Official Samsung PNxxF8500 Series Discussion Thread [No Street Price Talk] - Page 109 - AVS Forum | Home Theater Discussions And Reviews
 203Likes
Old 04-21-2013, 04:37 AM
buzzard767's Avatar
Quoted: 1618 Post(s)
Liked: 2393
Originally Posted by jackobots View Post
There is a hockey game on NBCSHD my fellow floridaman, That would be the perfect way to be sure the pop's are gone. If you know of a good calibrator on the southwest coast of Florida, please don't be shy : )
Originally Posted by Ken Ross View Post
That's key Floridaman! We now have a couple of professionally calibrated Cal Day modes that eliminate popping. I'm glad Robert and I weren't crazy
Let's get three. Where are you located, jackobots?
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
Old 04-21-2013, 05:38 AM
jackobots's Avatar
I'm about 45 minutes south of Sarasota and 45 minutes north of Fort Myers, in a town called Port Charlotte. I'll soon be moving closer to Sarasota but, for now, I'm here. The only source for a calibrator in my town is Best Buy and it's not a Magnolia. Port Charlotte is definitely not a high tech town, so I'm concerned they may not be very good. We do have a lot of great fishing guides here though : )
Thanks for any help you can provide!
jackobots is offline
mcv83's Avatar
Hi. I'm about to get my ps64f8500 in May and I'wondering something : for the program suggestions system, will it work if I use a stb and not the integrated tuner?
By the way will the vocal command like "channel 4" will work also thanks to the external IR module?
Hope I'm clear ;-)
Thanks for your answers.
mcv83 is offline
Old 04-21-2013, 06:21 AM
JRWalker's Avatar
Quoted: 40 Post(s)
Liked: 54
Originally Posted by JimShaw View Post
JR, I thank you a great post that helps with the problem that I will have placing a 64F8500 in a cabinet.
It looks like it will work but as you said, I will have to keep an eye on the temperature. I would set it up for if a fan shut down, a small red light would go on. That light would be in a spot where it would be visible.
A binary indicator is one way to go. Did a little searching and found the Extech 401012 Indoor/Outdoor Temperature Alarm that you should consider.
Have updated my post as shown below:
"Putting any electronic device in a cabinet make me very nervous. If the fans speeds are set for silent operation you would have no indication of fan failure(s) or loss of power to one or more fans. A quick search for "temperature alarm" returns many choices. The Extech 401012 Indoor/Outdoor Temperature Alarm http://www.extech.com/testequipment/product.asp?catid=67&prodid=392 has colors that would go well with A/V equipment and is only about $20 on Amazon. The 10' temperature sensor could be placed inside the cabinet. You could then read your room and cabinet temperature from the display and have an audible alarm and Red/Green indicator for your set point."
JRWalker is offline
Old 04-21-2013, 06:41 AM
umr
umr's Avatar
Quoted: 39 Post(s)
Liked: 77
Well, I tried all the modes...it is not a severe issue. I think it can be solved with some tweaking of the white balance. It sounds like Elvamir's calibrator (Jeff Meier) did not have to do much more than adjust the white balance to get it calibrated perfectly. It's so close to perfect now, with my own tweaks, which do not include any adjustments to white balance, I can't imagine it needing any radical changes.
That is false. This is a very tricky set to get good color from. Just hitting white balance will not get you very close on flesh tones. I spent about 2.5 hours finessing this unit to get a quality image. White balance is only a part of it.
umr is offline
Old 04-21-2013, 07:05 AM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
sssssshhhh...I'm hoping it's just my incredible bad luck, and truly just an isolated event. I could handle this abl pop all day long compared to uniformity issues.
Habit Forming....Wallet Burning Hobby....55" Oled Lg B6p 55" Samsung B8500 Fald Channel Master Dvr+ Onkyo RZ900 avr Samsung K8500 UBR player Svs Ultra Towers/Center, Svs Satellite Surrounds Svs Pb-13 Ultra Sub
airgas1998 is offline
Old 04-21-2013, 07:14 AM
JRWalker's Avatar
Quoted: 40 Post(s)
Liked: 54
Originally Posted by Atlantaguy View Post
Cooler guys makes great A/V cabinet cooling solutions.
http://www.coolerguys.com/
I have the Coolerguys PRO-Metal Dual 120mm Deluxe Cabinet Cooling Kit with built-in LED Controller CABCOOL 1202-Deluxe-M and it works like a charm.
Thanks. I have updated http://www.avsforum.com/t/1463454/official-samsung-pnxxf8500-series-discussion-thread-no-street-price-talk/3200_100#post_23226905 with a link to your recommendation.
JRWalker is offline
Old 04-21-2013, 08:32 AM
bargervais's Avatar
Quoted: 1555 Post(s)
Liked: 923
Does anyone know the picture quality of the PN51F5500 compared to the PN51F8500 as I'm considering a less expensive model for the den as it's not my main viewing area
DEN Atmos Samsung UN65KS8000 Roku Ultra Onkyo TX-NR 747 5.2.2 UHD audio. Polk Audio OWM3 Speakers / top middle on Ceiling / 300MGB Spectrum / Samsung UBD-K8500 Blu-Ray Player / 26 UHD Blu-Rays Living Room Atmos Samsung PN60E8000+SEK2000 / Onkyo TX-NR 1030 7.2.4 /Onkyo M-5010 Amplifier for top middle/ 300MGB Spectrum / Panasonic 3D blu-ray Bic Acoustech speakers, MICCA M-8S FH on wall /TM in ceiling speakers / 2 Bic F12 subs. BEDROOM Samsung 55JS8500 using tv speakers for now
bargervais is offline
Old 04-21-2013, 09:04 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Originally Posted by Cleveland Plasma View Post
Edge lit technology is maxed out........
Funny, I was PM'd just last year that it is plasma tech that had reached its zenith. wink.gif
vinnie97 is offline
Old 04-21-2013, 09:29 AM - Thread Starter
Industry Insider
Cleveland Plasma's Avatar
Quoted: 1975 Post(s)
Liked: 2136
It is getting close also........
Cleveland Plasma is online now
Old 04-21-2013, 10:15 AM
jackobots's Avatar
Thanks...flesh tones is one area where there is definitely room for improvement. From what I've read, most calibrators are saying this is a tough set to calibrate, so hopefully I can find a really good one!
Old 04-21-2013, 10:20 AM
JimShaw's Avatar
Quoted: 277 Post(s)
Liked: 296
Very nice. That would work perfectly.
8.3 Surround, protected by APC H15
Speakers: SpeakerCraft: 6 AIM8 Fives & 2 TIME Fives used as Wides
Woofers: SVS PB13-Ultra (1), HSU MBM-12 MK2 (2)
Samsung UN78JS9500, mLG OLED55E6P
Oppo UHD-203 player, Denon 4311CI, Harmony 1100, Harmony Elite, 9 Noctua cooling fans
JimShaw is offline
Old 04-21-2013, 10:26 AM
JimShaw's Avatar
Quoted: 277 Post(s)
Liked: 296
Didn't the head of the Patent office in the late 1800's say that the Patent office was no longer needed and should be closed because everything has been invented?
m
JimShaw is offline
Old 04-21-2013, 10:27 AM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
i take it you have decided to keep it? i'm crossing fingers on my swap. this set certainly comes alive when the sun goes down.smile.gif
Old 04-21-2013, 10:31 AM
gmarceau's Avatar
Quoted: 22 Post(s)
Liked: 68
People forget this. There really isn't much to improve upon, especially since this set now has added brightness and improved clarity, in addition to contrast that is near reference. We've got sets this year that are pretty much equal to a 9G Kuro and we might be done with big improvements in picture quality.
There was a wall at Magnolia with the GT50, E8000 plasma and LED, and the new F8500. The biggest difference watching a feed between all of them was the brightness, with the F8500 having less abl than the other two plasmas, and being close in brightness to the LED.
The biggest difference people are noticing with the F8500 is brightness and the LED look to the picture, a crispness that is part of the new pixel structure. This is part of the reason why I'm more interested in this set than the Panasonics. Unless Panny changes the look of the image, something that really can't be measured with equipment, I'm not too interested in upgrading from a Pioneer. With Sammy, it's almost like I'm changing to an LED or an OLED because of the unique look to the image that it produces.
The most striking part of the ZT60 v. Kuro demo at the Panasonic event the other week was the difference in shades of gradation. It wasn't black level. That tells me that black level is almost maxed out, since anything above 0fL is going to have some slight glow to it, so it's almost irrelevant.
"If you weren't such an ignorant troll, you'd be adorable" -rogo
gmarceau is offline
Old 04-21-2013, 10:40 AM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
" LED look to the picture"-yes it does indeed.
Old 04-21-2013, 11:05 AM
jackobots's Avatar
Yep, I'm keeping it! I must say, after looking at so many other plasma's, this is the only one I'd pay big bucks for. The difference in picture quality between the ST60, the VT60, and even the LG 60" I saw at Sam's for $700, is minimal. It's hard to justify paying so much more for virtually the same picture. The F8500 is an obvious improvement, but you are not going to see much difference among other plasma's.
So, if I was going to give advice to those looking for a plasma, either go for the F8500 or look for a bargain. There are some great deals out there on very nice, big plasma's...and the detail, brightness and the whites are virtually the same on the lot of them...IMO : )
Old 04-21-2013, 11:11 AM
yamvmax's Avatar
Quoted: 47 Post(s)
Liked: 33
WOW! couldnt disagree more. There are big differences between bargain plasmas and the higher end models.
wattheF likes this.
yamvmax is offline
Old 04-21-2013, 11:32 AM
jackobots's Avatar
I agree with your statement, but I would replace the word "big" with "little" : )
Old 04-21-2013, 11:34 AM
ucsbrandall's Avatar
Hello All. Newbie here. So Best Buy messed up and gave me a crappy PN60E8000. Long story short I did my research and just had the PN60F8500 delivered. I was looking forward to all the dark blacks and crazy brightness. To be HONEST out of the box and on the wall it looks only slightly better than my e8000. Couple questions who is a Good guy in the Los Angeles area to get a proffesional calibration?? Second, I dont want to take any money out of these guys pockets,where can I find some callibration settings to play with until I can get a Pro out. Thanks for the help, any other help for a newbie with a sweet TV that I cant get to look good would be great.
ucsbrandall is offline
Old 04-21-2013, 11:35 AM
Ph8te's Avatar
Quoted: 4543 Post(s)
Liked: 3972
Not so sure he was saiying "bargain plasma" in that sense, but find a good bargain on a plasma. The ST60 right now is a great bargain for the performance\picture you are getting, which is what I think jack was referring to....
Ph8te is online now
Old 04-21-2013, 11:37 AM
Ph8te's Avatar
Liked: 3972
There is a Display Calibration section of the forums where you will find calibrators and thier locations as well as reviews for them....
As far as settings go there is a Settings Thread, if you do a quick search youll find it in this section of the forums, its beenposted to recently so it shouldnt be too far from this one......
Ph8te is online now
Old 04-21-2013, 11:48 AM
Thanks, im working my way around this site and its great. A little over my head in some aspects. What ive learned is that each TV set is unique and needs a Pro with a meter to callibrate it to the specific TV, not just cut and paste someone else's settings.
Old 04-21-2013, 12:06 PM
Ph8te's Avatar
Liked: 3972
Indeed if you want the most accurate picture than have a professional come out and callibrate it.....Each set has its variances so each may have different settings to get the "same" reference. Sure you can cut and paste someone elses settings just dont expect an accurate picture
Ph8te is online now
Old 04-21-2013, 12:08 PM
Wizziwig's Avatar
Quoted: 954 Post(s)
Liked: 635
Originally Posted by DavidHir View Post
I would think and certainly hope that .002 vs .005 in a dark room would be noticeable. My 65ST30 measures around .005 and I am really not impressed with its black levels particularly in low APL scenes (dark room viewing).
I think you would be surprised. I briefly had a 60ST30 next to a 60" Elite LCD (with arguably the best blacks available at the time). When watching a movie like The Descent, the difference in blacks was hardly noticeable when watching in a batcave room. Both appeared gray with the Elite slightly darker but nowhere near black. The fact is that no FPD can really produce anything that resembles true black - not even the Kuro. Possibly the local dimming Sony LED's that totally turn off the lights but the trade-offs are not worth it IMHO.
To put things in perspective, I have a front projector that puts out blacks at 0.001 (maybe lower but that's the limit of my meter) and they still appear as gray after my eyes adjust to the dark room. The best blacks in my home still come from an aging Sony XBR CRT. I think we'll need to wait for OLED to become mainstream before we see a set that can produce a noticeable improvement in dark rooms.
Arguing over anything in the range of 0.001 to 0.004 is pointless to me since they are all an unsatisfying gray to my eyes. I would rather focus on other attributes of the display such as uniformity, color accuracy, etc.
-Mark
Wizziwig is online now
Old 04-21-2013, 12:44 PM
Elvamir's Avatar
I updated my original calibration report post with these, but here they are in this post as well, my post-calibration video results (after measured adjustments. There was still some manual tweaking performed after this.)
Sent from my iPad using Tapatalk HD
Elvamir is offline
Old 04-21-2013, 01:21 PM
DavidHir's Avatar
Quoted: 1702 Post(s)
Liked: 1319
-Mark
I had a Sony 57" CRT RP that had phenomenal blacks. At the time, I basically took it for granted and since moving to digital displays, I've been a bit disappointed as I still have that Sony look in my head.
DavidHir is online now
Old 04-21-2013, 01:55 PM
whiznant's Avatar
Originally Posted by varun55 View Post
Anyone compared the F8500 to the S60 or ST60 to see which display has a sharper, crisper image? TIA.
I was at BB last night comparing the VT60 to the F8500 and the F8500 has the VT beat by a nose in the sharpness department. Not a huge difference but it was noticeable. For those who value sharpness I'd say its enough of a difference for a prospective owner to be proud of. I for one came away thinking that I prefer the F8500. Granted the viewing conditions were not optimal. There's something about the F8500 that I really like. I think it's the motion handling.
varun55 likes this.
whiznant is offline
Old 04-21-2013, 01:58 PM
Coyote Waits
htwaits's Avatar
Quoted: 919 Post(s)
Liked: 2030
You can start with David Abrams who works out of LA. Then UMR and D-Nice do tours to the LA area on a regular basis. You can read recommendations from plasma owners by clicking on the link in the signature area at the bottom of my post. The flat panel reports are in post number two.
It's early days for settings since the F8500 has been out for such a short time. In fact, we only have two owners who have reported getting their F8500 professionally calibrated. UMR (Jeff Meier) did one of them. As it happens he posted in this thread today.
htwaits is offline
Old 04-21-2013, 06:42 PM
whiznant's Avatar
Is there no official f8500 owners thread anywhere? Also, I'm really surprised that there's no talk about the recent firmware update samsung issued on 3/19. Does it address the brightness pos and/or black fluctuations? I returned my f8500 to amazon on Thursday with the intent of waiting for the ZT60 and of course, no sooner than I return mine, a firmware update is issued! Murphy's law...
Any feedback on the firmware update?
whiznant is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
