60GT50, Need Help Please! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-02-2013, 04:16 PM - Thread Starter
sjturbo's Avatar
I recently picked up a new TC-P60GT50 which I think I love. however... I think my daughter or grand daughter my have changed something in the setting of either the dish VIP722K or on the tv itself. The problem is the "format" seems somewhat distorted. The reason I believe this is that when I call up the "guide" on the sat. the ends of the script on each side are cut off and changing the format , ie. zoom, justify ect do not fix this. Can anyone understand and remedy the issue?
sjturbo is offline
post #2 of 4 Old 03-02-2013, 07:03 PM
Ph8te's Avatar
Quoted: 4545 Post(s)
Liked: 3978
Have you tried hitting the "aspect" button on the remote? or going into the settings of the cable box to see what the settings are?
Ph8te is offline
post #3 of 4 Old 03-02-2013, 08:59 PM
Mangoes's Avatar
Same happened to me a few days ago.at the bottom of the dish remote, fit the format button. It is the same as the * button.
Mangoes is offline
post #4 of 4 Old 03-02-2013, 09:44 PM - Thread Starter
sjturbo's Avatar
Thanks much for input. Neighbor came by for bball game and showed me the correct aspect setting.
sjturbo is offline
