Purple / Pink Hazing in White Scenes On the Samsung pn58c550 Plasma Worth Repair Call? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-08-2013, 09:23 PM - Thread Starter
RIKINKY17's Avatar
I have recently read how hundreds if not more of Samsung owners have had this show up with other models but has anyone had this with this model? It has showed up on my set and I am out of warranty. What should I do at this point? Is it worth a service call or buy a new set?
RIKINKY17 is offline
post #2 of 3 Old 05-12-2013, 07:15 AM
xeonicxpression's Avatar
I'm in the same boat. I think mine is a PN58C500. I don't know what to do, but I'm done with samsung. First one was died 10 hours in, second on formed this problem, and my fiance had an LCD die 1.5 years in. 0 for 3 with Samsung.
xeonicxpression is offline
post #3 of 3 Old 05-12-2013, 01:10 PM
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
Where your seeing color hazing try A combination of raising green gain and lowering red gain until hazing goes away.Then lower green bias half the number amount that you raised greengain.Raise red bias half the number amount that you lowered red gain.Example if you raised green gain 4 then lower green bias 2
Edit You may need too adjust bias a different amount.Those numbers are what it is on my tv.You don't want too move the bias and gains very much if possible..
Vic12345 is offline
Samsung Pn58c550 58 Inch 1080p Plasma Hdtv Black
