panasonic st50 view hours - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-31-2013, 09:55 PM - Thread Starter
SHOWM3URBO0BYZ's Avatar
i seen somewhere that plasmas have a code you can enter to see the hours you have on your plasma. Can someone help me I have a panasonic 55" st50! thanks
SHOWM3URBO0BYZ is offline
post #2 of 6 Old 02-01-2013, 08:25 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
Just google Panasonic Plasma Check Hours or something like that - the procedure is posted EVERYWHERE and you should be able to find it easily.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 6 Old 02-01-2013, 11:27 AM - Thread Starter
thanks i had seen some i just didnt know if it would be different on different models. Also can this mess anything up? some people were saying not too because it can mess up your tv I dont see why it would but just making sure
post #4 of 6 Old 02-01-2013, 11:33 AM
rahkz's Avatar
Warning you are responsible for any modifications to the service menu so please be careful.
what you wanna do is hold down the volume button on the tv set first, while thats held down, press the "info" button 3 times.
this will take you to service menu.
then you want to press 2. then press ok, which will take you to the "src" menu.
then you want to go all the way to the bottom right rectangle using the arrow pad.
once you've highlighted the bottom right corner, hold the mute button until you see the total view hours. (point the remote at the tv so it can "pick up" you pressing down mute)
after that to exit, you can hold the power button on your tv to go back to regular viewing mode.
rahkz is offline
post #5 of 6 Old 02-10-2013, 04:12 PM - Thread Starter
Could it mess anything up if done wrong
post #6 of 6 Old 02-10-2013, 05:50 PM
"Don't PM Me Bro"
Quoted: 499 Post(s)
Liked: 766
Yes - if you do it wrong you can throw your set's Service Menu values all out of whack and ruin your picture quality. Be very very careful while checking your hours in the SM. Just follow the procedure to check your hours, don't venture into the picture adjustment areas.
Randy
