Official Samsung PNxxF8500 Series Discussion Thread [No Street Price Talk] - Page 385 - AVS Forum | Home Theater Discussions And Reviews
 203Likes
post #11521 of 13188 Old 04-22-2014, 05:11 PM
pieandchips's Avatar
Liked: 171
pieandchips is offline
post #11522 of 13188 Old 04-22-2014, 08:32 PM
hove131's Avatar
Quoted: 36 Post(s)
Can someone tell me what each column in the service menu should read from the factory? Was searching for cal modes and want to make sure I didn't mess with anything else
hove131 is offline
post #11523 of 13188 Old 04-22-2014, 08:57 PM
KONICA TECH's Avatar
Quoted: 25 Post(s)
Liked: 54
Just do a reset from the service menu..
KONICA TECH is offline
post #11524 of 13188 Old 04-22-2014, 09:04 PM
hove131's Avatar
Quoted: 36 Post(s)
Originally Posted by wxman View Post
I put a small fan on back of mine, with cell light at 20 and contrast at 95. Temperature never hits 40, generally in the 35 to 38 degree range. However, I do not have mine wall mounted, so that's probably the big difference. Even when I was breaking my tv, without the fan, it only hit 41 or 42 degrees.
You have only one fan? Where is it located? How did you mount it? USB fan?
hove131 is offline
post #11525 of 13188 Old 04-22-2014, 09:06 PM
hove131's Avatar
Quoted: 36 Post(s)
I don't see a reset option
hove131 is offline
post #11526 of 13188 Old 04-22-2014, 09:21 PM
Quoted: 25 Post(s)
Liked: 54
It is at the top of the page as soon as you go into the service mode. You will have to re-enter all your settings again, it will be just like when you took it out of the box. If you had it calibrated it will lose the settings.
post #11527 of 13188 Old 04-22-2014, 09:26 PM
Ph8te's Avatar
Quoted: 4545 Post(s)
Liked: 3978
Do a search for Fans in this thread or the other main one, there are more than a few posts detailing owners fan installs wink.gif btw they are external fans smile.gif
Ph8te is online now
post #11528 of 13188 Old 04-22-2014, 09:37 PM
hove131's Avatar
Quoted: 36 Post(s)
The top column says pixel shift "off"
hove131 is offline
post #11529 of 13188 Old 04-22-2014, 10:00 PM
wxman's Avatar
Quoted: 3564 Post(s)
Liked: 2574
I attached this fan to the top right side big vent facing back of tv. Used just one twist tie. Make sure the fan is blowing air out of tv, not into tv.
http://www.amazon.com/gp/product/B002OJN250/ref=oh_details_o07_s01_i00?ie=UTF8&psc=1
hove131 likes this.
LG 65EF9500
LG 65E6P
wxman is offline
post #11530 of 13188 Old 04-22-2014, 10:13 PM
hove131's Avatar
Quoted: 36 Post(s)
What does the pixel shift test do in the service menu? I turned it on but nothing happened
hove131 is offline
post #11531 of 13188 Old 04-22-2014, 10:17 PM
Ph8te's Avatar
Liked: 3978
are you in the service menu or the regular user menu. Those are two completely different things.....
Ph8te is online now
post #11532 of 13188 Old 04-22-2014, 10:29 PM
hove131's Avatar
Quoted: 36 Post(s)
Service menu... I check my temp and hours there and saw the pixel shift test ...curiosity got best of me...nothing happened when i tried it.... Assuming it just turns pixel shift option on if its off?
hove131 is offline
post #11533 of 13188 Old 04-23-2014, 07:45 AM - Thread Starter
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2014 Post(s)
Liked: 2183
Originally Posted by titancrusher1 View Post
http://www.cnet.com/news/why-samsungs-f8500-is-the-last-great-plasma-tv/
Yep, well we all new it, now its just confirmed. Except of course we do not know when the last units will be made.......
Cleveland Plasma is offline
post #11534 of 13188 Old 04-23-2014, 07:49 AM
Quoted: 25 Post(s)
Liked: 54
How did you get there?
post #11535 of 13188 Old 04-23-2014, 12:01 PM
hove131's Avatar
Quoted: 36 Post(s)
Mute 7-3-7 enter
hove131 is offline
post #11536 of 13188 Old 04-23-2014, 01:04 PM
Dianabol5mg's Avatar
Quoted: 307 Post(s)
Liked: 234
I finally got my 60 yesterday. Going through the motions. So far, looks darker than my 51did. I do have me a buzzer. Sounds like an old crt.
LG 65EF9500
LG 55EG9100
Samsung 60F8500
Samsung 51F8500
LG BH200
Sony BDP-S5200 Multi-Region
Dianabol5mg is offline
post #11537 of 13188 Old 04-23-2014, 02:40 PM
Denniswrly's Avatar
Liked: 38
Eco Settings Off ? cell light 15 Contrast 95 or lower is perfect for me amazing PQ...smile.gif
64f8500
oppo bdp-103
Denon avr 1803
Energy speakers
Energy sub
Dual recliner lazyboy
xbox 360
Denniswrly is offline
post #11538 of 13188 Old 04-23-2014, 02:46 PM
frankly's Avatar
just bought an OPPO 103, same problem both through my onkyo and direct switchwed my MI for the one hat came with th 103, same problem,
ordered some new hdmi cables gona try hem al with another screen and than hook up th Sammy.
Get back with the results
Samsung 51F8500 - Dreambox 7020HD - Onkyo NR TX818 - OPPO 93 - PS3 - EPSON 5910 - KEF 2005 (5.1) QNAP 4 x 2TB
frankly is offline
post #11539 of 13188 Old 04-23-2014, 03:35 PM
Quoted: 25 Post(s)
Liked: 54
Mute 7-3-7 enter
This is not the full service menu....
post #11540 of 13188 Old 04-23-2014, 04:00 PM
cooknl's Avatar
Quoted: 23 Post(s)
Liked: 25
Look here tells you what you need to get into service menu BUT be carefull you will loose all settings when you get out of it.
http://www.avsforum.com/t/1515070/official-samsung-pnxxf8500-bugs-thread
cooknl is offline
post #11541 of 13188 Old 04-23-2014, 04:58 PM
Quoted: 307 Post(s)
Liked: 234
My buzzing is very directional. Cannot hear when standing off to the sides of the display. When I am in front watching, thats when it hits me. My 51F8500 had no buzzing. Tonight Im going to try and find a way to direct the sound another way. My pic is awesome and my black levels are superb. I had an F8000 for a couple weeks and I hated when the screen would turn off with an all black screen. Very distracting. Not with this bad boy. Just pure black abyss-like goodness. Im using Standard Mode 16 or 17 cell light, 50 brightness, 97 contrast, 53 color, 15 sharpness. Ill play around with the white balance at a later date.
LG 65EF9500
LG 55EG9100
Samsung 60F8500
Samsung 51F8500
LG BH200
post #11542 of 13188 Old 04-23-2014, 05:14 PM
Quoted: 25 Post(s)
Liked: 54
Thanks, I was trying to find out where HOVE131 was so he could go to the service menu to do a reset. I sent him a PM
post #11543 of 13188 Old 04-23-2014, 05:15 PM
hpp8140's Avatar
Quoted: 264 Post(s)
Liked: 79
Yeah, it's directional. Geez isn't that too bright?
LN55C630, PN64F8500, Definitive SSA-50, GE Supercinema 3D Array X, Paradigm Millenia CT
hpp8140 is online now
post #11544 of 13188 Old 04-23-2014, 05:25 PM
Quoted: 307 Post(s)
Liked: 234
No not at all. I think I had brightness at 47 or 48 with my 51. I screw around with my dark settings in the advanced menu when I need to. Depends what movie im watching. I use my WOW disc to get me started, then I tweek it a little. If I can jack up my brightness without losing my inky blacks, im doing it.
LG 65EF9500
LG 55EG9100
Samsung 60F8500
Samsung 51F8500
LG BH200
post #11545 of 13188 Old 04-23-2014, 08:00 PM
aficionado914's Avatar
As a novice when it comes to streaming and all that stuff, i'd like to say two things i'm doing that require no knowledge.
First, i changed my cable box setting so it shows gray bars instead of black. It's a little thing, but now, when I go the the Listings, it is gray instead of black bars, which i understand is better for 'break in'.
Second is Samsung's own Scrolling. If i go surf the internet in the other room, (like right now) i set the scrolling on, why not, real easy and should get rid of any IR, if there was any to start with, and i think, maybe it's breaking it in.
So, if you're like me and have to play catch up on streaming and downloading and running slides,,,then i think these are two things you can do right out of the box.
Scrolling
Screen Menu > System > Screen Burn Protection > Scrolling
This removes after-images on the screen by illuminating all the pixels on the PDP according to a set pattern. Use this when there are after-images or symbols on the screen, especially when a still image was displayed on the screen for a long time.
The after-image removal function has to be executed for approximately 1 hour to effectively remove after-images. If the after-image is not removed the first time, repeat the process.
Press any button to cancel this process.
aficionado914 is offline
post #11546 of 13188 Old 04-23-2014, 09:35 PM
Ph8te's Avatar
Liked: 3978
Hopefully you stated and restarted that messing with certain things in the Service Menu can cause some major "damage" to the set that would not be covered under warranty wink.gif . Sometimes I worry about people going in there and just "looking around" and clicking something that looks "interesting". A little opps can ruin a perfectly good TV....There have been some horror stories of people making mistakes that were not easy to come back from (if they were able to at all).
Ph8te is online now
post #11547 of 13188 Old 04-23-2014, 09:48 PM
hove131's Avatar
Quoted: 36 Post(s)
So I doubt I did any damage as I wasn't in the full service menu as I was in the " mute 7-3-7" menu and all I turned on and off was pixel shift test. I turned it back off so doubt I need to or should do a factory reset of service menu.... Agreed??
hove131 is offline
post #11548 of 13188 Old 04-23-2014, 09:56 PM
Ph8te's Avatar
Liked: 3978
Yes\no maybe so? from other threads and a quick Google search pixel shift test may be to adjust the timing of the pixel shift function. Since it seems you only had on\off though, I'm not sure what it does. You could nee a factory reset, but you may not need one ether wink.gif hows that for a clear answer smile.gif
Ph8te is online now
post #11549 of 13188 Old 04-24-2014, 02:21 AM
Dougofthenorth's Avatar
Liked: 44
Set's picture is going to change after break-in hours anyway say after 200+ hours
Diana - congrats! but sorry you got a buzzer - hopefully it's a quieter buzzer like my 2nd set
Does it have the latest FW update??
Dougofthenorth
www.turtleshelltortue.org RIP
Dougofthenorth is offline
post #11550 of 13188 Old 04-24-2014, 02:23 AM
Liked: 44
Yep - but as recommended, write down any future tweaks - so you don't get "lost" again smile.gif
Dougofthenorth
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
