Samsung D7000 advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-27-2013, 08:03 PM - Thread Starter
ZachB10's Avatar
I have a Samsung D7000 plasma that is nearly a year old. The picture is great from a distance, but when you are up close there is a considerable amount of green / red pixels that are only visible in certain scenes. In a completely black area, it will appear black, but other times if it is near / approaching black you may see some red / green snow. Is there anything I can try or do I need to call for service? I have tried different HDMI cables / sources. Picture is beautiful from a distance and if the image is solid the red / green pixels do not appear, but I don't want to ignore this if it could turn into a larger issue.
ZachB10 is offline
post #2 of 4 Old 01-27-2013, 08:22 PM - Thread Starter
ZachB10's Avatar
FYI, it looks exactly like this when viewed up close. No resolution on the reference post... My brightness is at 46, any lower and it is too dark.
http://www.avsforum.com/t/1352196/pic-plasma-dithering-is-this-normal
ZachB10 is offline
post #3 of 4 Old 01-28-2013, 12:18 AM
Straybeat's Avatar
I had a plasma with a similar problem and a calibration fixed it. The pic was clear as a bell after that. If you have an ISF guy/girl near you you might give him a call and see what he thinks?
Straybeat is offline
post #4 of 4 Old 01-28-2013, 07:25 AM - Thread Starter
ZachB10's Avatar
I will have to see if I can find someone here. I have gone through the Disney WOW disc and it is as calibrated as I can get it, I know ISF is a completely different level but may be worth a try. I don't want to pay hundreds of dollars to find they can't fix the speckles, though.
ZachB10 is offline
