HELP!! 65" VT Panasonic with blinking red power light.. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-07-2013, 08:26 AM - Thread Starter
ashikojim's Avatar
Have a 65vt25 with a cracked screen. Will not power on, power status LED shows trouble code with 7 blinks. Troubleshooting guide suggests possible SU/SD board (can be found online for $50/ea) or other, more likely possibility is 'defective screen' Is it at all possible to run this display with several small cracks if I put $100-200 and replace those two boards or is it just a bunch of spare parts now?. Thanks!!
PLAMSA IS KING!!
ashikojim is offline
