Best ~42" plasmas? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-03-2013, 10:53 PM - Thread Starter
doublemazaa's Avatar
What are the favorite 42" plasma these days? I know the smaller panels aren't as good as the 50" inch panels, but are there some recommended 42" sets?
doublemazaa is offline
post #2 of 8 Old 03-03-2013, 11:30 PM
benareeno's Avatar
Quoted: 21 Post(s)
It likely starts and ends with the Panny ut50...
I'm really hoping for a higher end 42" in 2013 though...it could allow for the best pic quality of any display as it would likely be brighter and punchier than its 50"+ counterparts.
benareeno is offline
post #3 of 8 Old 03-03-2013, 11:55 PM
dabsac's Avatar
Quoted: 29 Post(s)
Liked: 24
I have a Samsung pn43e450 in the bedroom and the picture quality is very good. Only 720p though.
dabsac is offline
post #4 of 8 Old 03-04-2013, 06:00 AM
Ph8te's Avatar
Quoted: 4802 Post(s)
Liked: 4347
THe only announced 42" for 2013 is the S series from Panasonic I believe.....So your choice will be limited if you decide to go the Plasma route and need a TV that size....
Ph8te is online now
post #5 of 8 Old 03-04-2013, 06:49 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 526 Post(s)
Liked: 781
Panasonic is releasing two new 42" models in early March - the TC-P42X60 ("720p"), and TC-P42S60 (1080p).
http://www.avsforum.com/t/1461177/official-panasonic-s60-series-discussion-thread
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #6 of 8 Old 03-04-2013, 01:05 PM
davelanger's Avatar
You can barely tell the difference between 1080 and 720 at 42 inches though right?
davelanger is offline
post #7 of 8 Old 03-04-2013, 01:11 PM
dabsac's Avatar
Quoted: 29 Post(s)
Liked: 24
Yeah I've heard at less than 50 inches you can't see the difference.
dabsac is offline
post #8 of 8 Old 03-04-2013, 01:33 PM
whipit's Avatar
Quoted: 101 Post(s)
Liked: 86
On a 42" I can see the difference at about 7-8 ft. They have rectangular pixels and the screen door effect is enough for me not to want a 720p. I'd suggest the 42S60(1080p) when it comes out. When they come out go take a look for yourself and see, ymmv.
whipit is offline
