HELP!! - My wife used jewelry cleaner on my Panny plasma - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 32 Old 02-23-2013, 02:12 PM
Camster's Avatar
Glad it worked out we have a maid comes in every couple of weeks to clean things & I made sure they were to understand never to touch my tv's for this very reason. Hopefully no one touches your set ever again.
Cam
Camster is offline
post #32 of 32 Old 02-24-2013, 10:39 AM
Otto Pylot's Avatar
Quoted: 1625 Post(s)
Liked: 1020
Originally Posted by goMO View Post
the screen looks better than ever! my plasma is almost 8 years old, so it was due. I used the microfiber every once in a while for a specific smudge, but this seemed like a well earned wash!
You can also use a scent-free Swifter Sweeper refill for weekly dustings. No chemicals, dry, and it picks up all of the dust very easily and leaves absolutely nothing behind on the panel. I do that weekly on mine and only use the distilled water/microfiber cloth as needed (which isn't very often).
Otto Pylot is offline
