Official Panasonic S60 Series Discussion Thread - Page 253 - AVS Forum | Home Theater Discussions And Reviews
 115Likes
post #7561 of 7584 Old 11-19-2016, 08:41 PM
Steakfest's Avatar
Originally Posted by Steakfest View Post
The firmware is being upgraded now. I'll report back if there is any difference.
Don't see any new options in the settings or any difference in how the gameplay looks with the new firmware installed.
/John
Steakfest is offline
post #7562 of 7584 Old 11-19-2016, 08:49 PM
mailiang's Avatar
Quoted: 908 Post(s)
Liked: 607
/John
Like I posted, I don't believe it's a firmware issue with the set. Does it only have this problem with games? If so, it may be the console or related hardware.
Ian
Steakfest likes this.
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #7563 of 7584 Old 11-19-2016, 09:36 PM
Steakfest's Avatar
Ian,
I found another thread on this site that starts with a really good description of what I'm seeing.
30fps gaming at 60hz and the effects of frame doubling?
Definitely seems like an issue that appears when dealing with 30fps content on a 60hz display. What is still left to be determined is whether or not the "frame doubling" is caused by the source or the way the TV processes the 30fps content to display on the 60Hz display.
I just don't know enough about how the signal over HDMI works to even begin to guess what is going on. If anything I'm getting the impression that the 30vs.60 thing has been around for a long time, but was less noticeable on earlier flat panel technology, and the high quality of Plasma actually makes it MORE visible, and that's partly my problem.
Question about the S60 series now... Does it have a setting that is meant to make motion look smooth? I swear over the last couple of days, I've played with every setting in all the menus, but I don't think I yet found anything that helped make this issue less noticeable.
/John
post #7564 of 7584 Old 11-20-2016, 03:21 PM
mailiang's Avatar
Quoted: 908 Post(s)
Liked: 607
Question about the S60 series now... Does it have a setting that is meant to make motion look smooth? I swear over the last couple of days, I've played with every setting in all the menus, but I don't think I yet found anything that helped make this issue less noticeable./John
Some PDP's offer an optional 96hz setting which reduces judder, this feature is not available on the S60. Since I've yet to see any noticeable judder when watching most 24p content, it hasn't been an issue for me.
Ian
mailiang is offline
post #7565 of 7584 Old 12-11-2016, 03:47 PM
thesharkman's Avatar
Quoted: 32 Post(s)
well, ho ho ho, my house got a visit from the christmas thieves. one of the items they stole was the remote to my S60; i'm not sure why they stole it as it probably has zero use for them. is this the stock remote:
http://shop.panasonic.com/tvs/tv-acc...AYB000827.html
if not, can you one of you guys direct me to the correct, stock remote? thanks.....!
thesharkman
thesharkman is offline
post #7566 of 7584 Old 12-12-2016, 07:07 PM
RWetmore's Avatar
Quoted: 410 Post(s)
Liked: 218
Yes, that's it. Model # there matches mine exactly.
RWetmore is offline
post #7567 of 7584 Old 12-12-2016, 09:10 PM
Quoted: 32 Post(s)
thanks for the reply.....off to epay to pick one up.
thesharkman
post #7568 of 7584 Old 01-03-2017, 04:40 PM
ToonMasterTim's Avatar
Quoted: 117 Post(s)
Liked: 81
Is anyone else having problems getting Netflix to load on their S60/4?
ToonMasterTim is offline
post #7569 of 7584 Old 01-04-2017, 11:54 AM
mailiang's Avatar
Quoted: 908 Post(s)
Liked: 607
The smart app is antiquated and no longer supported. Get a Roku.
Ian
gomo657 likes this.
mailiang is offline
post #7570 of 7584 Old 01-04-2017, 01:10 PM
jasondjulian's Avatar
Quoted: 50 Post(s)
Liked: 89
Ian
I use my Sony S-5100, it was always faster to load anyhow.
Panasonic TC-P55S60
Sony S5100 BD-Player
Sony HT-XT1 Sound Base
jasondjulian is offline
post #7571 of 7584 Old 01-04-2017, 02:10 PM
ota.dt.man's Avatar
Please see this new Viera DAC thread:
http://www.avsforum.com/forum/167-plasma-flat-panel-displays/2702081-recommended-5-1-optical-2-0-1-rca-dac.html#post49545569
THANKS
ota.dt.man is offline
post #7572 of 7584 Old 01-04-2017, 07:58 PM
RWetmore's Avatar
Quoted: 410 Post(s)
Liked: 218
I used Netflix just the other day. The app works fine on mine. So does Amazon.
RWetmore is offline
post #7573 of 7584 Old 01-05-2017, 01:01 PM
Quoted: 117 Post(s)
Liked: 81
Ah, I wondered if Netflix might have stopped supporting it. I have other devices that support Netflix anyway, so I can just use those.
post #7574 of 7584 Old 01-05-2017, 03:15 PM
mailiang's Avatar
Quoted: 908 Post(s)
Liked: 607
Post
Panasonic no loner supports it. The Netflix interface should work OK, but it's a dated version.
Ian
mailiang is offline
post #7575 of 7584 Old 01-07-2017, 05:38 AM
Quoted: 117 Post(s)
Liked: 81
I'm confused. Well, either way, it won't load. It tries to load. It has been the older Netflix UI for a while, but navigation was responsive and it ramped up to full HD quickly, so I would often use it. All I wondered is whether other S60/4 owners were having the same issue with getting Netflix to load. I understand that Panasonic, like other manufacturers, will basically stop updating the TV apps after the year the TV is released. That isn't news to me. So, from that perspective, Panasonic hasn't 'supported' it for years. But it has been working. So I suspected Netflix might have dropped support for the older UI. The S64 is the only device I own still using the older UI. Even my 2013 Samsung BD player has the new UI, but navigation and loading can be very slow, however, it works.
post #7576 of 7584 Old 01-07-2017, 09:06 AM
mailiang's Avatar
Quoted: 908 Post(s)
Liked: 607
I have four Roku's and my oldest one is a Roku 2 HD from 2011. I use it on my kitchen TV and it has one of the original Netflix interfaces that Roku's older software couldn't update. It doesn't even support Dolby 5.1 and it still works like a charm. I seriously doubt the problem lies with the Netflix interface. I'm now using a Roku 3600R stick with a quad core processor with my S60 through my Pioneer receiver's HDMI input and it loads very fast and since it's a stick, you don't even know it's there. IMO, it offers the best bang for the buck.
Ian
mailiang is offline
post #7577 of 7584 Old 01-07-2017, 09:31 AM
HD KOOL-AID's Avatar
Quoted: 65 Post(s)
Liked: 32
Try pulling the power cord off next time the Netflix app locks up wait 10 seconds power it up again and reload app should work. Tried this on my gt50 with success.
HD KOOL-AID is offline
post #7578 of 7584 Old 01-08-2017, 03:15 AM
Quoted: 117 Post(s)
Liked: 81
Last night the app started working again. I used it to watch Netflix content without issue. Strange. As the issue of not loading the app persisted for a few days. The TV is plugged into my router, not wireless, and there have been no connectivity issues. Just a fluke, I guess.
post #7579 of 7584 Old 01-08-2017, 09:16 AM
mailiang's Avatar
Quoted: 908 Post(s)
Liked: 607
I found the Netflix app on the S60 to be quirky. Most 'smart devices' are lacking in terms of performance when compared to out-board players. Glad you got it working.
Ian
mailiang is offline
post #7580 of 7584 Old 07-18-2017, 05:09 AM
Noodles3's Avatar
So I just got a P50S60 from a friend for free. It works but needs a new A Board due to the HDMI ports being fried. I'm curious though TXN/A1USUUS TNPH1046UB is the part number but when looking online there are some that look just like it with part numbers like TNPH1046 (1)A since it's printed on the board but say it came from an S64 model but looks the same.
Others I've seen look the same and say they are A1USUUS TNPH1046UE and not UB
Does anyone know if there are boards from other models that will interchange with this? It looks like the UC and UE part numbers are from the S60 series just the other sizes.
Noodles3 is offline
post #7581 of 7584 Old 07-18-2017, 12:15 PM
mailiang's Avatar
Quoted: 908 Post(s)
Liked: 607
Lightbulb
The S64 is identical to the S60 except for the panel's AR filter.
Ian
Noodles3 likes this.
mailiang is offline
post #7582 of 7584 Old 07-18-2017, 12:30 PM
Noodles3's Avatar
Ian
So any of the A Board models from any size S60 or S64 should work with the P50S60 if I'm reading this correctly.
Noodles3 is offline
post #7583 of 7584 Old 07-18-2017, 03:10 PM
mailiang's Avatar
Quoted: 908 Post(s)
Liked: 607
You would think. Also check Sears: http://www.searspartsdirect.com/model-number/TCP50S60
Ian
mailiang is offline
post #7584 of 7584 Old 07-22-2017, 08:00 PM
Superdog's Avatar
Just had a panel failure on mine, 65S60 (chip on ribbon cable). Fortunately, the section I lost is at the very right side of the screen (~3" or so), so can still watch it for now. Will be watching OLED prices for a while.
Superdog is offline
Panasonic Tc P65s60 65 Inch 1080p 600hz Plasma Hdtv , Panasonic 60 Inch Plasma Hdtv Tc P60s60 , Panasonic Tc P55s60 55 Inch 1080p 600hz Plasma Hdtv , Panasonic Tc P50s60 50 Inch Plasma Hdtv , Panasonic 42 Inch Plasma Hdtv Tc P42s60
