Official Samsung PNxxF8500 Series Discussion Thread [No Street Price Talk] - Page 410 - AVS Forum | Home Theater Discussions And Reviews
 203Likes
Old 07-13-2014, 11:52 PM
MrNews's Avatar
Originally Posted by ofird View Post
Another thing I wanted to know about is which wireless keyboard will work good with the set - not referring to the Samsung ones which are expensive and Bluetooth is preferred over the USB.
I use this one: http://www.amazon.com/Motorola-Wireless-Keyboard-Retail-Packaging/dp/B004L9MBH6
Not all the special function keys work, but it's inexpensive, quite durable, feels great, and hooked up fine.
MrNews is offline
Old 07-14-2014, 12:02 AM
ofird's Avatar
Quoted: 24 Post(s)
During the Logitech harmony remote setup in my iPad it enabled to configure the iPad as a Bluetooth keyboard. So I am using this for now
Sent from my GT-I9300 using Tapatalk
ofird is offline
Old 07-14-2014, 06:32 AM
AVS Club Gold
Glenee's Avatar
Quoted: 81 Post(s)
Liked: 76
What is this Logitech Harmony Remote for iPad that you speak of ? I am fully interested.
Nothing's Perfect So Stop Expecting It ! Glenee
Glenee is offline
Old 07-14-2014, 07:10 AM
cooknl's Avatar
Quoted: 23 Post(s)
Liked: 25
cooknl is offline
Old 07-14-2014, 07:50 AM
AVS Club Gold
Glenee's Avatar
Quoted: 81 Post(s)
Liked: 76
I got the jest of it. You need a Harmony Ultimate Hub to do this.
Glenee is offline
Old 07-14-2014, 11:40 PM
ofird's Avatar
Quoted: 24 Post(s)
I did to this through the Hub that comes with the harmony ultimate remote.
But, having said that, it makes perfect sense that the iPad itself via BT should be able to connect to Samsung TV and operate as a Bluetooth keyboard.
Worth a try even w/o the Ultimate Hub.
ofird is offline
Old 07-14-2014, 11:42 PM
ofird's Avatar
Quoted: 24 Post(s)
Originally Posted by Ari David View Post
I got a broken link, can you re-share please?
Edit - got it thanks.
ofird is offline
Old 07-15-2014, 08:26 AM
Ari David's Avatar
Fill in
In the place go the "*********"
And the link will work
The forum won't let me post that link for some reason
Ari David is offline
Old 07-15-2014, 08:28 AM
Ari David's Avatar
Here are the actual settings
Picture Mode: Movie
10p White Balance = ON
Interval Red Green Blue
1 -2 0 -2
2 -3 -2 -2
3 -3 -2 -5
4 -4 -1 -3
5 -3 -2 -2
6 -5 -1 1
7 -6 1 3
8 -2 1 2
9 -5 1 7
10 -3 0 -3
Cell Light 15
Contrast 100
Brightness 47
Sharpness 10
Color 52
Tint G51/R49
Color Tone Warm1
Digital Noise Filter OFF
MPEG Noise Filter OFF
HDMI Black Level Normal
Film Mode OFF
Black Tone OFF
Dynamic Contrast OFF
GAMMA -1
Expert Pattern OFF
RGB Only Mode OFF
Color Space Auto
Flesh Tone 0
Edge Enhancement OFF
Motion Lighting OFF
Energy Saving OFF
ECO Sensor OFF
Auto Power OFF OFF
Old 07-21-2014, 12:54 AM
music_to_my_ear's Avatar
Quoted: 185 Post(s)
Liked: 90
Originally Posted by Cleveland Plasma View Post
"decline in overall demand for plasma display panel televisions", that is just not true, they are being discontinued because they could not make a 4K Plasma TV cost effectively . Therefor they could not over charge for new technology . LED is next........ Especially if LG gets there OLED costs down.
I would've LOVED to own a 4k Plasma....the viewing angles and reference black levels.
Definitely would've also waited out past the ZT60 for a 4k ZT70/80 whatever it may have been
*sigh*
music_to_my_ear is offline
Old 07-21-2014, 12:56 AM
Quoted: 185 Post(s)
Liked: 90
What firmware for the F8500 reduces the brightness?
Anybody know which firmware number it was? Im looking at a 65F8500 right now and if it has the older firmware then id most likely buy it and avoid the firmware being updated to avoid the brightness reduction
Good idea?
Old 07-21-2014, 02:14 AM
stanjohn123's Avatar
Quoted: 22 Post(s)
Ok so I'm biting the bullet and going for the 64 inch f8500 today. Only problem is I do not know if it's a 2013 or 2014 model.
Will this matter much ? Is there any difference between the 2014 and 2013 build tv ? I'm buying it for 3030 $. Thanks.
stanjohn123 is offline
Old 07-21-2014, 07:14 AM
AVS Club Gold
Glenee's Avatar
Quoted: 81 Post(s)
Liked: 76
I answered this in the other forum.
I don't think there is any difference. It only verifies that they are still making them.
Glenee is offline
Old 07-21-2014, 07:30 AM
Quoted: 1171 Post(s)
Liked: 519
I've followed this thread from the beginning and it does not appear that there is such a thing as a 2014 model. The 2013 model was kept in production into the time period where 2014s would have been released..
Some etailers/resellers will pitch getting a 2014 model as a means to upsell a buyer. The price you quote also appears a bit high too
Edit: Pricing information is better shared on this thread. http://www.avsforum.com/forum/showth...3#post25856353
JimP is online now
Old 07-21-2014, 07:58 AM
ofird's Avatar
Quoted: 24 Post(s)
Sound output related --
1) I have connected the TV optical out to the AVR optical in (indicated as TV), and I am trying to hear the sound of that input via the AVR (hopefully as 5.1) - but the setting in the sound menu had only PCM enabled and the others were grayed out, if I disable the internal speaker which I don't want to, I have only the DTS NEO enabled...??
My bottom line question is "how to enable digital sound pass through via the optical TV out to the AVR optical In"?
2) ARC - I am using HDMI port 3 - labeled as ARC, I have enable Anynet+CEC on the HDMI in TV Menu (is this required), and selected ARC "on" in the reciver options. Still no sound has been heared from the AVR .
did I do all the right steps?
Appreciate your help!
ofird is offline
Old 07-21-2014, 08:29 AM
Liked: 519
Since you're running optical from the TV to the AVR, its either that you haven't selected the correct input on the AVR or are on the correct input and haven't activated optical or toslink or digital (depending on your AVR) as the input. On my Marantz 8801, there is a setup menu where you select which type of input per input you want active. I assume that other AVRs have something similar to this.
JimP is online now
Old 07-21-2014, 08:31 AM
ofird's Avatar
Quoted: 24 Post(s)
Thanks, will look into this
what setting have you chosen for the TV sound menu under the digital output section?
ofird is offline
Old 07-21-2014, 08:59 AM
caeguy's Avatar
No sure what your source is but I can't get 5.1 from my cable box to the TV and optical from TV to the AVR. I believe this limitation is documented somewhere in the manual. Apps, such as VUDU, will output 5.1 via optical however.
Samsung PN60F8500, Panasonic TH-42PD25U/P, Pioneer VSX-1018TXH-K, Oppo BDP-93, Aperion Audio 5T&5C, HSU STF-2, PS3, Wii, HTPC, SD Homerun Prime, Ceton Echo
caeguy is offline
Old 07-21-2014, 09:41 AM
DanF8500's Avatar
Quoted: 617 Post(s)
Liked: 296
Ofird, this is for you with regards to the optical output limitations of the 8500.
http://support-us.samsung.com/cyber/...igjdzbfTo9UrwY
DanF8500 is offline
Old 07-21-2014, 10:19 AM
Quoted: 22 Post(s)
Thanks for the info. Pricing is right for my country , usually we have high taxes here.
Also I'm just lucky to buy as this model is running out of stock everywhere. Seems like people want to get hold of the last remaining best of plasma TV.
Old 07-21-2014, 01:15 PM
ofird's Avatar
Quoted: 24 Post(s)
Thanks for the info, for my case I am independent of the HDMI, I am using Plex to stream movies from PC to the Samsung TV client.
It works perfect with the opt out - Supporting DP, DPII, DTS and DD (that's the 4 I tried), so I am very happy with this, I didn't try to use ARC yet , will test ARC later.
ofird is offline
Old 07-22-2014, 09:54 AM
Quoted: 22 Post(s)
Good idea?
This is a good idea and something which I would like to know as well. I want that brightness at any cost.
Old 07-22-2014, 10:54 AM
wxman's Avatar
Quoted: 2751 Post(s)
Liked: 1943
The FW would have to be before 1114 and a build date before November 2013. that's what came with the tv I bought in January. Probably have to find out what the initial FW was with the tv. Then you have the issue if you do find one with the initial FW or one prior to 1114, you have rising blacks using cinema smooth.
LG 65EF9500
LG 65E6P
wxman is online now
Old 07-22-2014, 11:28 AM
Quoted: 22 Post(s)
Damn , I think I'm getting a 2014 build tv.
What's rising blacks ? Maybe I can live with that.
Old 07-22-2014, 12:18 PM
wxman's Avatar
Liked: 1943
Since you are getting a 2014 model, the rising black issue has been fixed. You really don't want that with a plasma. Rising blacks reduce overall contrast and blacks do not look as black.
LG 65EF9500
LG 65E6P
wxman is online now
Old 07-22-2014, 12:53 PM
p5browne's Avatar
Quoted: 2391 Post(s)
Liked: 1849
My current settings and fL
Cell at 20 as per Doug Blackburns ABL Posting after he talked to Samsung. Plus - ECO > On > Cell set to 20 > Eco Off. (As per previous findings - don't know if this bug was ever rectified?) And adjust Contrast for your Brightness - Currently, my Contrast is at 84 to give me 32fL, which for my F8500s location, is more than Bright enough. I still have an overhead of 16 Clicks to make Brighter.
p5browne is offline
Old 07-22-2014, 11:51 PM
Quoted: 185 Post(s)
Liked: 90
32 ftL is "bright enough" for you? Dang, I have my set on "day mode" almost 90% of the time which is at least 45-50 ftL anything less and I'm squinting for more brightness
ps: if you have your set with ECO on it should be turned off ASAP. ECO mode on any tv esp plasma tvs will severely reduce brightness and apl range. turn it off and you should see a dramatic difference
Old 07-23-2014, 12:00 AM
Quoted: 185 Post(s)
Liked: 90
Good idea?
Well that sucks....finding a new f8500 with firmware before 1114 and not suffer the rising blacks sounds like a limited engagement lol
I think I may end up getting one with older firmware and having to update it to remove the rising blacks and get the brightness reduced overall
Thanks for the heads up on the firmware though....ill have to see how this pans out
Old 07-23-2014, 02:05 AM
igreg's Avatar
Quoted: 265 Post(s)
Liked: 46
Does the F8500 series have progressive scanning (line doubling) like the Panasonic TH-PD7UY on 1080i source video? Thanks.
igreg is offline
Old 07-23-2014, 04:46 AM
Stereodude's Avatar
Quoted: 2907 Post(s)
Liked: 2091
It has a deinterlacer to display 1080i if that's what you're asking. The panel is a 1080p panel. Everything it displays is ultimately converted to 1080p.
Stereodude is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
