Panasonic ST50 panel brightness - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-02-2013, 07:46 PM - Thread Starter
Donkey_Lips's Avatar
hi all,
SIAP, but i noticed almost all calibrations have the panel brightness set to mid. is there any reason to not have it set to high, other than energy consumption? i feel like the picture is livelier with the setting on high, but i wasn't sure if there are any assumed drawbacks to it. any info is appreciated! TIA.
Donkey_Lips is offline
post #2 of 9 Old 02-03-2013, 09:48 PM
Doublea34's Avatar
TV life i believe. But i second this.
Doublea34 is offline
post #3 of 9 Old 02-05-2013, 12:23 AM
remodeler's Avatar
If you like it brighter by all means make it so. It will look great from here no matter where you keep the settings.
remodeler is offline
post #4 of 9 Old 02-05-2013, 01:04 AM
JSpectre88's Avatar
Liked: 54
It's probably best to change other settings and leave the panel on mid. I wouldn't be worried about energy consumption, but odds are you're washing out detail in darker scenes. If you like an overly bright display though, then go for what you like the best. I suggest leaving it on mid and calibrating with AVS709 if you haven't already tried, but again it's up to you.
JSpectre88 is offline
post #5 of 9 Old 02-06-2013, 04:38 PM
rahzel's Avatar
Liked: 148
The reason people don't use High PB is not because of power consumption. Most people use mid because it provides sufficient brightness for most people. I haven't actually checked, but setting it to high probably messes up the gamma curve. Reason I haven't checked is because I have no need for a higher brightness... not even close. Mid should be able to provide enough brightness for even the brightest rooms.
rahzel is offline
post #6 of 9 Old 02-07-2013, 09:27 AM
HDTBill's Avatar
I fiddled with this setting last night.
It can increase power use, but on a white screen it seems to decrease max power. Some folks like to increase CONTRAST to increase brightness when watching thru 3D glasses.
So this would possibly another way to do that.
I guess we really do not know, for the various pre-set PICTURE modes such as VIVID, CINEMA, GAMES etc. what the default settings are. Seems to me for example VIVID may well have Panel Brightness = High
HDTBill is offline
post #7 of 9 Old 02-07-2013, 07:30 PM
mrkdilkington's Avatar
I have an ST30 so I'm not sure if this applies to the ST50, but on high brightness it introduces color banding in color gradients. Not worth it. It also always defaults back to low brightness after 10 minutes (probably ST30 specific).
mrkdilkington is offline
post #8 of 9 Old 02-07-2013, 08:15 PM
JSpectre88's Avatar
Liked: 54
I actually messed around with this a lot yesterday. Putting the panel brightness on high is awful, and putting the brightness too high will wash out deep blacks. The best thing to do is adjust the gamma settings. You should be using a gamma of 2.6 for 50-55 inch models and 2.4 for 60-65 inch models. Lowering gamma slightly will lighten both dark and bright images, but won't wash out the darkest blacks. At least on my 50" I found a gamma of 2.4 to be perfect on almost any content.
post #9 of 9 Old 02-19-2013, 11:15 AM - Thread Starter
bump to say thanks for all the responses!
