 1080p option. I use it. I've tried all the others (1080i,720p,480p/i,and native) and channel changing is laboriously slow on native.
jbdan is offline
post #5 of 5 Old 01-28-2013, 01:20 PM
chunon's Avatar
Quoted: 2039 Post(s)
Liked: 1787
Kevin
I have a Tivo Premier with a ST30 and use the 1080i setting and have found it to be the best.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
