Official Samsung PNxxF8500 Series Discussion Thread [No Street Price Talk] - Page 313 - AVS Forum | Home Theater Discussions And Reviews
 203Likes
post #9361 of 13188 Old 11-17-2013, 06:06 AM
Ftballfn's Avatar
PieandChips... Sorry the OP only had this issue with ps3... I'm having the issue with cable and blu ray..... Zoom 1 and 2 are grayed out at all times...apologize for the confusion...
Ftballfn is offline
post #9362 of 13188 Old 11-17-2013, 09:24 AM
pieandchips's Avatar
Liked: 171
Originally Posted by jjclecky View Post
pieandchips, I have the same set up as you
I use HDMI-CEC feature without ARC (ARC is troublesome for me and many others). Doing so allows me to turn off the 'TV' input in the Denon and prevents the annoying switch that happens on power on.
I still want to hear sound from the TV's Smart apps such as Netflix etc. With ARC disabled, you now must use an optical cable wired from the TV to the Denon. I have mapped V-AUX port in the Denon to the optical port and select V-AUX when I want to hear Netflix.
pieandchips is offline
post #9363 of 13188 Old 11-17-2013, 10:22 AM
Liked: 171
Ahh apologies all around then...
I'm pretty sure the zoom modes you are trying to get from the cable tuner and Bluray via HDMI are disabled for us all so it's not a fault with your TV.
post #9364 of 13188 Old 11-17-2013, 11:49 AM
ken6217's Avatar
Quoted: 64 Post(s)
Originally Posted by ken6217 View Post
Hi,
Does anyone have settings for this display? I wanted use these until I have my display ISF'd.
Ken
Anyone? Are there any settings posted on the net for forum as a better option than what comes with the display?
Ken
ken6217 is offline
post #9365 of 13188 Old 11-17-2013, 12:28 PM
ljmart's Avatar
Liked: 184
Hi,
Ken
Ken
follow links in post 2...
http://www.avsforum.com/t/1475066/official-samsung-pnxxf8500-owners-thread-no-street-price-talk/0_20
Samsung PN51F8500 ~ Marantz SR5008 ~ Oppo BDP 103D ~ EMP Tek R55TiB LR, R56CiB, R55WiB ~ Sennheiser Momentum ~ Sennheiser 598
ljmart is offline
post #9366 of 13188 Old 11-17-2013, 03:14 PM
ken6217's Avatar
Quoted: 64 Post(s)
Thank you.
I actually bought the ZT60 last week and I am going to try the 8500. I love the blacks and color, but there image is too dark for me. The well lit scenes look great. However any indoor scenes are just too dark for me.
Ken
Ftballfn likes this.
ken6217 is offline
post #9367 of 13188 Old 11-17-2013, 09:38 PM
SheepNutz's Avatar
Whenever I switch channels on my DVR & it switches resolution (like going from a 720p channel to a 1080i channel), there's a black bar across the top of my screen that shows the input, resolution, and time and date. Is there any way to disable this?
SheepNutz is offline
post #9368 of 13188 Old 11-18-2013, 02:28 AM
Hifi4Hobby's Avatar
Be warned that the reliability of Samsung is very questionable..my C series 63" panel died in the 3rd year when the warranty ran out. The replacement part cost a bomb to pay for ($1k) and Samsung wont offer anything else than leaving you high and dry with its faulty panel. Dont end up with a "high end" thrash. Samsung is only keen to keep pushing new models (many are just mere repackaged) and after sales simply sucks!!
Hifi4Hobby is offline
post #9369 of 13188 Old 11-18-2013, 06:39 AM
Liked: 171
^ With respect, if a product I owned went faulty after three years, and I did not have an extended warranty then I would not expect to have the manufacturer fix it for free.
I have a Samsung B550 TV in our bedroom that has been going strong for 4.5 years.
Your reasoning is moot and invalid and could be attributed to any manufacturer of any product, anywhere.
post #9370 of 13188 Old 11-18-2013, 07:05 AM
Hifi4Hobby's Avatar
I never said it should be done free and depending on what's at fault, it might suggest inherited problem since day one, could be from manufacturing problem, design problem or simply quality issues.
FYI, my unit spoil not after 3 years, but 2.5 years and given the unit cost $4k+ when new, asking $1k is pretty unreasonable in my opinion and Samsung claimed the panel has 60k hours lifespan and clearly i dont use even half of that.
If you're here to sound like what a typical manufacturer would say, then i have heard enough. My point is simple, consumer's voice shouldnt be muted and any long term ownership should be raised especially when these products failed in shorter than expected lifespan and a costly bill is expected. The point here is not to bad mouth a manufacturer but to educate consumers if there're high numbers of certain models from a given brand failed in too short a time frame, we should be aware of it.
I doubt you have infinite resources to keep buying a large flat panel every 2.5 years. I dont, do you?
post #9371 of 13188 Old 11-18-2013, 07:31 AM
Liked: 171
^ If you had a Panasonic TV that developed a main board fault, you'd be posting the same thing in a Panasonic thread.
I'd wager a main board replacement for a high end Panasonic would cost a similar amount to have 'professionally' replaced / repaired.
It's not specifically Samsung, yet you appear to have developed a braisen attitude towards them, perhaps just to let off some steam?
post #9372 of 13188 Old 11-18-2013, 07:44 AM
ken6217's Avatar
Quoted: 64 Post(s)
Out of curiosity, what have been the most frequent issues with the 8500 and are the percentages small in getting a set with these?
Ken
ken6217 is offline
post #9373 of 13188 Old 11-18-2013, 08:11 AM
JRWalker's Avatar
Quoted: 40 Post(s)
Liked: 54
You may have an extended warranty on your TV that you don't realize that you have. See thread http://www.avsforum.com/t/449059/american-express-extended-warranty .
I have made an over the phone claim once on my AmEx card. Very easy to do since they have all the info about your purchase in your account history. From thread others cards offer extended warranty too.
Also, you get a longer Samsung warranty when you register your TV online.
Update:
For free American Express Extended Warranty Info call 1-800-225-3750 and select option 2 for recording. Quick explanation is that if your manufacturer's warranty plus any additionally purchased extended warranty do not exceed 5 years then AmEx will give you 1 additional year of extended warranty. Restrictions apply of course, read the fine print yourself. http://www.americanexpress.com/us/content/card-benefits/extended-warranty/faq.html
AmEx also provides free theft protection on card purchases.
JRWalker is offline
post #9374 of 13188 Old 11-18-2013, 08:32 AM
Hifi4Hobby's Avatar
FYI, i do have a Sony Bravia TV that's coming to 7 years old. It had a power supply board failure 2 years ago presumably KO by lightning strike. I called Sony and expecting to pay for it after the technician diagnosed the problem. Sony gave me a free board replacement but only expecting me to pay for the labor charges. How's that comparing to Samsung?
post #9375 of 13188 Old 11-18-2013, 08:35 AM
Hifi4Hobby's Avatar
It seems it only covers brand new item with original warranty of 12 months or less. Anything longer it wont apply..
post #9376 of 13188 Old 11-18-2013, 08:37 AM
Hifi4Hobby's Avatar
Ken
Samsung will tell you as what they have told me regarding to the panel failure issue as "it's hard to predict on electronics these days.." biggrin.gif
post #9377 of 13188 Old 11-18-2013, 08:58 AM
JRWalker's Avatar
Quoted: 40 Post(s)
Liked: 54
Don't know where you got the 12 month or less info. It is not correct. Have updated my post with more info.
http://www.avsforum.com/t/1463454/official-samsung-pnxxf8500-series-discussion-thread-no-street-price-talk/9360#post_23963537
JRWalker is offline
post #9378 of 13188 Old 11-18-2013, 10:10 AM
JRWalker's Avatar
Quoted: 40 Post(s)
Liked: 54
Well, Samsung recently replaced a 2007 DLP with an out of warranty exchange for a PN60F8500 and a fee of $450 and another for a PN64F8500 for fee of $550. Those Samsung customers are at least as happy with Samsung as you are with Sony. http://www.avsforum.com/t/827799/2007-samsung-led-owners-thread-hlt-xx87-89s/14670#post_23919992
I payed a higher exchange fee for my PN60F8500 but it was before any local sellers even had F8500s on display. I am very pleased with Samsung and its products.
hurricanebob likes this.
JRWalker is offline
post #9379 of 13188 Old 11-18-2013, 10:33 AM
mightymouseusf's Avatar
Quoted: 34 Post(s)
Liked: 33
Pretty much same here. I feel Samsung did right by me when my tv failed to live up to my standards. They replaced my D series with an F series years after I bought it, just because the bezel was coming loose.
mightymouseusf is offline
post #9380 of 13188 Old 11-18-2013, 11:21 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Samsung did go cheapo and use faulty caps on some (or all) of their 2007 models. As a result of a class action, they were forced to make up for their wrongdoing by compensating those who suffered from their shortsighted decision. Rumor is Panasonic has taken a similar path this year, so we'll see in a few years if that comes back to bite them. But given Samsung's history, it is a reason to think twice before plunging down 3 grand or more.
vinnie97 is offline
post #9381 of 13188 Old 11-18-2013, 11:22 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
That took a class action lawsuit before they complied...
vinnie97 is offline
post #9382 of 13188 Old 11-18-2013, 11:23 AM
Liked: 171
^ The faulty CAP fiasco affected many other Companies and a huge amount of hardware.
post #9383 of 13188 Old 11-18-2013, 11:29 AM
JRWalker's Avatar
Quoted: 40 Post(s)
Liked: 54
Truth is that the same caps were used by many including IBM, Dell, HP, Apple, Mitsubishi, and just about every computer motherboard manufacturer. When new the caps tested good. It was with time that they showed they only had about 10% of the expected life before some failed.
Story here: http://en.wikipedia.org/wiki/Capacitor_plague
The Samsung cap settlement agreement expired several weeks ago but they are still taking care of their customers. The settlement was to fix the set or pay $300 for the set. Samsung has gone way beyond those settlement terms.
JRWalker is offline
post #9384 of 13188 Old 11-18-2013, 11:33 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
I admit I did have a cap in my Asus router's power adapter fail (and likely the cause of the eventual failure of the router itself). However, I don't recollect any other TV manufacturers facing this problem in such a widespread fashion. If there are suits that support this contention, then I'm all ears.
vinnie97 is offline
post #9385 of 13188 Old 11-18-2013, 11:46 AM
JRWalker's Avatar
Quoted: 40 Post(s)
Liked: 54
I know of this one off the top of my head. There were probably others that I have not read about.
Mitsubishi TV class action lawsuit:
http://www.avsforum.com/t/1310024/problems-with-a-older-tv-new-isnt-always-better-try-repairing-it-first/30#post_21820806
vinnie97 likes this.
JRWalker is offline
post #9386 of 13188 Old 11-18-2013, 11:49 AM
vinnie97's Avatar
Quoted: 213 Post(s)
Liked: 1014
Good find...I can't "like" any of your posts for some reason (the option isn't there). Your AVS Club membership must put you above all that. wink.gif
vinnie97 is offline
post #9387 of 13188 Old 11-18-2013, 01:33 PM
WantsNWarrants's Avatar
Quoted: 84 Post(s)
Liked: 50
Some channels fill the screen and some don't... I was using zoom 1 and 2 before to get them to dill the screen....or to get the tickers off the screen... Might need to talk to Samsung support I guess....
Sorry, you were talking about a PS3? That does not need zoom mode.
Pie,
I used PS3 settings found here on AVS but they are clearly wrong. One example is that PS3 color ranges are restricted but should instead match NORMAL (0-255).
Would you please post your PS3 settings in one of the F8500 threads?
Thx
W&W
WantsNWarrants is offline
post #9388 of 13188 Old 11-18-2013, 02:22 PM
JRWalker's Avatar
Quoted: 40 Post(s)
Liked: 54
... Your AVS Club membership . . .
When the AVS Forum ads started blaring music every time my mouse went near them, I paid the AVS Club membership fee of $20 (now $25) to remove the ads. I must say that it is worth the price not having the ads and the page downloads seem to be quicker.
P.S.
Now I know what the My Profile option "Mute reputation display(?)" does. I have unchecked it. Feel free to Thumbs Up my posts. smile.gif
Bond 007 likes this.
JRWalker is offline
post #9389 of 13188 Old 11-18-2013, 04:10 PM
Liked: 171
Ad Block Plus.
Whilst I honour most sites advertising and allow them through to assist their revenue, this site goes over the top and intrudes into my psyche so I block nearly all ads here.
/Sorry AVS.
Glenee likes this.
post #9390 of 13188 Old 11-18-2013, 04:43 PM
CruelInventions's Avatar
Quoted: 460 Post(s)
Liked: 593
I have Ad Block Plus too, but I think I utilized a setting available in my user profile to shut all that stuff down (embedded links, etc.). Don't remember how to get there anymore, so I cannot advise beyond that..
CruelInventions is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
