Anyone recommend a wall mount for Panasonic 65" VT50? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-29-2013, 06:02 PM - Thread Starter
denaliman's Avatar
Liked: 25
I am looking for a wall mount for a 65" vt50. I prefer a tiltable mount (pro & cons between tilt and non-tilt?) and one that is is relatively flush but still allows for cable access. I will need some space or opening in the rear to mount a recessed plug or power bridge. The tv hasn't been delivered yet so I don't know which way the HDMI cable will be oriented out of the tv. I checked momoprice, but I live in Canada and the cost to ship was 3 times the price of a mount so it wasn't such a good deal. I looked at the Sanus LT25 and it looks like it would work, I like the features of the "pro set" and it is open on the bracket. Any suggestions?
denaliman is offline
post #2 of 3 Old 01-29-2013, 07:08 PM
highdefav1's Avatar
Quoted: 106 Post(s)
Liked: 37
Well I was going to recommend a Monoprice mount. I believe someone else indicated Parts Express also sell nice mounts at cheap prices.
I would recommend getting some right angle HDMI adapters. I believe the VT (like the ST) has the HMDI slots out to the side. So when you hook up an HDMI cable (if it's not think like a RedMere cable), it might be visible when viewing the display.
This is the right angle HDMI adapter I got for my ST50, so the HDMI cable is plugged into this from the top. There are other ones where the HDMI cable would be plugged in from the bottom, but you run the risk of blocking the other HDMI slots.
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10419&cs_id=1041913&p_id=4860&seq=1&format=2
Panasonic 55ST50
Yamaha RX-V673
Klipsch RF-52 II // RC-52 II // RS-42 II
Klipsch RW-12d
Klipsch KG 2.5
highdefav1 is offline
post #3 of 3 Old 01-30-2013, 01:58 PM - Thread Starter
denaliman's Avatar
Liked: 25
Thanks for the reply.
