Two Panasonic UT 50 Qs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-23-2013, 11:42 PM - Thread Starter
RiffWraith's Avatar
Hi - just picked up a Pan UT50 a few days ago. Was hoping someone can help me out here.
1) When I turn the TV on, I get a message about connecting to the internet. How is this disabled? I see nothing in any of the menus, and the manual makes no mention of this either.
2) Something happened, and now I am not getting the full picture L>R. I was, but now I am not. Not sure what i did.... I have played with the aspect settings (FULL) gets me closest, but still cant get it to where it was initially. A reset to default does not help.
Ideas?
Thanks in advance.
RiffWraith is offline
post #2 of 5 Old 02-24-2013, 08:59 AM
VarmintCong's Avatar
Ideas?
Thanks in advance.
Set your picture size to 2
VarmintCong is offline
post #3 of 5 Old 02-24-2013, 12:35 PM - Thread Starter
RiffWraith's Avatar
Hi - thanks.
It is 2. 1 is worse.
post #4 of 5 Old 02-24-2013, 03:49 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
I think what you're seeing is the Viera Connect Banner (comes up along the bottom when you turn the TV on). You can disable this by going into the Setup menu, scroll down to Advanced Setup, then in there you can turn the Viera Connect Banner to OFF.
2) Something happened, and now I am not getting the full picture L>R. I was, but now I am not. Not sure what i did.... I have played with the aspect settings (FULL) gets me closest, but still cant get it to where it was initially. A reset to default does not help. Ideas?
You didn't say what your source is when this is happening, but it sounds like there's an issue with some sort of Aspect setting on your source (cable box, satellite receiver, DVD player, etc). If your previous TV was a 4:3 screen then your source may not know it's now connected to a widescreen TV so usually you have to go into the source's setup menu and change the TV type to widescreen or 16:9 etc.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #5 of 5 Old 02-24-2013, 05:31 PM - Thread Starter
RiffWraith's Avatar
Got it - thanks!
"it sounds like there's an issue with some sort of Aspect setting on your source "
Yep - I must have acidentally hit the HD Zoom button on the cable remote. Pressed it, and all is fine now.
Thank you!
