Help with sharpness levels on samsung e530 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-11-2013, 04:53 PM - Thread Starter
thollis89's Avatar
I've been reading people having sharpness at 0-10, now sharpness starts at 50 from the factory, which honestly seems most idea for most pictures 50-60, sometimes the 40s look ideal to me, when actually going to the 0-10 level, the picture mostly looks blurry and not in focus. Any suggestions? Or am I blind :x
thollis89 is offline
post #2 of 8 Old 02-11-2013, 05:14 PM
chunon's Avatar
Quoted: 2010 Post(s)
Liked: 1772
Sharpness needs set with a test pattern
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #3 of 8 Old 02-11-2013, 05:23 PM - Thread Starter
thollis89's Avatar
Any suggestions? The only thing I have with a set up is a Finding Nemo DVD with a THX setup, anything I could download higher quality and put it on my usb stick to use directly from the tv? Or use from my xbox/ps3 would be nice.
post #4 of 8 Old 02-11-2013, 05:34 PM
agkss's Avatar
Quoted: 21 Post(s)
Liked: 65
agkss is offline
post #5 of 8 Old 02-11-2013, 05:35 PM - Thread Starter
thollis89's Avatar
Originally Posted by agkss View Post
Overscan-2.jpg 144k .jpg file
resolution_test_1080.jpg 232k .jpg file
Thanks a bunch, I assume adjusting goes the same as the THX set up; adjust until they are defined, but not "edgy"?
post #6 of 8 Old 02-11-2013, 05:37 PM
agkss's Avatar
Quoted: 21 Post(s)
Liked: 65
yes, that's how pattern works
agkss is offline
post #7 of 8 Old 02-11-2013, 06:08 PM - Thread Starter
thollis89's Avatar
Got it dialed in it seems, 17-30 seems ideal, 30 sharpening textures in games but producing edgy text
post #8 of 8 Old 02-11-2013, 06:10 PM
agkss's Avatar
Quoted: 21 Post(s)
Liked: 65
i had a D550 and always used 20
agkss is offline
