Small cloud on screen of my 65VT - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-12-2013, 05:34 PM - Thread Starter
Mulla711's Avatar
My 65VT has small faint white cloud about the size of a dime on the right lower side. It shows even with the set turned off. Ran the white IR bar also. Its still there frown.gif. Have had the set for 1.5 months . Any thoughts about what it may be? Dam its feels like when one of my kids get ill !
Mulla711 is offline
post #2 of 7 Old 03-12-2013, 05:39 PM
Latinoheat's Avatar
Quoted: 1157 Post(s)
Liked: 958
You don't happen to have windows behind your plasma do you? Apperantly someone else had the sun coming in from behind and didn't close the blinds and that's what he was seeing. White dots even when it was off, if you do shut your blinds and see, just a suggestion.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, HTPC, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC,Klipsch Reference R-62II,Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #3 of 7 Old 03-12-2013, 05:55 PM - Thread Starter
Mulla711's Avatar
Ill be damed !!...I do have mini blinds behind the set. I turned them up to refect the light up. Its gone now smile.gif Is it because the light got through the vent holes in back of the set and is about where the small cloud was? I hope this was the case. thank you..
Mulla711 is offline
post #4 of 7 Old 03-12-2013, 05:57 PM
merccrazy's Avatar
Quoted: 13 Post(s)
Does it look like this? 552.jpg 18k .jpg file
merccrazy is offline
post #5 of 7 Old 03-12-2013, 06:00 PM - Thread Starter
Mulla711's Avatar
Merccrazy,
it was very faint how do i explaine it? a soft night light? but could see it with set on or off..gone now smile.gif
Mulla711 is offline
post #6 of 7 Old 03-12-2013, 06:38 PM
merccrazy's Avatar
Quoted: 13 Post(s)
Good then it was probably the light entering from the back. The picture I posted are finger prints on the plasma screen.eek.gif The front glass had to be removed to clean them off. Your lucky.
post #7 of 7 Old 03-12-2013, 06:57 PM
Latinoheat's Avatar
Liked: 958
Awesome, glad I could help.:wink.gif
