The Official What would you do? thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-20-2013, 07:37 PM - Thread Starter
xneox's Avatar
Sorry for the long post.
I'm in the market for a new living room tv and have a couple options.
I have a Panasonic TC-P50V10 in my media room. This is my default viewing space. After-hours with the wife, or weekends with the kids.
The budget allows the purchase of one of two displays (I've narrowed it down - two different scenarios).
Media room swap option - Panasonic TC-P55UT50 would replace the media room display (bigger). The V10 would go to the living room.
No swap option - Samsung UN46EH5000 would be the new living room unit.
I have a high-end plasma in the the media room now. By all accounts, the UT is a mid-level plasma line. I can't get past the thought that I'll see a downgrade based on that alone. Bigger is better, sure, but bigger is also more telling of flaws (I'm about 9' from the display). I'm not itching for 3D, but it would be nice. The UT line has no anti-glare coating, but it's not a bright room. What else?
Option two would put a decent LED-backlit LCD display in the living room. No muss, no fuss. Reviewed universally well. A couple hundred cheaper.
Bottom line - If I'm going to notice a downgrade in picture quality with the UT, I don't want it to replace my V10. If it's lateral, the size and 3D are worth it for me. Any thoughts?
What would you do?
*edited to get rid of useless ramblings.
xneox is offline
post #2 of 6 Old 02-20-2013, 08:58 PM
fatuglyguy's Avatar
Quoted: 285 Post(s)
Liked: 616
I'd take the UT50. If your V10 is calibrated, then the UT would have less options as far as adjustment. It's been the general consensus here that the UT50 is essentially the same as the ST50 minus the AR filter, which shares a panel with the GT50, which is not far apart in performance from the VT50...you get my point. Considering the age of your V10 (a 2009 model) combined with the known issues from that model year (the dreaded black-level rise), I'd say the the UT50 should generally have better performance than your V10, the only caveats being the UT only has two HDMI inputs and is very reflective, which you indicated wouldn't be a real issue for you. Considering the prices that 55" UT50s are being blown out for now, I'd say it's a no-brainer, especially when you factor in the fact that Panasonic will not be offering anything at the price/performance ratio of the UT50 ever again.
desktop Sonus faber Toy monitor| REL T Zero| Sony UDA1|Sony MDR-Z7|Audioquest Nighthawk|Audioquest Dragonfly Red
surround Monitor Audio Silver RX6, RX Centre, RX1|SVS SB-2000|Sony STR-ZA5000ES|Panasonic 60ZT60|Oppo 103D|Sonos Connect + Peachtree Audio DAC•iT
stereo Sonus faber Toy tower|Teac UD-501|Sony TA-A1ES|Sony SCD-777ES|Sony ST-SA50ES|Sony BDP-S1700ES|Sonos Connect|Furman Elite-15 PFi|Sony 43X800D
fatuglyguy is offline
post #3 of 6 Old 02-21-2013, 06:30 AM - Thread Starter
xneox's Avatar
The V10 isn't professionally calibrated, but I did use the DVE disc. Will that work just as well on the UT?
I have noticed the blacks start to grey over the last year. Kind of a bummer. Did Panasonic fix that with the newer displays?
Yeah, Costco has it for $699 right now. Pretty crazy.
xneox is offline
post #4 of 6 Old 02-21-2013, 11:35 AM
5150zx's Avatar
Quoted: 36 Post(s)
Liked: 65
I had a 65V10 (great display), but the current crop of TV's are superior in most every way. I have a GT50 and VT50 and they are far superior to my old V10.
fatuglyguy said it better than I....
5150zx is offline
post #5 of 6 Old 02-21-2013, 05:24 PM
chunon's Avatar
Quoted: 2043 Post(s)
Liked: 1795
Yes the rising blacks were fixed starting in 2011
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
post #6 of 6 Old 02-26-2013, 06:09 AM - Thread Starter
xneox's Avatar
Thanks for the opinions, fellas. I ordered the 55" UT50...anxious to get it up on the wall now.
xneox is offline
