Official Samsung PNxxF8500 Series Discussion Thread [No Street Price Talk] - Page 418 - AVS Forum | Home Theater Discussions And Reviews
 203Likes
post #12511 of 13188 Old 09-14-2014, 11:14 PM
HLdan's Avatar
Quoted: 497 Post(s)
Liked: 228
Originally Posted by fierce_gt View Post
I've been running a pair of these for almost 3yrs now: http://www.memoryexpress.com/Products/MX26907
originally the plan was to use one for my 'front of the room electronics' including the tv, receiver, and game consoles, and one of the 'back of the room electronics', projector, HTPC...
they have been awesome, and have definitely saved me from losing my spot in a game, or work I hadn't saved on the pc. BUT, the 1000VA was not enough for the 64" f8500. when I first got the tv, I thought it had the dreaded 'buzz' because when a bright scene came on I heard this super annoying high pitched electrical buzz. I tried messing with settings and eventually realized it was the UPS behind the tv making the noise. when the tv is drawing max current, it's too much for the UPS to handle. now it might be JUST enough if the tv was the only thing plugged in, I'm not sure, but it's definitely not what I would consider a comfortable fit. my plan now is to get a 1500VA version for the front, give the projector its own dedicated ups, and the htpc which has grown since will get its own UPS. a bit overkill, but I don't really have any better place for the extra 1000VA ups, so why not.
anyway, I would recommend going with something larger, at LEAST 1000VA if the tv will be the only thing on the battery protected side. but moving up to 1500VA is smart imo. then you can plug in a couple other sources if needed, and be fully protected. I had my game console lose power one time while saving years ago, and it erased ALL the save data I had. it was a bit of a major blow actually. many of the games I had save data for I haven't played since. stuff like guitar hero where you have unlocked all the songs suddenly just becomes frustrating to start over
You just hit the nail on the head about the Game Console. My PS4 doesn't like when the power is shut off without shutting it down first. I will look into the 1500VA for my 648500. Appreciate that. I knew I should've looked into these a while back. I ignored the advice about getting one long ago. I will consider one now. Have too much to lose.
HLdan is offline
post #12512 of 13188 Old 09-15-2014, 06:35 AM
Stereodude's Avatar
Quoted: 3102 Post(s)
Liked: 2243
how come?
Because you want to give surges a way into your system via the unprotected printer.
Stereodude is online now
post #12513 of 13188 Old 09-15-2014, 05:03 PM
p5browne's Avatar
Quoted: 2810 Post(s)
Liked: 2134
The only time a laser printer is hard on the UPS, is when the heater element comes on. (This would kick the UPS Off, and anything plugged into it.) Laser Standby mode hardly draws any amperage, and will be running cool. In all the years I've had a laser printer, I've never had issues with it plugged into the wall. But, then again, it's never been running during a power surge, nor power down, power up situation. (Luck of the draw.) Any one of my TV and Stereo systems have at one time or another.
p5browne is offline
post #12514 of 13188 Old 09-25-2014, 12:21 PM
Bndck's Avatar
Samsung Plasma F8500 - wifi problem
I have another issue in my Plasma. i have wi fi network and tv's wi fi reception is ok working fine. because of week signal i put wi fi extender recently. all of my other devices can connect to new extended wi fi network but Samsung TV does not connect. samsung manual says that it does not do i need to set manual IP settings rather automatically?. my Repeater is Dlink DIR 505. how do i setup new wi fi?.
Bndck is offline
post #12515 of 13188 Old 09-25-2014, 03:17 PM
turnne1's Avatar
Quoted: 1755 Post(s)
Liked: 410
they came out and replaced my panel today..under warranty
all seems good
no vertical lines
Warren
Ph8te, Denniswrly and DanF8500 like this.
Rm 1 Samsung 64F8500 Marantz 8801 prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Hisense H50C Yamaha A2050 Celestion 305 speaker system
Rm 3 Panasonic 50ST50 Denon4520 Kef 2005.2 speaker system
Rm 4 Samsung 51E8000 Sony DA5400ES Mirage Omni sat speaker system
turnne1 is offline
post #12516 of 13188 Old 09-30-2014, 12:18 PM
vahighland's Avatar
all seems good
no vertical lines
Warren
Warren, did you have the DSE (dirty screen effect) issue or some other problem with vertical lines/banding?
vahighland is offline
post #12517 of 13188 Old 09-30-2014, 04:28 PM
turnne1's Avatar
Liked: 410
it had 4 small vertical lines down the screen towards the right side
Warren
turnne1 is offline
post #12518 of 13188 Old 10-01-2014, 07:51 AM - Thread Starter
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2033 Post(s)
Liked: 2197
Warren
Amazing that it is worth a screen swap, you would think they would just replace the whole set.
Cleveland Plasma is offline
post #12519 of 13188 Old 10-01-2014, 08:32 AM
turnne1's Avatar
Liked: 410
IME...as this is the 2nd Samsung Tv that has had a panel replaced under warranty
They will replace one panel under warranty
If there are issues with that panel they will then replace the TV....been there done that
Warren
turnne1 is offline
post #12520 of 13188 Old 10-01-2014, 02:46 PM
HeffeMusic's Avatar
Quoted: 178 Post(s)
Liked: 76
Hello all,
I am on the fence about purchasing a 60"F8500. I am coming from an almost 7 year old 60" Panny PZ700u first 1080P panel. How much has the technology improved on the Sammy? Is it worth the upgrade? I just went to BB Magnolia to look at it and they only had a 51" and it was not calibrated. It is really hard to tell how good the set is when it is surrounded by 4K panels blazing lights. Your advice would be appreciated.
Jeff
HeffeMusic is offline
post #12521 of 13188 Old 10-02-2014, 09:33 PM
COLLOSUS76's Avatar
Originally Posted by HeffeMusic View Post
Hello all,
Jeff
Hi there. I haven't been on this site for a long time since I had been enjoying my 65 inch ST30 panny plasma the last few years. That is until a lightning strike near my house blew out my A board and who knows what else.
Well to my surprise I found out Panasonic had stopped making Plasmas last year and Samsung would be this year. I went to ABT Electronics and after debating bought me a 65 inch 4k sony xbr 850 LCD...and that lasted all of two days. I'm sorry to the LCD fans but I just couldn't force myself to keep it. I watch tv from 9 to 11 feet out and while the 4K was cool it didn't blow me away enough to accept all of the LCD flaws.
I had seen the Samsung F8500 in the store but was kind of sold into the, 4K. I took the 4K back and dealt with the store on the Samsung. Had it delivered and as soon as I turned it on I knew this was it for me. With the LCD I already knew it was going back the moment I turned it on at night.
The F8500 is a thing of beauty. To me what this TV offers is worth way more than 4K. Now if they had come out with a 4K plasma display I would have been in heaven.
And I haven't even started messing with the "Smart" features. But tonight while I was watching football the tv asked me if ai wanted to start the sports app and log into my yahoo fantasy football account. When I did I was able to track the scores from the leagues and the all the info for the game itself. Yards drives and TDs. All while watching the game.
So to summarize cause I know I rambled a bit...the F8500 rocks!
psgcdn, HLdan, Tiki Steve and 1 others like this.
COLLOSUS76 is offline
post #12522 of 13188 Old 10-03-2014, 04:57 AM
HeffeMusic's Avatar
Quoted: 178 Post(s)
Liked: 76
Thanks Collosus,
I am currently waiting for the delivery of my new 60" F8500. I bit the Bullet yesterday. I will post my thoughts as soon as I get it. Question did you put the TV through a breakin period? I remember I had to keep all my pic levels down for 100 hrs when I got my first Plazma.
Jeff
post #12523 of 13188 Old 10-03-2014, 07:15 AM
PeterLewis's Avatar
Quoted: 130 Post(s)
Liked: 68
Thanks Collosus,
Jeff
I'am breaking mine in nice and easy....For HDTV viewing I use standard mode with Eco - High and ON.
This keeps the contrast real low for tv shows that have a lot of icons and text.
Then for blu -ray I put it in Cinema default (eco off) but make sure to zoom any 2.40 aspect ratio movies for the first couple of hundred hours.
KONICA TECH likes this.
Sony OLED XBR-65A1E (In my Future )| XBR65X950B|XBR55X900B|2-BR100/Subs|4K X10 Player
Denon - X7200WA|Roku Ultra 4k|PS4
Mirage Omnisat V2 5.1.4 Dolby Atmos set up with SVS PB2000 Sub
PeterLewis is offline
post #12524 of 13188 Old 10-03-2014, 09:17 AM
fierce_gt's Avatar
Quoted: 1629 Post(s)
Liked: 1570
for what it's worth, when I got mine, I adjusted settings to what I felt were 'correct', not lowered beyond that(so contrast was at 95 I think). I did run some slides at night for about a week to speed things up. but really the only precaution I took was I avoided using the tv with my PC for a couple hundred hours. I really believe this is one of the most ir resistant plasmas ever made. or maybe it's just bright enough to hide the ir better than the rest, haha.
Displays: Samsung PN64F8500/JVC X35
AVR: Pioneer VSX-1130K, 7.1/5.1.2 audio
Sources: HTPC(Enby), PS3, XBOX360, Wii
Control: Harmony One
fierce_gt is online now
post #12525 of 13188 Old 10-06-2014, 09:11 AM - Thread Starter
Industry Insider
Liked: 2197
Hello all,
Jeff
With the recent price drops I assume you are over the fence ??
post #12526 of 13188 Old 10-06-2014, 10:26 AM
Cozmo85's Avatar
Quoted: 245 Post(s)
Liked: 92
Guess im joining the club. Got a local store to do $1749 on a brand new 60".
Cozmo85 is offline
post #12527 of 13188 Old 10-06-2014, 08:52 PM
MikeD2's Avatar
Quoted: 17 Post(s)
Thinking hard about pulling the trigger on a 64F8500 now that the prices dropped. I assume any NIB sets (from one of the authorized, major retailers) would come with the 2014 Evo kit stuff already on board ?? Any way to tell for sure from what's printed on the box ?
MikeD2 is offline
post #12528 of 13188 Old 10-06-2014, 09:03 PM
Cozmo85's Avatar
Quoted: 245 Post(s)
Liked: 92
Im betting the current models are exactly the same software wise as the original models.
Cozmo85 is offline
post #12529 of 13188 Old 10-06-2014, 09:04 PM
Ph8te's Avatar
Quoted: 4549 Post(s)
Liked: 3980
No, they wouldn't. If you want the new interface and added benefit of the Evo kit you will have to purchase one. There are no major differences that we know of outside of build date between 2013 builds and 2014 builds. Remember it's not a new 2014 set, but a "carryover" from last year.
I'm lost in the blue nowhere.
Ph8te is online now
post #12530 of 13188 Old 10-07-2014, 08:16 AM
AMartin56's Avatar
Quoted: 1032 Post(s)
Liked: 423
A few quick questions for F8500 owners that may have also hand an opportunity for a lengthy comparison with Panasonic's recent plasmas.
I have a 50ST60. I only have three problems (more like minor issues) with the set: It seems more prone to IR than I expected (no burn in (and I don't expect to ever have any but it's still a bit odd), I see rainbows on it, and I don't like the minor uniformity issues that pop up on my panel with the ABL kicks in on bright content (I was prepared for a potential strobe effect with ABL but this seems worse IMO). 95% of the time the pictures WOWS me, but I want to leave no stone unturned for that remaining 5% before plasma goes poof so I'm considering a F8500.
My only experience with a Samsung plasma was a 4500....It had no IR under similar use and I didn't see any rainbows. And the uniformity seemed perfect. Based on what I can tell Samsung's approach to plasma seems to avoid the issues I'm troubled by on the Panny at the possible expense of slightly higher black levels. Is this a fair summary? I realize there is no perfect display and that you can't tell me what my eyes will see...I'm just curious to see if owners would say my impressions captures the gist of the comparison.
Thanks in advance.
AMartin56 is online now
post #12531 of 13188 Old 10-14-2014, 08:44 AM
khlavkalash's Avatar
Netflix 5.1 over optical out?
I've just set up a new 60" F8500, replacing an 8 year old Pio 42" 720p plasma.
My receiver is too old for ARC (Pio SC-07 with HDMI 1.3a), so I need to use optical for return audio from the Netflix, HBOGo and other apps. I can get 5.1 out from HBOGo, but on Netflix, content with 5.1 only comes through as stereo.
Before I go too far down the rabbit hole, I just wanted to confirm that the Netflix app can output 5.1 over the optical output and it's not a limitation of the app itself.
Loving the TV so far -- it's so much bigger than the previous set that I'm still a bit overwhelmed just turning watching 1080p content. Blacklist on Netflix looks amazing... just wish I had surround sound to go with it!
Gerald
khlavkalash is offline
post #12532 of 13188 Old 10-14-2014, 08:52 AM
Ph8te's Avatar
Liked: 3980
1st things 1st you made sure you selected the 5.1 track for Netflix right?
Ph8te is online now
post #12533 of 13188 Old 10-15-2014, 12:13 AM
My only choice of audio track for Netflix shows/movies that advertise 5.1 in their descriptions is Stereo.
Sound settings for the TV are Speaker Select = External Speaker and Digital Audio Out = Dolby Digital. Receiver is getting Dolby Digital from the TV, but just the stereo audio track.
HBOGo programming with 5.1 audio tracks is sent as Dolby Digital 5.1, so I know the TV can provide surround over the optical cable. I also played an episode of Breaking Bad from Amazon Instant Video with 5.1 audio. I just can't figure out why Netflix isn't even giving me the option for shows and movies that have a 5.1 audio track.
Gerald
post #12534 of 13188 Old 10-15-2014, 12:36 AM
Ph8te's Avatar
Liked: 3980
Gerald
Sounds almost like a NetFlix app or account issue. Maybe try removing then re adding the app? You might need to try a reset of the TV as well. Just remember if you do a reset to copy your settings in case you lose them.
Ph8te is online now
post #12535 of 13188 Old 10-15-2014, 04:33 PM
Gerardo2068's Avatar
Quoted: 263 Post(s)
Liked: 64
So sad Samsung will stop making plasma
Gerardo2068 is offline
post #12536 of 13188 Old 10-15-2014, 08:13 PM
Stereodude's Avatar
Liked: 2243
I cried for days when I heard the news.
I WANT MORE and MK1980 like this.
post #12537 of 13188 Old 10-15-2014, 08:19 PM
Quoted: 263 Post(s)
Liked: 64
I feel your pain
post #12538 of 13188 Old 10-16-2014, 07:39 AM
Netflix is one of the core apps, so I don't think it can be removed. Instead, I reset Smart Hub to defaults and went back through the setup, entering my Netflix account info on first launch. It still only offers stereo.
I don't think it's worth it to try to reset the whole TV. I can fake surround in my receiver with Dolby ProLogicII processing.
I don't watch that much Netflix, outside of Kids programs with my 4 year old. I just was putting a new piece of gear through its paces.
Thanks for your help!
Gerald
post #12539 of 13188 Old 10-16-2014, 10:16 AM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
How bad is the sound coming out of the display's speakers?
I have a surround system, but wife only uses it 20% of the time.
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #12540 of 13188 Old 10-16-2014, 01:02 PM
WantsNWarrants's Avatar
Quoted: 84 Post(s)
Liked: 50
In my opinion, AWFUL. Tinny. Volume must be 60 or higer to hear anything.
This is expected because the panel does not have enough depth to contain a decent speaker.
I use headphones, but if multiple people watched the set, I'd buy a Sammy soundbar.
dsskid likes this.
WantsNWarrants is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
