8 inch black vertical bar on Panasonic TC-P50GT30 - AVS Forum | Home Theater Discussions And Reviews
Old 02-22-2013, 11:04 AM - Thread Starter
briana101's Avatar
A large black vertical bar recently appeared on our 50in Panasonic Plasma on the right hand side of the screen (see attached) while watching TV via Direct TV HDMI.
I tried adjusting aspects, ratios, resolution, etc. with no luck. The bar does move depending on the ratio though. No clue. What's funny is the black bar is not present when watching DVDs (which is also connected via HDMI) or playing the WII via the component input. I've tried swapping HDMI ports and cables too with no luck.
TV is 15 months old.
Any help would be appreciated.
briana101 is offline
Old 02-22-2013, 11:25 AM
chunon's Avatar
Quoted: 2013 Post(s)
Liked: 1773
If it is not present on your other sources and you have swapped the HDMI cables it has got to be the box itself, have tried connecting thru component cables ?
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is online now
Old 02-22-2013, 01:48 PM - Thread Starter
briana101's Avatar
Took your suggestion and tried the DTV box on another TV but could not replicate the problem. I was using YWR video connection though (don't have another HD TV). So I tried the YWR video connection on my Panasonic GT30, and the problem was gone. Then I switched to new HDMI cable, and the problem is still gone. So I'm happy as can be. I suspect maybe it was a bad HDMI cable, however, I can't exactly duplicate the problem with the old cable now, though the picture is definitely not as good with the old cable.
Thanks again. Case closed for now.
Old 02-22-2013, 02:05 PM
chunon's Avatar
Liked: 1773
That's great Briana glad its resolved smile.gif If you need a good replacement cable check out monoprice
65C6 OLED
Old 02-22-2013, 03:43 PM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
It's good that its gone... but I think you have done nothing...:-( so it will likely come back. I suspect a loose connection in a board which was now working because you played with the cabling. Hopefully, it won't come back but now you know that it is likely on the "backside" and can probably be rectified.
budwich is offline
Panasonic Viera Tc P50gt30 50 Inch 1080p 3d Plasma Hdtv
