Problem with New Panasonic VIERA TC-P55VT50 55-Inch Plasma TV - AVS Forum | Home Theater Discussions And Reviews
Old 03-04-2013, 07:35 PM - Thread Starter
cjejgd's Avatar
I just purchased a new Panasonic VIERA TC-P55VT50 55-Inch Plasma TV. It has a thin blue line on the left edge (facing tv). Is there a problem and do I need to calibrate to fix??? do i need to return?
thanks
cjejgd is offline
Old 03-04-2013, 08:26 PM
highdefav1's Avatar
Quoted: 106 Post(s)
Liked: 37
Does it remain no matter which source you are using? If using HD TV source, does it remain on every channel?
Can you snap a pic and post?
Panasonic 55ST50
Yamaha RX-V673
Klipsch RF-52 II // RC-52 II // RS-42 II
Klipsch RW-12d
Klipsch KG 2.5
highdefav1 is offline
Old 03-09-2013, 03:21 PM - Thread Starter
cjejgd's Avatar
Ho Thanks. Actually, it is only when we are using the THX picture feed. It isn't there for any other feed.. so I'm thinking that when I'm viewing a DVD it will be gone. I haven't had time to try that yet..
cjejgd is offline
Panasonic Viera Tc P55vt50
