HELP Samsung PN58B860 image is dim grainy and there is a dark spot - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 43 Old 03-08-2013, 02:22 PM - Thread Starter
str8maxn's Avatar
Originally Posted by tom669 View Post
The LVDS cable runs from the main board, which has the video inputs, to the control board, which is the board that has the 3-4 jumper on it.
TOM, I removed the LVDS cable and added a jumper on pins 3-4 and turned on the TV. Nothing show up on the screen.
str8maxn is offline
post #32 of 43 Old 03-08-2013, 02:31 PM - Thread Starter
str8maxn's Avatar
I forgot to mention that there is a flashing green LED light on the logic board.
str8maxn is offline
post #33 of 43 Old 03-08-2013, 06:03 PM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
This is unexpected. I have to be honest; these TVs are alien to me, I've only worked on older Samsung plasmas.
Do you get good Vs/Va from power board when powered up?
tom669 is offline
post #34 of 43 Old 03-09-2013, 03:22 PM - Thread Starter
str8maxn's Avatar
No worries Tom, I'll take any advise you have.
Yes, Both Vs and Va tested OK. I found the Y board and two buffer board on ebay pretty cheap, I am hoping replace them will fix the tv.
I should get them mid next week. I'll let you know how that goes. Thank you very much for the support.
JM
str8maxn is offline
post #35 of 43 Old 03-09-2013, 04:07 PM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
I hope it fixes it.
tom669 is offline
post #36 of 43 Old 03-14-2013, 03:58 PM - Thread Starter
str8maxn's Avatar
I hope it fixes it.
Tom, SUCCESS!!!!!! It looks like it was a bad Y board. The X board also needed replacing. I found some broken welds on some very small resistors. So small I lost them when I tried to repair them. The two replacement buffer boards dont appear to work. I don't get an image when I installed them. Do you recommend getting new buffer boards? Or am I good now? (since I goot a good Image)
Thanks again Tom.
JM
str8maxn is offline
post #37 of 43 Old 03-15-2013, 04:03 PM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
Nice to hear that. I'd keep the current buffers. Often, these parts are harvested from cracked screen TVs. If the TV is switched on when it is cracked, or powered on after the event, the buffer board can be damaged by the shorted electrode lines. I would send the faulty buffers back. What's the total investment for this 58"?
tom669 is offline
post #38 of 43 Old 03-15-2013, 04:16 PM - Thread Starter
str8maxn's Avatar
That's exactly what I did; Keep my buffers and sent the bad one back.
Over all cost:
Samsung 58 $175.00 (but it was sold to me as 65 inch cuz of the box otherwise I would have tried to get it lower)
X board $ 25.00
Y board $ 50.00
Total $250.00
str8maxn is offline
post #39 of 43 Old 03-15-2013, 04:16 PM - Thread Starter
str8maxn's Avatar
Over all cost:
X board $ 25.00
Y board $ 50.00
Total $250.00
str8maxn is offline
post #40 of 43 Old 03-17-2013, 04:49 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
Not bad for a 58" 1080p Smart TV! Amazing what people will throw out for needing just $75 in parts.
I still feel jammy for picking up the 46" Panasonic 1080p plasma with a fault for under $110 (£70 in the Queen's money), and finding the only fault to be a loose cable.
tom669 is offline
post #41 of 43 Old 03-18-2013, 10:12 AM - Thread Starter
str8maxn's Avatar
Sounds like you got a great deal too..
Tom, Thank you again for all the help. This is my 3rd TV I fix. It started with my own when it went out and I found it a challege to try to fix it. Since then both my kids are befefiting for someone else's trash.
on to the next one....
JM
str8maxn is offline
post #42 of 43 Old 03-20-2013, 06:37 AM
tom669's Avatar
Quoted: 149 Post(s)
Liked: 139
I've done over 50 repairs! Family got a 40" 1080p Samsung LCD, I got a 46" Panny plasma (I'm not keeping any crappy LCD smile.gif) and my dad got a 50" NEC plasma (a pretty old model, but it suits him because it's quite big and he can see it well, it's 720p only and struggles with black levels but that's not a problem for average TV.) In total? All three were acquired for under £160, all in faulty condition and fixed very cheaply. I think I only spent £10 on the capacitors for the Samsung. The NEC had a failed shorted audio board, so I unplugged that and gave my dad a 5.1 amp as a birthday present which cost £20 (also faulty until I fixed it) and the Panasonic was, as mentioned, a loose LVDS cable.
tom669 is offline
post #43 of 43 Old 04-16-2013, 05:19 PM - Thread Starter
str8maxn's Avatar
Tom,
If you can help once more that would be great. I picked up another TV.
http://www.avsforum.com/t/1468576/samsung-58-pn58b650s1fxza-help-needed
str8maxn is offline
