Official Panasonic S60 Series Discussion Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 115Likes
post #61 of 7583 Old 03-11-2013, 06:57 PM
benareeno's Avatar
Quoted: 18 Post(s)
i just bought the ut50...and while it has a "good" picture...there are still some otherwise annoying parts of the picture. I'll be returning it...
I see above that the poster mentions that the S60 is better than st50 because it's brighter.
If anything...with increased brightness, I see increased noise and grain in the picture. It's really the only downfall of plasma...it's too damn noisy!
solution for me would likely be a 42" set...so the noise is less visible.
One other note...big, closeup faces don't have enough contour or color to give a sense of reality. They look too much like one color...
any change in either of these regards?
Ben
benareeno is offline
post #62 of 7583 Old 03-11-2013, 08:00 PM
Widmark's Avatar
Originally Posted by rnab32 View Post
I know the S60 has wireless LAN, can anyone confirm this means we'll have access to apps such as Netflix through the tv?
All the online marketing makes it clear that while it doesn't have the full "my homepage" and web browser, it has access to the basic streaming services like Netflix. I think I'll be getting a blu-ray player as well so that would cover that in any case.
Widmark is offline
post #63 of 7583 Old 03-11-2013, 09:17 PM
rnab32's Avatar
Good to know...thanks. Netflix is all I care for, oh and HBO GO if they ever make that available.
rnab32 is offline
post #64 of 7583 Old 03-12-2013, 09:27 AM
trp3383's Avatar
Quoted: 59 Post(s)
Decisions decisions... I currently have a 55st30 which is great. I sometimes use 3d but not often. I'm looking to upgrade. Is a 55s60 going to be an actual upgrade? Panasonic has them for 850 through epp. And if the s60 is better then my st30 should I just go for a 60s60 for 1100? Again 3d isn't a big factor, I usually just watch sports and blu ray. Thanks
trp3383 is offline
post #65 of 7583 Old 03-12-2013, 09:37 AM
Leon!'s Avatar
Liked: 35
An s60, from an ST50?! No way would i downgrade models just for one year newer. Putting aside panel class, aren't you losing the st's glare filter too?
edit, sorry misread st30. Still unless that was a generation with floating blacks or fluctuating brightness or you had some problem with it & you had to, I wouldn't go ST to S.
Leon! is offline
post #66 of 7583 Old 03-12-2013, 09:40 AM
Bond 007's Avatar
Quoted: 2312 Post(s)
Liked: 1871
He never mentioned an ST50.
No, Mr. Bond. I expect you to die!
Bond 007 is online now
post #67 of 7583 Old 03-12-2013, 09:44 AM
trp3383's Avatar
Quoted: 59 Post(s)
I'm just asking pq wise. It's 2 models behind. Would the blacks and color accuracy be better?
trp3383 is offline
post #68 of 7583 Old 03-12-2013, 09:49 AM
Leon!'s Avatar
Liked: 35
Probably. Don't you have the anti glare filter on your st30 though? s60 is like the u series in that regard, & the lower grade panel.
Leon! is offline
post #69 of 7583 Old 03-12-2013, 09:57 AM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Do you have a light controlled room? If so the lack of filter on the S60 won't matter to you. Other than that, I believe that there would be noticeable improvements for you.
Edit: Also, I bet that 55" has shrunk since you first bought it. 60" with HD signal will be sweet. wink.gif
sheshechic is offline
post #70 of 7583 Old 03-12-2013, 10:07 AM
trp3383's Avatar
Quoted: 59 Post(s)
My room does have 3 windows and a door but i can control the light. That's my feeling on the size. 60 would be $1180 shipped for the 60s60 and $1360 for the 55st60.......
trp3383 is offline
post #71 of 7583 Old 03-12-2013, 10:13 AM
fairchild99's Avatar
Liked: 151
I'm also torn I wanted to try out 3D but I only have a single blu-ray which came with a 3D disc (Prometheus) and aside from that no other content, but there is the potentially better panel on the ST60 (anti-glare filter, better motion from the 2500 Focused field drive and the 3D)
Biggest I can go is 50" and I would be going from a 42" S2 Panasonic to a 50" S60 or 50" ST60.
Anybody know if the 2500 Focused field drive is something that's always on or something that has to be enabled similair to my S2 with Blur Reduction. (basically it was advertised as having 1100 lines of motion resolution vs 900 for the lesser models but I don't run with it on anyway so it's a feature I don't even use)
Sony 32" EX400 calibrated settings
Panasonic 50" S60 calibrated settings
HTPC/Sony S5100 to Sony HT-CT660 to Panasonic 55" VT60, Sony 32" EX400, Panasonic 50" S60
fairchild99 is offline
post #72 of 7583 Old 03-12-2013, 10:26 AM
Bond 007's Avatar
Liked: 1871
Are you saying that the st costs more than the s? I am confused by your post.
post #73 of 7583 Old 03-12-2013, 10:28 AM
Leon!'s Avatar
Liked: 35
Looks like you did have the glare filter on the st30 btw, so depending on how much light, controlling the glare might be a different task with s60. But even then, there were some viewers who claimed to prefer the look of the U50 without the filter vs. those with. So as said might not be a problem for you.
Guys what practical differences if any do "shades of gradation" make?
st30 6,144
s60 6,144
st50 12,288
st60 12,288
Either way with that little of a price difference, 60 vs. 60", I'd go st60.
Leon! is offline
post #74 of 7583 Old 03-12-2013, 10:34 AM
Bond 007's Avatar
Liked: 1871
So, there is an S60 and an ST60. Thats where I was getting confused.
sheshechic likes this.
post #75 of 7583 Old 03-12-2013, 10:44 AM
trp3383's Avatar
Quoted: 59 Post(s)
That price was a 55st60. A 60 would be $1550.
trp3383 is offline
post #76 of 7583 Old 03-12-2013, 11:00 AM
chunon's Avatar
Quoted: 1821 Post(s)
Liked: 1600
st30 6,144
s60 6,144
st50 12,288
st60 12,288
IMO that shades of gradation makes little to no differrence in picture quality more of a marketing tool
65C6 OLED
Time Warner Cable/Oppo 203/ Sony XT1 Soundbase/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #77 of 7583 Old 03-12-2013, 11:03 AM
Leon!'s Avatar
Liked: 35
^thanks, figured as much.
Sorry misread your model no.'s again trp, that is a more sizeable jump in price. Either way i just don't see why, if not significantly better & bigger. Unless there are complaints with your st30.
Leon! is offline
post #78 of 7583 Old 03-12-2013, 11:07 AM
trp3383's Avatar
Quoted: 59 Post(s)
I'm just picky and want the newest stuff. No complaints. Blacks could be better
trp3383 is offline
post #79 of 7583 Old 03-12-2013, 11:12 AM
chunon's Avatar
Liked: 1600
I have the St30 also good set but yes the blacks will be better and the contrast ratio, color accuracy. The ST30 is no dog but it doesnt measure up to the 2012 models. I am getting a VT50 delivered tomorrow. Those ST60 prices are great imo even if it is no better than the ST50.
65C6 OLED
chunon is offline
post #80 of 7583 Old 03-12-2013, 11:48 AM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Another point regarding S60 vs ST30 is that it won't have the floating blacks or fluctuating brightness issues either.
post #81 of 7583 Old 03-12-2013, 12:24 PM
chunon's Avatar
Liked: 1600
ST30 doesn't have floating blacks that was fixed in 2011 and the Fbr was fixed via firmware update
65C6 OLED
chunon is offline
post #82 of 7583 Old 03-12-2013, 01:38 PM
superbooga's Avatar
Actually the increased shades of graduation do reduce the amount of dithering, but it only works when set in Cinema mode. Cinema mode has significantly worse black levels than the other modes, so it actually makes zero difference for the majority of users, who use the other modes.
superbooga is offline
post #83 of 7583 Old 03-12-2013, 02:10 PM
chunon's Avatar
Liked: 1600
Interesting and hdant heard about the black levels is that all 2012s?
65C6 OLED
chunon is offline
post #84 of 7583 Old 03-12-2013, 05:07 PM
Lestat Phoenix's Avatar
The S60 has a very small difference in black level for the better than the ST from last year...
The scariest words in the English language are:
"Hello, we're from the government, and we're here to help."
PS3 HDMI 1.4
GT50 3D 1080p Plasma HDTV
10' 1080P@60
Lestat Phoenix is offline
post #85 of 7583 Old 03-12-2013, 06:32 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Good news!
post #86 of 7583 Old 03-12-2013, 06:33 PM
sheshechic's Avatar
Quoted: 55 Post(s)
Liked: 96
Who has measured the S60?
post #87 of 7583 Old 03-12-2013, 06:55 PM
hotskins's Avatar
Quoted: 60 Post(s)
Liked: 68
He has both Tvs
hotskins is offline
post #88 of 7583 Old 03-12-2013, 07:34 PM
Widmark's Avatar
I really really want to buy a 42s60, right now, I just cannot get a straight answer about motion smoothing! I've been told "it can be turned off" but I've read the entire eHelp document, which far as I understand is the manual for all the features, including the advanced picture adjustments, and there is no mention. Can somebody please allay my fears here?
Widmark is offline
post #89 of 7583 Old 03-12-2013, 07:38 PM
Latinoheat's Avatar
Quoted: 1046 Post(s)
Liked: 792
You can always turn it off, it has different settings, weak,medium,strong or off. Why don't you just go to the audio video store and check it for yourself.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #90 of 7583 Old 03-12-2013, 08:15 PM
Widmark's Avatar
Because the Best Buy near me doesn't have any S60s and because according to it's manual, it doesn't even exist. There is no mention anywhere in it's help that even suggests it exists and can be changed. Every other detail is laid out in the eHelp. 24p Direct in, 3:2 pulldown etc. No mention of IFC at all.
Widmark is offline
Panasonic Tc P65s60 65 Inch 1080p 600hz Plasma Hdtv , Panasonic 60 Inch Plasma Hdtv Tc P60s60 , Panasonic Tc P55s60 55 Inch 1080p 600hz Plasma Hdtv , Panasonic Tc P50s60 50 Inch Plasma Hdtv , Panasonic 42 Inch Plasma Hdtv Tc P42s60
