Official Panasonic S60 Series Discussion Thread - Page 244 - AVS Forum | Home Theater Discussions And Reviews
 115Likes
Old 12-21-2014, 05:18 PM - Thread Starter
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
Originally Posted by foghorn2 View Post
Also there is no excuse for no guide on the s60's . Very lame on Panasonic's part.
Why is it very lame? Very few TVs have a guide so it's pretty rare. And nation-wide, less that 15% of TV watchers are using an antenna so the vast majority of us subscribe to a TV service and get our guide that way so a guide built into the TV is a low priority with most TV makers.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Old 12-22-2014, 06:00 AM
jasondjulian's Avatar
Quoted: 45 Post(s)
Liked: 82
OTA tuner with a built in channel guide? Didn't realize they were even doing that.. now come to think of it, I think my dads 50" Toshiba LCD had one.. but it wasn't very good..
also.. that 0.013cd/m2 measurement for the MLL of the S60... while good, also not the lowest I have seen measured for an S60 either. However, I think I know where foghorn is coming from.. i think with the pixel structure the way it is and the 720 v 1080 thing, at the same distances, the perception may be for deeper blacks.. while measurements show otherwise.
Panasonic TC-P55S60
Sony S5100 BD-Player
Sony HT-XT1 Sound Base
jasondjulian is offline
Old 12-22-2014, 01:36 PM
foghorn2's Avatar
Quoted: 93 Post(s)
Liked: 79
Still Lame and lazy on Panasonic's part, my son's POS Chinese named 24" lcd tv even has a guide.
foghorn2 is offline
Old 12-22-2014, 02:29 PM - Thread Starter
"Don't PM Me Bro"
Quoted: 499 Post(s)
Liked: 766
Ok whatever. Just because some no-name company includes a virtually useless feature that very few people would ever use doesn't make the other TV makers lame and lazy.
mailiang likes this.
Randy
Old 12-29-2014, 09:02 AM
Avnizzle's Avatar
Hi all,
Turned on my S60 the other day and found CP24's ticker burned into the bottom of my screen. I've tried running the "Screen Wipe" setting but still have no luck getting rid of it, any other suggestions?
Thank you.
Avnizzle is offline
Old 12-29-2014, 09:32 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Originally Posted by Avnizzle View Post
Hi all,
Thank you.
How long was the ticker displayed? What are your picture settings? It's probably just stubborn IR. You can either run the screen wash for several hours a day to get it to fade, or you can purchase the Disney Wow disc, use the test patterns and do a proper calibration. Then I suggest you run the pixel flipper, which I have read on this forum is pretty effective with issues like this. I watch sports programming with tickers all the time and station logos are a constant. Keeping the contrast and brightness at reasonable levels and watching full screen content regularly should help prevent stubborn IR, which has never been an issue on my set.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
Old 12-29-2014, 09:39 AM
Avnizzle's Avatar
Originally Posted by mailiang View Post
How long was the ticker displayed? What are your picture settings? It's probably just stubborn IR. You can either run the screen wash for several hours a day to get it to fade, or you can purchase the Disney Wow disc, use the test patterns and do a proper calibration, and then run the pixel flipper, which I have read on this forum is pretty effective with issues like this.
Ian
It was left on for 8+ hours and settings are "Cinema" using David's settings from CNET (http://forums.cnet.com/7723-19410_10...ture-settings/). I left the Screen Wipe on overnight, checked this morning and no difference.
Avnizzle is offline
Old 12-29-2014, 09:52 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Again, how long was the ticker displayed? Did you watch full screen content afterward or run the screen wash? This usually helps prevent stubborn IR, especially if you don't have a lot of mileage on the set. Try the Disney WoW flipper, but it may take some time to get results. Also, running the screen wash over night may not be long enough. You will probably have to do that for several days, and don't display that image until it's corrected.
Ian
mailiang is offline
Old 12-30-2014, 05:52 AM
Quoted: 45 Post(s)
Liked: 82
How large of a border of unused pixels is everyone seeing on their S60?
Full 1080i/p images, Overscan OFF, horizontal size 1 .... you know, the normal settings.
Depending on the content, allegedly all at 1080i, I'm seeing anywhere from 3-5mm. I just noticed it yesterday... and I don't recall having seen this border of unused pixels before, or perhaps not as much. Also odd that it changes based on content that is all supposedly the same 1080 res. I've noticed it while watching my ATT U-Verse, I have not yet checked it with Bluray.
I know that it is not uncommon to have this border of unused pixels, often to mask the edge of the panel itself.. I was just CERTAIN that previously my image, all HD images, went straight to the black plastic.
Panasonic TC-P55S60
Old 12-30-2014, 06:10 AM
RWetmore's Avatar
Quoted: 360 Post(s)
Liked: 198
I wouldn't worry about it. I too have noticed what I thought were shifts in the used pixels, but I think it's because not all the 1080x1920 are 'engaged' with all content. What you really need to do to check is run a full screen test pattern like all white or all one color and look then. I'm virtually sure your set is fine though.
RWetmore is offline
Old 12-30-2014, 06:16 AM
RWetmore's Avatar
Quoted: 360 Post(s)
Liked: 198
Hi all,
Thank you.
Yeah, the Disney WOW disc's pixel flipper. You might have to run it for a day or two but it should get rid of it.
RWetmore is offline
Old 12-30-2014, 06:32 AM
Quoted: 45 Post(s)
Liked: 82
Thanks for the reassurance. I'm fairly positive that when it was new, some 2600 hours ago, and I ran the solid color break-in slides the image filled every single last pixel right up to the plastic bezel.
I'm sure if I checked bluray it'd be the same. Good to know.
Panasonic TC-P55S60
Old 12-30-2014, 08:29 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
I have only seen it when watching the weather report on Eyewitness News, which has a broadcast rez of 1280x720p. What you are seeing is normal and will be seen on certain content. Overscan and why all TVs do it.
Ian
mailiang is offline
Old 12-30-2014, 08:41 AM
ToonMasterTim's Avatar
Quoted: 114 Post(s)
Liked: 78
Or just watch normal content and it will eventually go away. I'd rather just watch content and have it diminish over a longer period of time rather than run a pixel flipper for several hours, putting hours on the TV for no reason other than to remove some image retention. But to each their own. I know it can be annoying to not notice something once you've seen it.
ToonMasterTim is offline
Old 01-04-2015, 09:56 PM
jimmyrickard's Avatar
Hi guys I am looking to buy a Panasonic SC-HTB680GNS Soundbar to compliment my S60. I'm interested in Panasonic devices being compatible with each other like remote sharing etc. will these two devices work together?
Cheers
jimmyrickard is offline
Old 01-05-2015, 07:45 AM
Quoted: 114 Post(s)
Liked: 78
Cheers
Best bet is to check the sound bar manual. You can typically find them online. And often you can use the Viera Connect feature to link up the devices.
That said, you may not necessarily have to use a Panasonic sound bar for compatibility. For instance, I have a Vizio sound bar and was able to program my S60s remote to control the sound bar. Vizio incorporated this feature and it made programming the TV remote a breeze. But it only permits me to change volume. For other features of the sound bar I have to use the Vizio remote, but for the most part I just set it and forget it.
Narrow it down to the features you think you would want and see what is offered. I am not sure how well the Panasonic sound bar performs. You may be able to get a better sound bar and still have the compatibility you desire. Many sound bars probably allow you to program your TVs remote to control the volume, just as my Vizio does. Best wishes.
Old 01-11-2015, 04:46 PM
Liked: 0
My TC50PS64 seems to have the "soap opera effect" even though it's not an option on that model. Things moving on screen seems faster then they should be, and everything looks like home video. It seems worse in 48hz than 60hz. This is my second TC50PS64 and I never had this issue on the first one. I've looked through the menu and there isn't any motion interpolation option.
bunnyears is offline
Old 01-12-2015, 10:22 AM
RWetmore's Avatar
Quoted: 360 Post(s)
Liked: 198
No, you're correct there isn't. I'm not sure what you're seeing.
RWetmore is offline
Old 01-12-2015, 12:53 PM
dmtaub's Avatar
Quoted: 100 Post(s)
Liked: 34
Is it with one source? All sources? Both HDMI ports? The more info you can give, the better.
dmtaub is offline
Old 01-12-2015, 01:33 PM
Quoted: 114 Post(s)
Liked: 78
I have seen another mention of this in the thread, but I have never noticed it on mine. If you enable 48 Hz mode it may seem to smooth out the motion a bit on 24p sources, like Blu-ray. If that's what you're seeing, perhaps you should disable 24p on your player and set the TV to output 60 Hz.
Old 01-12-2015, 01:56 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
The only difference I can see is flicker. 48HZ doesn't usually agree with most TV's when outputting 24p.
Ian
mailiang is offline
Old 01-12-2015, 06:19 PM
Liked: 0
I don't think it's the player or HDMIS because I noticed it while watching television as well. It's very strange because it's not supposed to be a feature and there's nothing in the menus (as far as I can tell). And my old TC50PS64 never had this problem.
Old 01-12-2015, 08:55 PM
Cravit8's Avatar
Quoted: 1151 Post(s)
Liked: 610
Simply because you're new. Would you please take a picture of your username written on paper next to the TV's sticker on back showing model number?
Or just post a quick youtube video of the problem which would help even more.
bunnyears likes this.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
Old 01-13-2015, 03:35 AM
Liked: 0
I'm starting to suspect that my problem may be caused by my blu-ray player and/or the HDMI cord, although that wouldn't explain this happening on tv programming. I replaced the hdmi cable for an unrelated reason, and the effect seemed to go away completely in 60hz. However, it was still there in 48hz. I restored the blu player to factory settings...and now it's back in both modes
or could it be my eyes are deceiving me?
Old 01-13-2015, 07:39 AM
Quoted: 45 Post(s)
Liked: 82
Have you asked anyone else to view your suspect content and ask them what and how they see it? It very well could be a combination of playback frame rates and your eyes...
Panasonic TC-P55S60
Old 01-30-2015, 05:37 PM
littlegoat's Avatar
I attempted to adjust picture settings this evening and I can navigate to the main menu and for options with only +/- minus adjustments(i.e. contrast) I can change those but anything will multiple selections like the picture mode I can not change. I navigate to the Picture mode, hit ok, and the screen flashes up the menu with standard, vivid, cinema but then immediately returns the the previous menu.(navigating menus from the remote & hard keys on side of tv and both behave the same)
I tried to reset the device to default, and that made no difference for my menu issue, but now the picture looks terrible, software is up to date. I have no idea what else to try, any thoughts?
littlegoat is offline
Old 01-30-2015, 07:55 PM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
Maybe you're in Hotel mode. In the service manual it says to unplug the tv from the wall outlet to exit that mode. Worth a try.
littlegoat likes this.
whipit is offline
Old 01-31-2015, 12:31 PM
littlegoat's Avatar
Thanks I unplugged it and same behavior.
I will search for a newer firmware, Tv says up to date but in reading via Google I see for this set the auto update feature didn't work well for folks.
Old 02-02-2015, 10:12 AM
littlegoat's Avatar
Found a higher firmware update from Panasonic via Google, installed and menus are back to normal.
Old 02-08-2015, 02:29 PM
I've noticed that when I play movies through the USB with my portable HDD on the S60, there is like a very faint surge of white light on the screen, usually in the black borders of a movie, and only happens momentarily. Blink and you miss it. Any idea what's going on here? When I plug the HDD into the other USB the TV gives me a oversurge error which is a bit concerning, and makes me think that these TV's can't really handle the extra power required from the HDD or something. Has anyone else experienced this?
There really isn't enough power available for a portable drive on these pannys. The only thing that works is a powered drive. Also the tv only supports USB 2.0. A 3.0 device will work at 2.0.
Since taking Whipit's advice I've been using my HTPC to watch movies, but I notice that I still get glimpses of white light near the borders of the screen. I've noticed it only happens when I'm watching something in anamorphic (2:35:1), where the black borders flicker. I'm running the HDMI through a powered HDMI switcher if that makes any difference.
ALSO
When I look very close to the screen, it looks incredibly grainy with pixels moving all over the place. Is this normal?
EDIT: After doing some googling, it appears the grainy stuff is known as 'dithering'. Apparently this is an issue with a poorly calibrated TV? Anyway, I picked up the Disney WOW calibration Bluray, should that sort it out once calibrated?
Panasonic Tc P65s60 65 Inch 1080p 600hz Plasma Hdtv , Panasonic 60 Inch Plasma Hdtv Tc P60s60 , Panasonic Tc P55s60 55 Inch 1080p 600hz Plasma Hdtv , Panasonic Tc P50s60 50 Inch Plasma Hdtv , Panasonic 42 Inch Plasma Hdtv Tc P42s60
