Official Samsung PNxxF8500 Series Discussion Thread [No Street Price Talk] - Page 136 - AVS Forum | Home Theater Discussions And Reviews
 203Likes
post #4051 of 13188 Old 04-30-2013, 07:54 AM
Ph8te's Avatar
Quoted: 4618 Post(s)
Liked: 4099
Originally Posted by Moonchilde View Post
I found it, thank you.
No problem, he may not be able to do anything, but its worth a shot.
Ph8te is offline
post #4052 of 13188 Old 04-30-2013, 08:19 AM
polakis's Avatar
My european 64F8500 has 1003 firmware version. Is this the last firm? When i search for firmware it says no new firmware. Europe's firm are different?
polakis is offline
post #4053 of 13188 Old 04-30-2013, 08:25 AM
Ph8te's Avatar
Liked: 4099
EU firmware numbers are different, so you cant go by the numbers you would see here.....
Ph8te is offline
post #4054 of 13188 Old 04-30-2013, 08:37 AM
Halimali's Avatar
Liked: 50
Originally Posted by Ken Ross View Post
Hali, I think the option for gray is to reduce the severe contrast between black sidebars and actual picture content. So as you suggested, it's a form of IR control. With that said, I'd bet the vast majority of people use black since gray can be a bit distracting.
Thanks Ken,
Is it just gray color? Or others too?
I wouldn't mind if it is different colors changing say every 3 -5 minutes. Just to prevent the IR
As of June 2013:
2,712 Bluray movies
1,593 DVD movies
356 bluray+DVD series
1,322 bluray+DVD Anime
Halimali is offline
post #4055 of 13188 Old 04-30-2013, 08:41 AM
Halimali's Avatar
Liked: 50
Originally Posted by Elvamir View Post
I am. No issues at all, except that I had some HDMI handshake issues between my Integra receiver and the TV early on so had to add a delay in the power in sequence which solved it. But the remote works great, no problems.
Thanks Elvamir,
Glad all is working well for you. I asked because there are some users who are facing problems with the F8000 so thought this might be Samsung related.
As of June 2013:
2,712 Bluray movies
1,593 DVD movies
Halimali is offline
post #4056 of 13188 Old 04-30-2013, 09:24 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Originally Posted by bargervais View Post
Get a good AV Receiver with 9 speakers and two subs
I'm not the only one who is "amazing" with an overkill suggestion like that. A 7.1 system is already going to be more than enough (in the majority of scenarios) for surround sound. wink.gif
vinnie97 is offline
post #4057 of 13188 Old 04-30-2013, 09:58 AM
ljmart's Avatar
Liked: 184
Not sure on that. Robert just emphasized that you need to be in Auto update mode. I know most updates allow you to do it either way, but who knows. If it were me, I'd follow his advice.
thank you ken, just what i was looking for!
Samsung PN51F8500 ~ Marantz SR5008 ~ Oppo BDP 103D ~ EMP Tek R55TiB LR, R56CiB, R55WiB ~ Sennheiser Momentum ~ Sennheiser 598
ljmart is offline
post #4058 of 13188 Old 04-30-2013, 10:14 AM
ljmart's Avatar
Liked: 184
Originally Posted by Pinger View Post
Believe me I'm not jumping in just yet, I'm having non of the issues others are except for the Cal/Day which is no biggie to me since I'm using Standard by day Cal/night at night.
Just thought it very strange that this update supposedly is also for LEDs F7450/F7500/F7550/F8000, PDP F8500 also??
Note I did unload and unzip it and it is a update image "update.msd" with a modified date of April 25th...
maybe its just in that group name so to speak? like the manual... is for all these tvs..? i also think ken said robert said this update may not be the pop and flux blk fix and that one should be out soon.
ljmart is offline
post #4059 of 13188 Old 04-30-2013, 11:24 AM
mightymouseusf's Avatar
Quoted: 34 Post(s)
Liked: 33
Yeah I tend to agree. I have a 7.1 system and I rarely find content that makes full use of it. And many times if the source is 5.1 it actually sounds better when I just leave it that way instead of trying to upconvert to 7.1. 9.2 seems overkill to me. But to each his/her own.
mightymouseusf is offline
post #4060 of 13188 Old 04-30-2013, 11:59 AM
somar76's Avatar
Hello All,
Just updated my 60" and I wanted to let you know that the new it did reset my TV back to the "stock" settings.
somar76 is offline
post #4061 of 13188 Old 04-30-2013, 12:05 PM
Crestapre's Avatar
What version does your TV show now?
Crestapre is offline
post #4062 of 13188 Old 04-30-2013, 12:09 PM
somar76's Avatar
It says it 1101
somar76 is offline
post #4063 of 13188 Old 04-30-2013, 12:09 PM
Damien Inferno's Avatar
I just updated my tv to 1101.2 The brightness pops are still there and it does erase all settings to default. If your tv is calibrated make sure you write down all your settings before updating. Samsung says the update gives us picture improvement. Looks the same to me. My tv size is 64 and im in nyc.
Samsung F8500 Service menu factory reset and activating cal modes instructions
http://www.avsforum.com/forum/167-pl...l#post24101072
Damien Inferno is offline
post #4064 of 13188 Old 04-30-2013, 12:13 PM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Doh.
vinnie97 is offline
post #4065 of 13188 Old 04-30-2013, 12:13 PM
Thelt2000x's Avatar
Originally Posted by Damien Inferno View Post
I just updated my tv to 1101. The brightness pops are still there and it does erase all settings to default. If your tv is calibrated make sure you write down all your settings before updating. Samsung says the update gives us picture improvement. Looks the same to me.
Ugh.....very disappointing. Glad I sent mine back yesterday and did not wait....
Thelt2000x is offline
post #4066 of 13188 Old 04-30-2013, 12:18 PM
somar76's Avatar
Originally Posted by Thelt2000x View Post
Ugh.....very disappointing. Glad I sent my back yesterday and did not wait....
I may be doing the same thing I'm well within the 60 day return window
somar76 is offline
post #4067 of 13188 Old 04-30-2013, 12:22 PM
Well according To Robert the brightness pops fix is in a separate update coming soon. I just don't know why Samsung says there is picture improvement when as far as I can see there isn't. I do notice though that voice recognition works better---- not that anyone cares lol.
I also and experiencing the banding issue and have a samsung tech coming tomorrow to look at it. If he cant do anything about it I think im going to return my set. I have a 64 btw.
post #4068 of 13188 Old 04-30-2013, 12:24 PM
Coyote Waits
htwaits's Avatar
Quoted: 936 Post(s)
Liked: 2078
Maybe the 9.2 suggestion was a joke. There's very little material that actually makes good use of a 7.1 setup. I've visited an AVS freind with a 9.2 setup, along with the Sony 4K projector and a 128" screen. The owner, and I, were doubtful that the 9.2 setup added anything.
htwaits is online now
post #4069 of 13188 Old 04-30-2013, 12:24 PM
yamvmax's Avatar
Quoted: 47 Post(s)
Liked: 33
This is NOT the update that fixes pops...relax guys.
yamvmax is offline
post #4070 of 13188 Old 04-30-2013, 12:28 PM
Ph8te's Avatar
Liked: 4099
Folks, when reporting firmware updates its best to name your location as NA and EU update numbers are different. Also, there needs to be mroe than 1101.....The "fix" firmware is supposedly 1017.2....the update that everyone seems to be getting is 1101.2 (posted by Pinger earlier) which looks like a "general" update and "not" the fix that everyone is looking for......
Ph8te is offline
post #4071 of 13188 Old 04-30-2013, 12:29 PM
arenaman's Avatar
Liked: 33
1004.7 is the latest firmware for Europe, download it from Samsung's website.
Panasonic TXP65VT65B
arenaman is offline
post #4072 of 13188 Old 04-30-2013, 12:32 PM
Thelt2000x's Avatar
Thanks. I just figured this was the update. I didn't figure they would UPdate to 1101 just to DOWNgate (wait what??) To 1017
post #4073 of 13188 Old 04-30-2013, 12:36 PM
me too because it lists-- Improves picture quality in the update description. Does anyone who installed it notice a difference in their picture quality? Also says --- Supports more MSO in OnTV feature. Anyone know what that is or means?
post #4074 of 13188 Old 04-30-2013, 12:39 PM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
all fw that Samsung puts out says "improves pq". while the details are usually hidden. it sucks i know, but it is what it is.
Habit Forming....Wallet Burning Hobby....55" Oled Lg B6p 55" Samsung B8500 Fald Channel Master Dvr+ Onkyo RZ900 avr Samsung K8500 UBR player Svs Ultra Towers/Center, Svs Satellite Surrounds Svs Pb-13 Ultra Sub
airgas1998 is offline
post #4075 of 13188 Old 04-30-2013, 12:42 PM
Quoted: 34 Post(s)
Liked: 33
crap! I forgot to turn of the auto firmware update settings....son of a....
post #4076 of 13188 Old 04-30-2013, 12:43 PM
Quoted: 34 Post(s)
Liked: 33
Doh.
D'oh indeed Vinnie. D'oh indeed...
post #4077 of 13188 Old 04-30-2013, 12:43 PM
polakis's Avatar
Arena do you have the link. I want to update mine. Thanks
polakis is offline
post #4078 of 13188 Old 04-30-2013, 12:43 PM
Ph8te's Avatar
Liked: 4099
The firmware may not be a "general" firmware so it may not need to fit the regular numbering conventions......This particular firmware if it is indeed the 1101.2 is for the PDP AND LCD lines, the specific update youa re looking for is PDP only....
Pretty much, that "Improves Picture" is just a general statement and it may not mean visbale improvements..
Ph8te is offline
post #4079 of 13188 Old 04-30-2013, 12:44 PM
I couldn't download it via auto update I had to use a usb stick.
mightymouseusf likes this.
post #4080 of 13188 Old 04-30-2013, 12:45 PM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
suppossedly you better keep it on if you give a hoot about the fw that will fix the pop/flux black issues.
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
