Official Samsung PNxxF8500 Series Discussion Thread [No Street Price Talk] - Page 169 - AVS Forum | Home Theater Discussions And Reviews
 203Likes
post #5041 of 13188 Old 05-07-2013, 09:39 PM
DevItHere's Avatar
Originally Posted by biotechy View Post
Thanks for the help so far guys. Sharpness at zero, check. I have an Oppo 103 and Dish 722k running into a Denon 4311 and then one HDMI into HDMI 1 on the Sammy. I used to use a Panny VT50 55" and have hung that on a wall in the bedroom now. The VT50 didn't have the "grainy" look on Blu Ray, so that's how I noticed it so quickly. I did turn off all enhancements on the Oppo 103, the Denon I will have to really check over again. Their GUI is not the easiest to navigate for sure. Just making sure that my set is "normal" before return windows closes. Thanks again.
Similar thing on my OPPO biotechy with graininess. I forget the setting on the OPPO, but I had to set the one PQ enhancement setting to as high as it would go (8 I think) then the graininess went away. I think the graininess for me was a lot of dither.
DevItHere is offline
post #5042 of 13188 Old 05-07-2013, 09:46 PM
agressiv's Avatar
Originally Posted by Ph8te View Post
Did you try to do a factory reset? have you tired to update via USB to the 1103 that was released today?
Its rare that this happens, but it does happen, never a good thing and I m sorry your going through this tyr the above 2 things and if they odnt work call up Samsung suppport to get the issue resolved.
Upgraded to 1103, didn't help. Unplugged for 10 minutes didn't help. Did a factory reset - didn't help. Unplugged for another 10 minutes - presto.
I have a repair request open for next Wednesday so I'll just cancel it if it doesn't break again.
agressiv is offline
post #5043 of 13188 Old 05-07-2013, 10:19 PM
Coyote Waits
htwaits's Avatar
Quoted: 924 Post(s)
Liked: 2042
Originally Posted by jackobots View Post
I tried the screen fit and had the row of pixels on top sometimes, but also on the bottom other times. So, now I have it at 16x9 with no issues.
What is the advantage to screen fit? Am I missing something?
If I have the Samsung terminology right, when you use "screen fit" you are getting a one to one bit map of the HD image exactly as it comes to you. What you see is source noise on the top and bottom of your screen. That usually means SDTV but I suppose you might see it with crappy HDTV. There shouldn't be any with Blu-ray disks.
When you switch to "16x9" the set is doing a small (5%?) amount of over-scan. Over-scan was always built into CRT SDTV sets for that reason. The down side of over-scan it that the image will not be as sharp because less (5%?) source data is mapped into your pixels.
htwaits is online now
post #5044 of 13188 Old 05-07-2013, 11:01 PM
crmmoore's Avatar
Originally Posted by Elvamir View Post
When you go into Picture Size (where you changed it to Screen Fit) you'll see an option just under that for Position. Click it and you'll go to a screen with four arrows, where you can adjust the screen to line it up right and move those wiggles out of frame.
Sent from my iPad using Tapatalk HD
If I do that, then won't there be a black bar on the bottom that may burn in?
crmmoore is offline
post #5045 of 13188 Old 05-07-2013, 11:27 PM
Halimali's Avatar
Liked: 50
Glad to hear that many are happy with the update.
Sounds wonderful
As of June 2013:
2,712 Bluray movies
1,593 DVD movies
356 bluray+DVD series
1,322 bluray+DVD Anime
Halimali is offline
post #5046 of 13188 Old 05-08-2013, 01:51 AM
Damien Inferno's Avatar
Originally Posted by Ken Ross View Post
Yeah, I'm actually wondering how much of this is in our head as opposed to reality. It was discussed that perhaps it would cause a brightness drop and now it seems people may have expected that.
A self fulfilling prophecy or perhaps reality?
Sent from my SCH-I535 using Tapatalk 2
I think the picture has way better clarity now but I did have to put the cell light up to 20 and the gamma up to +2
This is why I say its not as bright as it was. But who cares the pops are gone and the tv looks better than ever with a few minor adjustments.
Samsung F8500 Service menu factory reset and activating cal modes instructions
http://www.avsforum.com/forum/167-pl...l#post24101072
Damien Inferno is offline
post #5047 of 13188 Old 05-08-2013, 02:56 AM
griffithstrife's Avatar
Quoted: 16 Post(s)
Hello Everyone I took the plunge I was scared but figured I would get it sooner or later, after the update was done I did another calibration. The results are below.
A bit different from what I had before but still looks good to my eye but, after I was done calibrating I upped the gamma to plus 2 so I don't know how that will affect the calibration I will check tomorrow though.
griffithstrife is offline
post #5048 of 13188 Old 05-08-2013, 03:06 AM
Quoted: 16 Post(s)
I would like to show everyone why I think the f8500 was for me.
No other TV I have seen can go that bright and that dark I know the Sharp Elite came close but it had to many issues for me, I know all TVs have issues including the f8500. But to me this TV represents the best compromise available to someone like me.
post #5049 of 13188 Old 05-08-2013, 03:27 AM
cooknl's Avatar
Quoted: 23 Post(s)
Liked: 25
Can we watch the Shootout in Europe??
If so How???, when , where???
Thx
Rob
cooknl is offline
post #5050 of 13188 Old 05-08-2013, 04:10 AM
bonepile's Avatar
Does it matter?
I am running my cable box, and Blu Ray player through my Sony A/V receiver and into my 8500. Does it matter if I am using HDMI input #1 or HDMI input #3??
Thanks for answering.
bonepile is offline
post #5051 of 13188 Old 05-08-2013, 04:50 AM
DrFaxe's Avatar
Quoted: 14 Post(s)
Liked: 84
Thx
Rob
Live Shootout Feed:
http://new.livestream.com/accounts/632436/hdtvshootout
The Event will be Live on May 10 & 11, 2013 6:00 pm Eastern Standard Time
DrFaxe is offline
post #5052 of 13188 Old 05-08-2013, 05:07 AM
gmarceau's Avatar
Quoted: 24 Post(s)
Liked: 68
Originally Posted by Oplasmic View Post
I have the 60F8500 and with the latest 1103 update the one thing I seem to notice is the picture seems to me to have more depth to it. Brightness is still there, the blacks MAYBE seem a little darker, but it seems to have a depth to it I didn't notice before. Would that be an improved gamma or greyscale? I'm using the movie mode with slight adjustments which were not changed before the update. Anyone else noticing a depth difference?
It's probably an improvement in ANSI contrast, so the blacks are floating a little less. Other than that, if people are seeing better shadow detail, the mll might be slightly lower.
Usually, the more 3D like the picture seems, the deeper the blacks are and the better the contrast. If it didn't get any brighter...
Anyone used their Darbee on the F8500?
"If you weren't such an ignorant troll, you'd be adorable" -rogo
gmarceau is offline
post #5053 of 13188 Old 05-08-2013, 06:32 AM
cooknl's Avatar
Quoted: 23 Post(s)
Liked: 25
Originally Posted by DrFaxe View Post
Live Shootout Feed:
Wow Great!!
Just tried the link and all works fine here in Holland. Glad its on the east coast that way we only have a 6 hour difference. So looks like gonna go to bed in the weeeeee small hours of the morning on Saturday and sunday.
Rob
cooknl is offline
post #5054 of 13188 Old 05-08-2013, 07:25 AM
Ph8te's Avatar
Quoted: 4555 Post(s)
Liked: 3986
Originally Posted by bonepile View Post
Does it matter?
HDMI 3 is the ARC channel, so if your receiver can handle the ARC signal you should always use HDMI 3 from your AVR so that the audio will pass through even when the receiver is off....
Ph8te is online now
post #5055 of 13188 Old 05-08-2013, 07:48 AM
arenaman's Avatar
Liked: 33
Live Shootout Feed:
Panasonic TXP65VT65B
arenaman is offline
post #5056 of 13188 Old 05-08-2013, 07:53 AM
DavidHir's Avatar
Quoted: 1728 Post(s)
Liked: 1338
This is exactly what I was thinking. I am VERY curious to see the Shootout results with this set compared to the VT60.
DavidHir is offline
post #5057 of 13188 Old 05-08-2013, 07:59 AM
Ph8te's Avatar
Liked: 3986
Originally Posted by arenaman View Post
BTW you dont ahve to watch it live as they will post videos of the event (both days) after they happen, watching live is much more "rewarding" though and allwas you to be up to the minute with information wink.gif
Ph8te is online now
post #5058 of 13188 Old 05-08-2013, 08:09 AM
Halimali's Avatar
Liked: 50
Live Shootout Feed:
Thank you for sharing this
The Shootout will be beneficial to those who want to make a purchase decision. Though I cannot say the same about myself.
As of June 2013:
2,712 Bluray movies
1,593 DVD movies
Halimali is offline
post #5059 of 13188 Old 05-08-2013, 08:29 AM
Ken Ross's Avatar
Quoted: 5719 Post(s)
Liked: 6076
This is exactly what I was thinking. I am VERY curious to see the Shootout results with this set compared to the VT60.[/quote]
The picture looks like its got a Darbee built in. :-)
Ken Ross is offline
post #5060 of 13188 Old 05-08-2013, 08:47 AM
JRWalker's Avatar
Quoted: 40 Post(s)
Liked: 54
Yes. Have only watched a few samples after applying FW 1103. No problems.
Darbee added 3D cues make both 2D and 3D images very realistic.
My recent post about my PN60F8500 and Darbee experience here:
http://www.avsforum.com/t/1463454/official-samsung-pnxxf8500-series-discussion-thread-no-street-price-talk/4700_100#post_23282495
Darbee patent disclosure full text information links here:
http://www.avsforum.com/t/1463454/official-samsung-pnxxf8500-series-discussion-thread-no-street-price-talk/4700_100#post_23283772
JRWalker is offline
post #5061 of 13188 Old 05-08-2013, 08:59 AM
jackobots's Avatar
I know this may sound like a really dumb question, but I can't determine how to get the picture to move. I see the arrows, but can't get a pointer to come up so I can click on them. Moving my thumb on the pad doesn't seem to do anything and when I click it, the arrows just go away. What am I doing wrong?
jackobots is offline
post #5062 of 13188 Old 05-08-2013, 09:02 AM - Thread Starter
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2052 Post(s)
Liked: 2216
Cleveland Plasma is offline
post #5063 of 13188 Old 05-08-2013, 09:05 AM
Ph8te's Avatar
Liked: 3986
Ph8te is online now
post #5064 of 13188 Old 05-08-2013, 09:08 AM
JRWalker's Avatar
Quoted: 40 Post(s)
Liked: 54
That is not my experience. The Darbee DVP 5000 enhancements on my PN60F8500 are as dramatic as the images in the Darbee Gallery http://darbeevision.com/gallery . My comparisons have been made with both Darbee Demo Mode and bypassing Darbee unit altogether.
JRWalker is offline
post #5065 of 13188 Old 05-08-2013, 09:13 AM
jackobots's Avatar
So you've already decided I see...me too, unless the ZT60 knocks everyone's socks off eek.gif
post #5066 of 13188 Old 05-08-2013, 09:20 AM
jackobots's Avatar
Yea, yea, yea...I know...user error, but I stiil can't figure it out. You wiseguy you wink.gif
post #5067 of 13188 Old 05-08-2013, 10:09 AM
pieandchips's Avatar
Liked: 171
Originally Posted by Cleveland Plasma View Post
I have not heard of such a device before.
-Interested......
pieandchips is offline
post #5068 of 13188 Old 05-08-2013, 10:11 AM
bonepile's Avatar
Thanks for that advice. I will leave it exactly where you suggest, and where it is now. Appreciate that advice too. smile.gif
bonepile is offline
post #5069 of 13188 Old 05-08-2013, 10:33 AM
mightymouseusf's Avatar
Quoted: 34 Post(s)
Liked: 33
-Interested......
Is this more of your dry humor Pie?
mightymouseusf is offline
post #5070 of 13188 Old 05-08-2013, 10:40 AM
Liked: 171
Seriously. I had not heard of this. I've just been reading up. May order one.
Does this affect grayscale in such a way as to require a new calibration whilst using one?
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
