Plasma TV Directly in front of a window - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-30-2013, 02:48 PM - Thread Starter
lctiger's Avatar
I was wondering if I would have any negative effects by placing my plasma so that the only window(bay window) in the room is directly behind the display. Does anyone know if this would cause any drastic negatives during day time viewing? Most of my viewing is done in the evening anyways. Thanks in advance.
lctiger is offline
post #2 of 9 Old 01-30-2013, 02:55 PM
dmaul1114's Avatar
As long as you have good blinds/ curtains so that light hitting your eyes isn't washing out your vision, that should be fine. Probably better than having it somewhere else in the room where it will reflect the window (especially if it's a model without a filter).
For evening viewing, it's moot since the sun's down.
lctiger likes this.
dmaul1114 is offline
post #3 of 9 Old 01-30-2013, 02:55 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
Depends on whether the Bay Window is traditional (Southern exposure, for highest heat gain) or purely decorative little to no direct sun). Either way, you will probably be looking into the light. My L/R TV is mounted across a corner with windows on either side but one faces East and the other North, so no direct light and we watch in the daytime.
lctiger likes this.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #4 of 9 Old 01-30-2013, 03:03 PM - Thread Starter
lctiger's Avatar
It's a southern facing window, but there's a large tree in the backyard and it has thick wooden blinds. The room is 12x18 and the window is on the 18 ft wall so I'm thinking this would allow for more comfortable seating space.
lctiger is offline
post #5 of 9 Old 01-30-2013, 03:17 PM
dmaul1114's Avatar
Should be fine. But I'd just get some black out curtains to be safe. Can keep them open when not watching during the day, and easily shut them when you want to watch something.
Just search for "black out curtains" on Amazon and you can get an idea of prices.
lctiger likes this.
post #6 of 9 Old 01-30-2013, 03:50 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
lctiger likes this.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #7 of 9 Old 01-30-2013, 05:53 PM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
Out of curiosity I just took a flashlight to the back of my 50ST30 in a dark room and I'm getting light bleed through it. On the left top it makes it look like an edge lit lcd. there's about an inch of that. and on the right side about 5 inches in and 5 down there's a spot that shows up brightly right on the screen like the tv's trying to display it, it's a little larger than the vent holes. It's about where the side bar on Randy's tv meets the picture. On my 54G10 it has just one spot that you can barely see in the same area, upper right. The flashlight is pointing straight through which would be impossible for the sun to do. Not sure what model you're talking about but they can be different according to this test. I gave up on looking for more, I don't wanna know, lol
whipit is offline
post #8 of 9 Old 01-30-2013, 06:17 PM
Jay Mammoth's Avatar
Quoted: 30 Post(s)
Liked: 35
My VT is directly behind my windows in the living room, 2 dark curtains is all I needed,
Jay Mammoth is offline
post #9 of 9 Old 01-31-2013, 01:30 PM
swizzchard's Avatar
how do you watch it with 2 dark curtains covering your tv, thats behind your windows eek.giftongue.gif
swizzchard is offline
