Official Panasonic S60 Series Discussion Thread - Page 236 - AVS Forum | Home Theater Discussions And Reviews
 107Likes
post #7051 of 7540 Old 07-03-2014, 02:32 AM
sawfish's Avatar
Quoted: 122 Post(s)
Liked: 142
I wouldn't expect a 1080p TV to support 1920x1200. You should extend your desktop to the TV, not mirror it. I do that with my HTPC running WMC with CableCard and XBMC, and it works perfectly and uses the TV's native resolution, which is what you want to be using anyway.
sawfish is offline
post #7052 of 7540 Old 07-03-2014, 05:59 AM
xenon9887's Avatar
Liked: 94
Playing a 1920x1200 16:10 signal on a 1920x1080 16:9 set wouldn't make any sense as the aspect ratios do not match. The image on the TV would have to either zoomed in to maintain aspect ratio or squashed vertically to fit.
What you can do is go into your driver settings on the source PC, change your resolution to 1080p and disable scaling. What you will end up with is a thin black bar on the top and bottom of your monitor but the image will still be 1:1.
Hope this helps.
xenon9887 is offline
post #7053 of 7540 Old 07-10-2014, 09:06 AM
dmtaub's Avatar
Quoted: 100 Post(s)
Liked: 34
So, after experimenting with an F4500 for a couple of days, I ended up taking it back and picking up this beauty, along with the UT50, both 50 in, for $800 out the door. Both were floor models at Pacific Sales. I'm keeping the S60 for my bedroom, my dad is taking the UT50 for his bedroom. Very happy with the purchase. So, obviously being a floor model, it had plenty of hours on it (I think around 2000). I have seen like 7 revisions of fairchild99's settings, looking like 4/27/13 is the latest. I cannot find the other settings posted on the first page as the link just takes me to the end of the thread, and going through 236 pages would suck. If anyone can offer the following, I would be greatly appreciative:
Fairchild99 settings later than 4/27/13, if they are available
D-Nice settings (though, it looks like he didn't do a S60 run, only ST and above)
Any other known settings that most are happy with
I did a bunch of searchs, still coming up with 25 plus pages to look at. If you want to flame, be my guest. I'm just looking to get the best possible picture I can. Thank you.
dmtaub is offline
post #7054 of 7540 Old 07-10-2014, 10:55 AM
ToonMasterTim's Avatar
Quoted: 99 Post(s)
Liked: 74
It's great to see others still finding great deals on this set. How I miss the buzz on these boards last year around this time when I was deciding to purchase my S64 from Sam's Club. I spent hours reading the thread before and after my purchase. I'm still loving the set. And with Panasonic having ceased PDP production, I am glad I went with the S64 last year. You and your dad should be very happy with the TVs.
jasondjulian put together a wonderful spreadsheet of the various calibrations that were done by fairchild and others. It is available from his profile.
http://www.avsforum.com/forum/member...ondjulian.html
ToonMasterTim is offline
post #7055 of 7540 Old 07-10-2014, 11:02 AM
dmtaub's Avatar
Quoted: 100 Post(s)
Liked: 34
Thank you Tim. However, when I go to the profile and click his link, it just takes me to the end of the S60 discussion thread. This is the problem I was having with the links in the 1st post. Anyway someone can pm me the spreadsheet?
dmtaub is offline
post #7056 of 7540 Old 07-10-2014, 11:04 AM
Quoted: 99 Post(s)
Liked: 74
Sorry. I didn't try the link. Perhaps it is due to the forums upgrade that was done recently? I'll PM you with the spreadsheet.
dmtaub likes this.
post #7057 of 7540 Old 07-10-2014, 11:09 AM
jasondjulian's Avatar
Quoted: 37 Post(s)
Liked: 78
No flaming.. check out the link my sig... I've linked to a spreadsheet I made that has a lot, but apparently not all of Fairchild99's settings, as well as a number of others.. its a good starting point.
I have about 1700 hours on my S60 purchased in early-mid December, and I am using Fairchild99's 2200+ hours settings.. i played with going back and forth with those settings and the ones I listed from PlasmaPZ80U, which I actually prefer slightly better ON MY TV... yours may very well differ. Keep in mind these are not calibrations for our sets, only theirs, and should be used as very good jumping off points. Feel free to tweak them on your S60 as needed.. on mine, I found PlasmaPZ80U's settings with Warm1 and brightness at 0 instead of -1 looked significantly better...
Of course the room and ambient lighting and seating distance will factor in as well.
dmtaub likes this.
Panasonic TC-P55S60
Sony S5100 BD-Player
Sony HT-XT1 Sound Base
jasondjulian is offline
post #7058 of 7540 Old 07-10-2014, 11:10 AM
MilkManX's Avatar
Quoted: 51 Post(s)
Liked: 41
Wink
Mine is set in Cinema /Warm 2 and then fine tuned with the Disney WOW BD. Settings are in this thread somewhere.
MilkManX is offline
post #7059 of 7540 Old 07-10-2014, 11:11 AM
Quoted: 37 Post(s)
Liked: 78
.. Yeah, crap... it must be from the forum upgrade.. I'll have to fix that...
I had to convert the Excel spreadsheet into a word document.. so it aint as pretty (as if it ever was!).. but it should be attached to this posting.
Auntie-Raster likes this.
Panasonic TC-P55S60
post #7060 of 7540 Old 07-10-2014, 11:21 AM
mailiang's Avatar
Quoted: 720 Post(s)
Liked: 527
Post CNET Settings
You also may want to try CNET's David Katzmaier's settings. After some additional tweaks, I got excellent results. However, I recommend keeping the white balance and color detail controls at the default position. Since every panel is different, these adjustments are more critical, and require special tools.
http://forums.cnet.com/7723-19410_10...ture-settings/
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #7061 of 7540 Old 07-10-2014, 11:23 AM
dmtaub's Avatar
Quoted: 100 Post(s)
Liked: 34
Ian
I was going to try his, but I saw his gets a very strong red push. I'll play around with them.
dmtaub is offline
post #7062 of 7540 Old 07-10-2014, 11:35 AM
mailiang's Avatar
Quoted: 720 Post(s)
Liked: 527
Edited my last post. Also, try warm 1 instead. No red push on my particular set.
Ian
mailiang is offline
post #7063 of 7540 Old 07-10-2014, 12:05 PM
FlynP5's Avatar
I tried some of the settings found in this thread but ended up running a calibration disk to get my own settings. I had much better skin tones after doing this.
AVS HD 709 - Blu-ray & MP4 Calibration
Panasonic TC-PS60 plasma • Anthem MRX 510 • OPPO DV-980H •
Rogers Nextbox 2.0 8642 HD • Playstation 3 • HTPC (GA-EP45-UD3P, AMD Radeon HD 6870) • SVS Ultra Series Speakers • HSU STF-3 Subwoofer
FlynP5 is offline
post #7064 of 7540 Old 07-10-2014, 12:24 PM
Quoted: 37 Post(s)
Liked: 78
I found with nearly any of the posted settings, they all seemed a bit too pink... similar to when you look at Kuro vs ST/VT/ZT Panny images.. the Kuro has more natural fleshtones, while the Panasonics are pinky, everyone looks somewhat flush by comparison.
I switched from Warm2 to Warm1 and relatively speaking, the pinkyness went away.. much more natural looking.
Panasonic TC-P55S60
post #7065 of 7540 Old 07-10-2014, 12:35 PM
dmtaub's Avatar
Quoted: 100 Post(s)
Liked: 34
I did notice that as I was playing around. Warm1 seems a bit more natural than warm2. Was getting a lot of yellowness. I may try the avshd disk and see what I can do.
dmtaub is offline
post #7066 of 7540 Old 07-10-2014, 01:00 PM
Quoted: 99 Post(s)
Liked: 74
Likewise. I have preferred Warm 1 over Warm 2, which is a bit too warm. You'll notice that on Warm 1 the whites are more white, whereas on Warm 2 they can often look "dirty" by comparison. With Gamma, I often prefer 2.2, but 2.4 can be okay as well.
post #7067 of 7540 Old 07-10-2014, 08:13 PM - Thread Starter
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 438 Post(s)
Liked: 739
Yes the forum upgrade broke lots of people's links including a bunch of mine. If someone finds the original Fairchild settings link i'll edit it into the first post.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo Series3 & Premiere, TWC Cisco 8742HDC DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, R40, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #7068 of 7540 Old 07-12-2014, 09:18 AM
dmtaub's Avatar
Quoted: 100 Post(s)
Liked: 34
Thanks Everyone. After trying a few different settings from the spreadsheet, I ended up going with Fairchilds 2200+ settings (this set had about 2500 hours on it), but switched it to Warm1. Warm2 just looked a bit dirty. Warm1, the colors pop and the whites are white, while still having great blacks.
I am really happy with the purchase. Now, just to get my PB6600 off the wall and do some poti tuning!
dmtaub is offline
post #7069 of 7540 Old 07-14-2014, 05:30 AM
Quoted: 37 Post(s)
Liked: 78
Sounds like you and I are using the exact same settings. You have about 800 more hours on yours than I do, but I too found that those specific settings are quite accurate, white whites and very deep blacks while JUST avoiding black crush.
Panasonic TC-P55S60
post #7070 of 7540 Old 07-15-2014, 10:29 AM
xx2000xx's Avatar
I don't have any tools for calibration so I've always played around with Fairchild's and Cnet. I recently got an x-star 1440p PLS panel monitor that has excellent colors out of the box. So I compared it to what I was using via my HTPC playing HQ files and I'm now off of Cnet's settings (only change was I moved it up to 2.4 instead of 2.2) I found out the blues/pinks/reds were out of wack and actually what came almost spot on was Fairchild's settings (2.4, I think his last one was at 2.6 but I had it saved in custom) but with actually Warm 1 instead of Warm 2 as I've always used 2. So I guess I'm jumping on board with you guys with Warm 1. I've spent too many hours tweaking this TV but it looks like I can just set it and forget it now and just enjoy it.
Here's the review if anybody is interested of the famous Korean monitor that I got that's all the rage. No dead pixels and no black light bleed and can OC to 96hz no problem.
xx2000xx is offline
post #7071 of 7540 Old 08-07-2014, 11:11 AM
MilkManX's Avatar
Quoted: 51 Post(s)
Liked: 41
Anyone use an Optical to RCA L/R converter to get some analog stereo out on this TV or any TV?
I hope it works!
MilkManX is offline
post #7072 of 7540 Old 08-07-2014, 12:12 PM
Quoted: 37 Post(s)
Liked: 78
Yes.. it works fine.
something like this:
http://www.amazon.com/Digital-Optica.../dp/B005DIRI6I
or this:
http://www.walmart.com/ip/Insten-INS...erter/28882414
or this:
http://www.newegg.com/Product/Produc...9SIA0U008H8083
All practically the same thing, doing the same job. As mentioned, works fine for converting Digital Optical (TOSLINK) audio to 2 channel analog audio.
MilkManX likes this.
Panasonic TC-P55S60
post #7073 of 7540 Old 08-07-2014, 12:14 PM
MilkManX's Avatar
Quoted: 51 Post(s)
Liked: 41
Thanks again. DO you know if you can set the TV to output PCM on the Optical out?
MilkManX is offline
post #7074 of 7540 Old 08-07-2014, 01:56 PM
mailiang's Avatar
Quoted: 720 Post(s)
Liked: 527
Post Digital Audio Output Setting
Yes you can. First select Network or Media player and then the sound options in the menu. Scroll down and under the digital audio out setting, select PCM. Default is Auto.
Ian
mailiang is offline
post #7075 of 7540 Old 08-07-2014, 02:12 PM
MilkManX's Avatar
Quoted: 51 Post(s)
Liked: 41
Ian
Great. Thanks.
MilkManX is offline
post #7076 of 7540 Old 08-07-2014, 05:35 PM
Liked: 0
Hey everyone!
I'm thinking of getting the 60S60, which is still availble in my country. I read almost the whole thread here to get a solid decition. At first I was actully looking at the 60ST60 which is about 700$ more, but it was really flickering, aspecialy on bright scenes. I read here that some people say the S60 does not flicker as much. Can any one give me an opinion? It's really hard to find those TVs on disply here since it's all LED now in stores.
Other then that, How is it compering the the ST60 in motion and action movies? how does the lack of 1080P/24 afects anything? it's gonna be placed in a very dark room so the lack of AR filter is not an issue.
Thank you all for your kind help!
OM82 is offline
post #7077 of 7540 Old 08-09-2014, 12:21 AM
ChadThunder's Avatar
Quoted: 84 Post(s)
Liked: 63
Originally Posted by OM82 View Post
Hey everyone!
The ST60 has better motion for sure (3D phosphor and faster subfield driver), the flicker you perceived was probably a combination of bad settings and depending on where you live it is possible the panel was running in 50hz mode in which it is known to have a few motion problems such as dynamic false contouring, the ST60 offers an option to convert 50hz signals to 60hz which works well but in doing that you might introduce a very subtle soap opera effect.
Your best bet is to try all the settings in store, start in "Cinema mode", turn down the sharpness control and have a close look at the the frame creation option, Panasonic plasmas have a lot of potential but some of the worst default settings imaginable
mailiang likes this.
ChadThunder is offline
post #7078 of 7540 Old 08-09-2014, 02:07 PM
Liked: 0
Thank you for the reply
I'm also trying to save some $$$ by choosing the 60S60, which is about 800$ differance. How bad is the motion blur on the S60 and the lack of 1080p/24 support? I don't need 3D and it's going to my basement which is a really dark room.
OM82 is offline
post #7079 of 7540 Old 08-09-2014, 03:52 PM
mailiang's Avatar
Quoted: 720 Post(s)
Liked: 527
Personally, I don't game and I haven't any issues with motion blur or 1080p/24 content. I watch at least two movies on Blu-Ray a week. The S60 shines in rooms with controlled lighting, and according to David Katzmaier of CNET, under low lighting conditions it comes very close to the PQ of the ST60.
Ian
ToonMasterTim likes this.
mailiang is offline
post #7080 of 7540 Old 08-09-2014, 05:02 PM
MilkManX's Avatar
Quoted: 51 Post(s)
Liked: 41
I watch Blu Ray and game on my s60 with no motion blur issues.
MilkManX is offline
Panasonic Tc P65s60 65 Inch 1080p 600hz Plasma Hdtv , Panasonic 60 Inch Plasma Hdtv Tc P60s60 , Panasonic Tc P55s60 55 Inch 1080p 600hz Plasma Hdtv , Panasonic Tc P50s60 50 Inch Plasma Hdtv , Panasonic 42 Inch Plasma Hdtv Tc P42s60
taboola here
