TC-P65VT50 wall mounted dimensions, and mount locations...? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-07-2013, 03:06 PM - Thread Starter
ejsg19's Avatar
I have a VT50 on the way from Pauls, and would like to get the wall mount installed correctly, prior to the TV being delivered.
I can't seem to find any information on where the bolt holes on the back of the TV are located on this model. This would tell me how high on the wall to put the wall mount. I asked a guy at Pauls, and his answer to all this was "they are on the bottom." Not quite the answer I was looking for, in terms of being precise.
I have just under 8' ceilings in that room, and a 36'' tv stand, as well as leaving room somewhere on the stand or wall for a Infinity Primus center speaker http://www.amazon.com/gp/product/B0044D1788/ref=oh_details_o00_s05_i00?ie=UTF8&psc=1
I know the tv is approx 5' wide and 3' tall, so a 3' tall tv and a 3' tall tv stand, and a 10'' tall speaker, doesn't leave a ton of room for error, or just as bad the mount is too high, and the ceiling interferes.
Can anyone point me to some accurate dimension numbers, so I know where to locate the wall mount?
(this way maybe I can convince the delivery guys to help me put the tv on the mount, vs having to do it by myself.
ejsg19 is offline
post #2 of 5 Old 03-07-2013, 04:08 PM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 499 Post(s)
Liked: 766
Originally Posted by ejsg19 View Post
I have a VT50 on the way from Pauls....I can't seem to find any information on where the bolt holes on the back of the TV are located on this model....Can anyone point me to some accurate dimension numbers, so I know where to locate the wall mount?
See the VT50 Quick Start Guide linked in the 2nd post of the 2012 Lineup Thread - it has detailed schematics. Just be sure you're looking at the 65" diagram, not the 55" or 60" one:
http://www.avsforum.com/t/1386141/official-panasonic-2012-lineup-and-information-thread-no-price-talk
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 5 Old 03-07-2013, 07:23 PM
highdefav1's Avatar
Quoted: 106 Post(s)
Liked: 37
I would recommend waiting until the display arrives. Maybe offer the guys $30 or $40 a piece to help you mount the set. It would be a shame to install the mount first and find out you were off.
It doesn't take much more than 10-15 minutes in install the mount and hang the display. Have the guys hold the set up so you can gauge the approximate location, then install your wall plate in the correct location, install the rails on the back of the set, hook up your cables and your good to go.
Really, you're only having the guys hold up the set to gauge your position for the wall mount and then having them put it on the wall mount once the rails are on.
Or if not, don't you have a nearby friend that can help mount the set?
Panasonic 55ST50
Yamaha RX-V673
Klipsch RF-52 II // RC-52 II // RS-42 II
Klipsch RW-12d
Klipsch KG 2.5
highdefav1 is offline
post #4 of 5 Old 03-07-2013, 07:45 PM
"Don't PM Me Bro"
Quoted: 499 Post(s)
Liked: 766
The delivery service Paul's uses probably won't wait for all that, and may even be in a time crunch and not have the time to stick around even with the offer of that huge tip.
Heck, for five bucks you can enlist the help of a 12 year old neighbor kid to help lift the TV onto the wall bracket, there no need to spend more for an adult to help wink.gif
Randy
post #5 of 5 Old 03-11-2013, 02:15 PM - Thread Starter
ejsg19's Avatar
Thanks Randy,
Not precise measurements, but I think with a margin of error of 2-3 inches, I can get this figured out now.
Thanks again,
Eric
ejsg19 is offline
