Official Panasonic S60 Series Discussion Thread - Page 251 - AVS Forum | Home Theater Discussions And Reviews
 105Likes
post #7501 of 7534 Old 11-12-2015, 03:27 PM
ToonMasterTim's Avatar
Quoted: 98 Post(s)
Liked: 73
Originally Posted by mailiang View Post
24 hz setting on a TV? The S60 has a 60 and 48 hz setting. I have my BD player set to native (24p), which allows the set do the processing. In my particular case, this renders the best results.
Ian
It's 48 Hz. Whatever. I was at work and couldn't remember. It's the setting that is not 60 Hz.
ToonMasterTim is offline
post #7502 of 7534 Old 11-12-2015, 08:47 PM
mailiang's Avatar
Quoted: 685 Post(s)
Liked: 502
Most people find that the 48hz setting produces too much flicker.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #7503 of 7534 Old 11-13-2015, 02:57 AM
Quoted: 98 Post(s)
Liked: 73
Ian
I know. That's what I said. But, I don't mind it. And even my wife has never mentioned it, so I suspect it doesn't bother her either.
post #7504 of 7534 Old 11-26-2015, 08:37 PM
Liked: 0
Hi All,
I'm new here and not sure if it is best to start my own thread, but I have a P55S60 and it's been working great up until a week ago. A vertical black bar appeared on the very left side about 4 inches wide with a few mulitcolored vertical lines of that are very thin - close to a single pixel wide. Based on my internet Googling and a bit of reading, I took the TV apart on the off chance it was loose connectors on the C3 board. I loosened and cleaned out the connectors and a bit of dust in the housing.
Attached are pics of it's regular operation showing the symptoms (black vertical bar) as well as what it looks like if I unplugged two of the C3 boards ribbon connectors.
So, my question: Is it the panel or the C3 (or any other board)?
ID:	1082202   Click image for larger version
Tonkatruck is offline
post #7505 of 7534 Old 12-17-2015, 10:43 PM
Ceej64's Avatar
Ian
Call me crazy, but one of the ways I can tell the brightness/contrast is calibrated properly is that the flicker almost disappears. It's there, but almost not noticeable, and not distracting the way it is otherwise.
Ceej64 is offline
post #7506 of 7534 Old 12-18-2015, 08:32 AM
mailiang's Avatar
Quoted: 685 Post(s)
Liked: 502
David Katzmier, ISF calibrator and Senior editor of CNET, reviewed a well calibrated S60. His comments:
Video processing: The S60 showed a couple of flaws in this category. Most importantly, unlike the ST60 it is incapable of correctly reproducing the correct film cadence of 1080p/24 sources when set to its standard (60Hz) mode. Instead, the pan over the Intrepid from "I Am Legend" (my standard cadence test) appeared relatively halting and choppy, compared with the smoother -- yet not too smooth -- look of the ST60 and other sets that handled film correctly. I tried the 48Hz mode but as usual it flickered too much for me to tolerate. Since those are the only two modes available, you have to choose between choppy motion and flicker. I'd choose the former every time.
Personally, I haven't noticed any significant judder on my S60, but regardless of which settings I have used, including those in the Cinema mode, which are similar to David's, I have to agree with his assessment when it comes to flicker. I believe that source material has more impact on these anomalies, then small differences in calibration.
Ian
mailiang is offline
post #7507 of 7534 Old 01-04-2016, 12:55 PM
MJ DOOM's Avatar
Quoted: 18 Post(s)
TV crapped out. 65 inch. Square Trade is reimbursing me full price. Is this thing worth anything or worth saving or should I just throw it in the garbage.
ID:	1161450   Click image for larger version
ID:	1161458   Click image for larger version
I unfold the scroll, plant seeds to stampede the globe
When I'm deceased, by then the beast arise like yeast
to conquer peace leaving savages to roam in the streets.
MJ DOOM is offline
post #7508 of 7534 Old 01-05-2016, 07:27 AM
Cravit8's Avatar
Quoted: 1149 Post(s)
Liked: 610
Probably $300 in parts if you have the time and storage.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #7509 of 7534 Old 01-05-2016, 10:51 AM
RWetmore's Avatar
Quoted: 287 Post(s)
Liked: 167
I would definitely get it repaired if possible. Plasmas are no longer being made, and the amount you'll have to spend for comparable picture quality is several thousand at least.
mailiang likes this.
RWetmore is offline
post #7510 of 7534 Old 01-05-2016, 12:05 PM
Cravit8's Avatar
Liked: 610
Well, if it's just the board, yeah that could be replaced likely, but if it's the panel...you're telling me you'd pay to have the panel replaced which certainly would be same as the original TV price.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #7511 of 7534 Old 01-05-2016, 01:14 PM
RWetmore's Avatar
Quoted: 287 Post(s)
Liked: 167
I probably would, yes. This set is just that good. It probably is just a board or perhaps even a faulty connection somewhere (if you're lucky).
RWetmore is offline
post #7512 of 7534 Old 01-05-2016, 01:27 PM
Cravit8's Avatar
Liked: 610
Absolutely could be a faulty connection, extremely rare, but possible, more so if someone lives in colder weather. I'll always be surprised at how a device can fault from a connection that seemed fine for years.
Unless there was one nearby that I could pickup, I wouldn't replace the panel though, but that's just me.
I'm not going to search out of curiosity but I would be extremely surprised to even find one available. Panasonic isn't stocking them as far as I know.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #7513 of 7534 Old 01-05-2016, 02:01 PM
mailiang's Avatar
Quoted: 685 Post(s)
Liked: 502
If it's the panel, you're out of luck. You may want to have a tech look at the set.
Ian
mailiang is offline
post #7514 of 7534 Old 01-05-2016, 03:55 PM
RWetmore's Avatar
Quoted: 287 Post(s)
Liked: 167
Yes, if it's the panel you may be out of luck. It probably isn't the panel though, and might only be a simple fix.
RWetmore is offline
post #7515 of 7534 Old 01-05-2016, 05:41 PM
MJ DOOM's Avatar
Quoted: 18 Post(s)
The TV is in my basement, gets cold down there with the vents closed. Could be a connection fault or the panel. What would I check if its a connection fault?
MJ DOOM is offline
post #7516 of 7534 Old 01-05-2016, 07:08 PM
dsettlemoir's Avatar
I recently had a lightning strike near me/power surge that killed my antenna input and Ethernet/wireless connection. HDMI still works. Last year about this time my daughter cracked the screen, so I guess it's time to replace my 50". I've been holding out for an reasonably priced HDR set.
dsettlemoir is offline
post #7517 of 7534 Old 01-06-2016, 11:17 AM
mailiang's Avatar
Quoted: 685 Post(s)
Liked: 502
Post
Heat has much more impact on electronics then cold. Unless your basement is very damp, the cooler temperatures shouldn't even be an issue. A bad or lose cable or faulty board can also be the cause of your problem. IMO, since you received re-reimbursement, it pays to at least have a qualified tech to check out.
Ian
MJ DOOM likes this.
mailiang is offline
post #7518 of 7534 Old 01-06-2016, 11:28 AM
Cravit8's Avatar
Liked: 610
I don't disagree with Ian on about the heat part, but coldness makes things contract, so if 2 connections are not inserted fully, the 2 wires contracting back could be enough to remove that copper to copper connection.
That really is a long shot. Open the case and give it a visual inspection. If you don't see something, than a capacitor blew, a board went out, or the panel is broken.
I can't believe I didn't pay for the square trade warranty for mine, stupid younger me.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #7519 of 7534 Old 01-24-2016, 04:05 PM
djPerfectTrip's Avatar
Liked: 29
I just bought an indoor antenna that is just a coax, was wondering if there was a way to get the audio to my AVR. Can't seem to figure it out...I'm not seeing any options on which output to use. Currently have an HDMI on HDMI2.
I thin I figured it out, using the digital audio out option. Just not sure if I'm going to be able to get to it since my TV is mounted...bah.
Turn it up!
djPerfectTrip is offline
post #7520 of 7534 Old 01-24-2016, 04:11 PM
dmtaub's Avatar
Quoted: 100 Post(s)
Liked: 34
Optical out of the tv to optical in of the AVR. That should get you sound.
dmtaub is offline
post #7521 of 7534 Old 01-24-2016, 07:28 PM
Liked: 29
Yep, I was able to get to it. Thank you
Turn it up!
post #7522 of 7534 Old 01-27-2016, 06:10 PM
FernandoRocker's Avatar
Quoted: 22 Post(s)
Is your Netflix app working on your sets? Mine hasn't worked since 4 months (I think)... I have a TC-P50S60.
FernandoRocker is offline
post #7523 of 7534 Old 01-27-2016, 08:16 PM
mailiang's Avatar
Quoted: 685 Post(s)
Liked: 502
Thumbs up
Yep. Like a charm.
Ian
mailiang is offline
post #7524 of 7534 Old 01-29-2016, 02:32 PM
Cravit8's Avatar
Liked: 610
Like a year ago someone else also had a netflix problem. You'll have to search this thread for keywords and sift though them; I think the solution was posted.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #7525 of 7534 Old 02-03-2016, 09:48 PM
darko313's Avatar
So I went out and got a colorimeter, the i1 Display Pro. I'm using DisplayCal 3.1
Here's what I'm aiming for right now:
Pre calibration wb RGB adjustments for balancing the color temp
Gamma TV setting: 2.2
Target gamma: bt 1886
HDMI range: Full
Color temp: D65 target (warm 2 on tv)
Mode: Custom
Target lumens: 120
1080p pixel direct: enabled
I haven't noticed any issues with this setup yet. Just keep in mind the screen will burn in you're careless.
darko313 is offline
post #7526 of 7534 Old 02-17-2016, 03:58 AM
Greatestalltime's Avatar
Ok. I had a problem with my 65s60 and have lost all the calibration settings I had and loved. I'm pretty sure they were from Fairchild99. I searched, clicked on the link in his sig and nothing relatable comes up.
When I first came back to this site I was on some unusable unreadable "enhanced version". I switched to mobile and it was better but, I still cannot get to the content is used to find and navigate through so easily. I'm stupid obviously but, is there also an issue with the site.
I've read through about 60 pages and when I get to Fairchilds latest settings they aren't in the post. Rather, tells me to click on his sig. In mobile version this doesn't do anything. In desktop it takes me to page 130 and there is no post by him on that page.
Any help would be greatly appreciated.
Greatestalltime is offline
post #7527 of 7534 Old 02-17-2016, 03:58 AM
post #7528 of 7534 Old 02-17-2016, 05:11 AM
I found this table. Is it current ? It was on about page 200.
http://www.avsforum.com/attachments/75008
post #7529 of 7534 Old 02-17-2016, 05:11 AM
post #7530 of 7534 Old 02-17-2016, 09:17 AM
foghorn2's Avatar
Quoted: 54 Post(s)
Liked: 31
Like you said, this site is so hard to navigate now with Huddler, most have gone away, its a ghost town.
..his mind is not for rent
to any god or government - Peart and Dubois
..I will save you everyone, and you can pay me
when I'm done - Stuart Adamson
foghorn2 is online now
Panasonic Tc P65s60 65 Inch 1080p 600hz Plasma Hdtv , Panasonic 60 Inch Plasma Hdtv Tc P60s60 , Panasonic Tc P55s60 55 Inch 1080p 600hz Plasma Hdtv , Panasonic Tc P50s60 50 Inch Plasma Hdtv , Panasonic 42 Inch Plasma Hdtv Tc P42s60
taboola here
