Official Samsung PNxxF8500 Series Discussion Thread [No Street Price Talk] - Page 250 - AVS Forum | Home Theater Discussions And Reviews
 203Likes
post #7471 of 13188 Old 05-26-2013, 10:49 AM
Ph8te's Avatar
Quoted: 4545 Post(s)
Liked: 3978
Originally Posted by Halimali View Post
Then exchange the TV
You should have checked the TV when they brought it to you. Unless you got it directly or shipped
Hali,
Hes been given this advice for more than a month now, but seems to ignore it. He seems to be on a "do you see bands" posting bonaza, across multiple forums and facebook wink.gif
While I understand polakis is from Greece where they may do things differently, there are only a few things that can be done. Call Samsung and hope to get a replacement or contact the place of purchase for an exchange....
Ph8te is offline
post #7472 of 13188 Old 05-26-2013, 11:04 AM
smbsocal's Avatar
Liked: 25
Originally Posted by nfraso View Post
Anyone around Charlotte or Atlanta know if those Magnolia's have these on display? I have a feeling they would tell me they did even if they didn't...
The Best Buy in Mooresville, NC which is about 30 minutes N of Charlotte has a 64" F8500 next to a 60" VT60. Very good setup to compare the two.
nfraso likes this.
smbsocal is offline
post #7473 of 13188 Old 05-26-2013, 11:15 AM
polakis's Avatar
Originally Posted by Ph8te View Post
Hali,
I will get a replacement next week. I ask just for statistic reasons...
polakis is offline
post #7474 of 13188 Old 05-26-2013, 11:20 AM
Ph8te's Avatar
Liked: 3978
Polakis, the problem with that is the "numbers" you get will be meaningless to anyone but you....The number of people that visit the forums you do and reply saying the do or dont have the band is only a small fraction of those that actually buy the set.I would understand if it was a large number of people (hudreds if ot thousands, but unfortuantely we here are penny in the pucket of overall sales......Much like poles that are not "public" anyone can votes and totally destroy your statistics.....
Happy to hear that you have a replacement coming, hopefuly that one works out better for you smile.gif
Ph8te is offline
post #7475 of 13188 Old 05-26-2013, 11:40 AM
Tony1's Avatar
Quoted: 31 Post(s)
Originally Posted by Ken Ross View Post
That's a good question Jim. Although the 8500 gets amazingly bright, it's still not quite as bright as an LED.
OTOH, edge lit LEDs have a number of issues that plasmas don't have (of course plasmas have their issues too).
DSE was always something that bugged me and was one of the reasons I returned a Sony 929. I'm amazed at how almost totally absent DSE is on my 8500. I find DSE to be one of the most distracting issues with displays.
Would you say that the F8500 has drastically less DSE than the VT50 or the whole 2012 panny line up in general? I find that the LED i just bought to have less DSE than either of my 2 plasmas..
Panasonic GT50 55"
Pansaonic VT60 60"
Tony1 is offline
post #7476 of 13188 Old 05-26-2013, 11:42 AM
Bama29's Avatar
Liked: 26
Originally Posted by crmmoore View Post
So what if you use a Ps3 for Bluray? What should the following settings be:
RGB full range: Full or limited?
Y Pb/Cb Pr/Cr vs RBG?
Y Pb/Cb Pr/Cr Super white: on or off?
Deep Color Gamut: On, auto, or off?
I'm pretty sure that it should be Y Pb/Cb Pr/Cr and not RGB, but there is so much conflicting on the other settings that I can't get a clear answer. Any advice?
crmmoore,
There is a pretty good guide for setup of your PS3 over at the Home Theater Shack Forum and can be located here.
Michael
Bama29 is offline
post #7477 of 13188 Old 05-26-2013, 11:42 AM
pieandchips's Avatar
Liked: 171
So what if you use a Ps3 for Bluray? What should the following settings be:...Any advice?
Y Pb/Cb Pr/Cr
Superwhites: On
Deepcolor: Off
pieandchips is offline
post #7478 of 13188 Old 05-26-2013, 11:48 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
My Kuro has it also. I don't remember it on the Samsung LNT466F (LCD, the last one I owned for primary viewing), but that model had a backlight from hell (devoid of uniformity), which stood out more.
vinnie97 is offline
post #7479 of 13188 Old 05-26-2013, 11:59 AM
hifi59's Avatar
Originally Posted by LarryInRI View Post
Note to those doing calibrations on this set with meters:
Be aware that dropping Contrast that far below about 90 will cause the higher end of the 10 point controls to become ineffective and each of the remaining to cover more than one region. This in turn will increase the iterations required to perform a true calibration. It can be done but plan to spend time determining the relationship between labeled 10 point region and actual region or regions affected.
With Contrast at 60 about half of the 10 point controls will be useless.
Larry
I have noticed that with cell lite at 20 and contrast at 81 to avhieve a desired 35 ftl, using 10 point is a challenge. What I did discover was that if I want to adjust 50ire for example, I would have to go to interval 4 instead do 5 to make te adjustment. Interval 5 affects 60ire and so on. Once o figured that out, getting near perfect grayscale on my sons f8500 was a breeze.
Are you saying that had the contrast been above 90 for example, the 10 pt would have tracked with the proper interval instead of as I described?
If you're talkin, you ain't learnin.
hifi59 is offline
post #7480 of 13188 Old 05-26-2013, 12:13 PM
Liked: 171
Hifi do you have the values? I'd love to see them. I learn a lot that way especially to do with the idiosyncrasies of the set.
post #7481 of 13188 Old 05-26-2013, 12:59 PM
Darth F8500's Avatar
I have 2 vertical bands on my TV that can be seen when light hits the tv. They are much harder to see when room is dark. I can also make out a vertical band that can be seen from different angles. I'm on TV 3 and I'm retuning this one in a week when I have some time. I will be getting another 64 F8500 since PQ is the best I've seen. The VT and ZT are great for dark rooms or for home-theater systems.
Darth F8500 is offline
post #7482 of 13188 Old 05-26-2013, 01:18 PM
DavidHir's Avatar
Quoted: 1721 Post(s)
Liked: 1333
Unless you guys can see these bands while watching content, I would not worry about it at all.
On my F8500, they are not visible watching any real material.
DavidHir is offline
post #7483 of 13188 Old 05-26-2013, 01:53 PM
Mine are if watching with room shades open and off angle forward facing not visible.
post #7484 of 13188 Old 05-26-2013, 02:01 PM
post #7485 of 13188 Old 05-26-2013, 02:20 PM
bargervais's Avatar
Quoted: 1557 Post(s)
Liked: 933
how do you return TV after TV do they just take them back without question i don't understand
DEN Atmos Samsung UN65KS8000 Roku Ultra Onkyo TX-NR 747 5.2.2 UHD audio. Polk Audio OWM3 Speakers / top middle on Ceiling / 300MGB Spectrum / Samsung UBD-K8500 Blu-Ray Player / 26 UHD Blu-Rays Living Room Atmos Samsung PN60E8000+SEK2000 / Onkyo TX-NR 1030 7.2.4 /Onkyo M-5010 Amplifier for top middle/ 300MGB Spectrum / Panasonic 3D blu-ray Bic Acoustech speakers, MICCA M-8S FH on wall /TM in ceiling speakers / 2 Bic F12 subs. BEDROOM Samsung 55JS8500 using tv speakers for now
bargervais is offline
post #7486 of 13188 Old 05-26-2013, 02:35 PM
Pinger's Avatar
Quoted: 39 Post(s)
Liked: 34
Mine are if watching with room shades open and off angle forward facing not visible.]
Not seeing any on my 51F8500..
funny not 10 minutes after reading your post a nice pure white screen popped up on ep.1 of the Netflix's New Arrested Development series so I paused and snapped a shot with my cell phone..
Pinger is offline
post #7487 of 13188 Old 05-26-2013, 02:44 PM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
How is your tv mounted in your cabinet? It doesn't look like you have it on its stock stand....maybe it's an optical illusion in your pic....nice, white screen!!!
DanF8500 is offline
post #7488 of 13188 Old 05-26-2013, 02:47 PM
Ph8te's Avatar
Liked: 3978
Darth at what distance are those pictures taken? They look awfully close to the TV.....It has been established that you may see the filter come into play if you are 3ft or closer and on an angle.......Im trying to decipher that last part of your sentence....so are they visable during normal content (not slides) or is it only during slides and full white\color screen content...
Ph8te is offline
post #7489 of 13188 Old 05-26-2013, 03:53 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
Yes, that's exactly what I am saying. The ten point controls should track perfectly at the highest reasonable Contrast setting -- about 94. As the Contrast is reduced, the ten point tracking starts shifting just as you described. The Cell setting does not cause this problem. However, as Cell is reduced, the threshold where ABL kicks in also is reduced. But with this TV and its very bright capability, reducing the Cell should have no really visible effect on ABL.
I suggest that you set the Contrast at 90 or greater and reduce Cell to get the max output that is comfortable to you. The calibration will go much easier for you.
Larry
LarryInRI is offline
post #7490 of 13188 Old 05-26-2013, 04:44 PM
Liked: 171
^ I found, by trial and error, that it worked easier for me to tweak either side by a notch, before going in full bore on the level that I was supposed to tweak (if that makes any sense smile.gif ).
post #7491 of 13188 Old 05-26-2013, 05:04 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
Pie,
Using a screen like this helps determine where the 10 point is working. This one is from Chad B.
Larry
post #7492 of 13188 Old 05-26-2013, 05:33 PM
buzzard767's Avatar
Quoted: 1621 Post(s)
Liked: 2395
In Chromapure I calibrate GS in the Gamma module with the mid point (65%, 75%, etc.) options enabled. For example, adjust the level 7 control and see what happens at 60, 65, 70, 75, and 80% for a good understanding of what the display is doing.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
post #7493 of 13188 Old 05-26-2013, 06:02 PM
Liked: 171
post #7494 of 13188 Old 05-26-2013, 06:04 PM
Moonchilde's Avatar
Liked: 105
Y Pb/Cb Pr/Cr
Superwhites: On
Deepcolor: Off
But superwhite shows content below 16 and above 235.
BTW, I double checked the HDMI Black Level setting today. On low, it is definitely crushing black. On normal, it isn't, and you can still see the full range such as white 236 to 255. I personally don't think this setting has anything to do with RGB limited or full range. I think it just adjusts the gamma to a degree maybe changes it to a different curve. It may be a setting you'd look into to calibrate for deeper blacks, but again you'd be correcting a gamma curve so you may end up defeating it anyway and might have an easier time calibrating for normal.
Something of note: PC mode will not allow YCBR ranges beyond 235 or below 16. In PC mode, However, I can create an image with a 235 white background and 255 white text and make out the difference. Really, really weird. YCBR will also float the blacks, but going into menu and moving the brightness slider down 1 notch and back up a notch will pop the image back to how it usually looks.
Could someone else test this? If it's a repeatable bug, then I'd like to report it.
In PC mode:
Step 1. Set PS3 to RGB for DVD/BD content.
Step 2. Load up the 5% grayscale step pattern from Get Gray
Step 3. Hit triangle, go to AV settings, change the output to YCBR.
Notice the image pops up in brightness.
Step 4. Hit menu on your remote, go to brightness, and change it by a step.
Notice the image resets to it's normal setting.
Moonchilde is offline
post #7495 of 13188 Old 05-26-2013, 06:10 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
[snip]
The sole purpose of the HDMI Black Level is to adjust the TV to accept and display properly either a 16-235 or 0-255 input. That's all.
Larry
post #7496 of 13188 Old 05-26-2013, 06:11 PM
Liked: 171
How do I use that? /confused, sorry.
post #7497 of 13188 Old 05-26-2013, 06:14 PM
Liked: 171
Larry
Yes agreed, after a lot of research lol. Also, Superwhites do 'something' that helps take any color 'smearing' out of pure white, so I read somewhere before (can't find reference) so it does help for 16-235.
post #7498 of 13188 Old 05-26-2013, 06:18 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
If you mean the chart, simply put it on the screen and increase the green in the individual 10 point controls. You'll see exactly where the range or ranges show up.
Here is a jpeg of the chart for you to download.
gamma-10 pt.jpg 25k .jpg file
Larry
post #7499 of 13188 Old 05-26-2013, 06:26 PM
buzzard767's Avatar
Liked: 2395
Horrible little CRT. Watching Sprint Cup but have to go to bed soon as I'll be doing my own racing on Interstate 24 early tomorrow. eek.gif
Buzz
post #7500 of 13188 Old 05-26-2013, 06:36 PM
Pinger's Avatar
Quoted: 39 Post(s)
Liked: 34
Thanks Dan, love the whites on this TV..
I have it wall mounted with a Articulating wall mount. (Sanus XF228), .
Pinger is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
