Official Samsung PNxxF8500 Series Discussion Thread [No Street Price Talk] - Page 420 - AVS Forum
post #12571 of 12600 Old 10-18-2014, 06:07 PM
Liked: 0
Originally Posted by khlavkalash View Post
My only choice of audio track for Netflix shows/movies that advertise 5.1 in their descriptions is Stereo.
Sound settings for the TV are Speaker Select = External Speaker and Digital Audio Out = Dolby Digital. Receiver is getting Dolby Digital from the TV, but just the stereo audio track.
HBOGo programming with 5.1 audio tracks is sent as Dolby Digital 5.1, so I know the TV can provide surround over the optical cable. I also played an episode of Breaking Bad from Amazon Instant Video with 5.1 audio. I just can't figure out why Netflix isn't even giving me the option for shows and movies that have a 5.1 audio track.
Gerald
Can the TV be set to external speakers and 2 channel (PCM) out?
Wyatt Earpe is offline
post #12572 of 12600 Old 10-18-2014, 06:14 PM
AMartin56's Avatar
Quick question.
I'm on my second 51F8500 due to a dead pixel. New set seems fine but it makes a slight pop and crackle noise when you turn it on. The screen also flashes momentarily.
Is that normal? I don't remember the previous set doing that.
AMartin56 is offline
post #12573 of 12600 Old 10-18-2014, 10:33 PM
breezy2012's Avatar
Quoted: 54 Post(s)
Liked: 25
Originally Posted by AMartin56 View Post
Quick question.
Do you have it hooked up to an A/V system or are you using the TV's sound?
breezy2012 is offline
post #12574 of 12600 Old Yesterday, 02:53 AM
AMartin56's Avatar
The TV is hooked up to a sound bar via the optical connection.
But the noise is coming from the panel.
When I turn it on the screen is black but then 'sizzles' slightly as the screen flashes to a slightly brighter black screen. During this flash you see a bit of IR from what was last displayed if you are quickly cycling the power (rather than turning it on after it's been sitting for awhile). if the input is dormant (meaning the Blu-ray player is turned off ) it flashes again (but more briefly) in the same fashion with slightly less 'sizzle' before the no signal message pops up. The panel doesn't buzz otherwise.
My first TV definitely didn't do this, and I don't believe this one did it at first either. At this point it has less than twenty hours on it. I probably shouldn't go looking for trouble since the set works normally otherwise. I just worry that this might be the start of an electrical problem.
post #12575 of 12600 Old Yesterday, 03:51 AM
Quoted: 145 Post(s)
Liked: 195
Originally Posted by I WANT MORE View Post
In my humble opinion the 8500 has excellent sound.
Much better than the Panny vt50.
I currently have both those displays and my experience is just the opposite although I have to admit that I haven't run the 8500 on its internal speakers to break them in.
Once I moved my VT50 to the bedroom, it did sound thin for a while until those speakers broke in. I'm still interested in using some external sound on the VT50 mainly because I've got enough nice equipment in storage that I mind as well use.
Samsung 64F8500, Panasonic 65VT50, Oppo 95, Tivo Roamio for OTA, Dish VIP722, Marantz AV8801 preamp, Rotel Amps, Atlantic Tech 8200 speakers, Seaton Submersive HP, Calman 5, Chromapure, Accupel DVG-5000, i1Display3pro, i1pro2, eecolor colorbox.
JimP is offline
post #12576 of 12600 Old Yesterday, 06:14 AM
AMartin56's Avatar
Here is a video of what my second set looks like when turned on. I couldn't capture the sound it makes but it's just a bit of buzz similar to when full screen white is displayed. My first set didn't do this.
Sorry for the grainy video but I had to keep the file size down.
https://flic.kr/p/prGECs
Is this normal?
post #12577 of 12600 Old Yesterday, 08:20 AM
HLdan's Avatar
Quoted: 169 Post(s)
Liked: 106
Is this normal?
I would say it's not normal since you said the first F8500 you returned for the defective pixel did not do this. I personally have never seen my F8500 do this either.
HLdan is offline
post #12578 of 12600 Old Yesterday, 08:28 AM
DanF8500's Avatar
Quoted: 127 Post(s)
Liked: 166
Is this normal?
What does your 8500 do when you turn it on with an "active" hdmi signal? Your video shows you turned on your set with an inactive hdmi connection. Typically, my tv is the last component I turn on in the hdmi chain. My cable/DVR, AVR, and Blu-ray player always get powered up first before my tv.
DanF8500 is online now
post #12579 of 12600 Old Yesterday, 09:32 AM
AMartin56's Avatar
Thanks for the troubleshooting help.
The set does the same flash when the input is active.
It also does the same thing when I turn the screen off in the menu and then turn it back on.
It might just be my imagination, but the effect seems weaker if the set had been off for awhile but it's still there.
post #12580 of 12600 Old Yesterday, 09:49 AM
RagingTorrent's Avatar
As the last days of Samsung plasmas quickly approaches, I'm still weighing the decision of what I'm going to go with. Had I caught the Walmart $1k deal on the 64" F5300, this would not be a discussion right now. But since I didn't, the debate continues for me.
One question I had after looking at a couple of F8500s in the stores, though. The local HHGreg had an open box (pretty sure it was the 60") sitting on display a couple weekends ago. I turned on the TV and connected Blu-ray player, which played the Transformers sequel. While the black levels and contrast looked amazing, the picture looked very grainy. It stood out on some colors and scenes more than others, but it was there nonetheless. I messed with the settings for a good 5 minutes, but couldn't find anything to take the graininess away. I was rather disappointed, but figured maybe there was something wrong with the unit (being an open box and all).
I was at Fry's yesterday, and the 64" was on display (also with the power off ). I turned it on, and changed it to the HDMI 1 source, which is the feed all the TVs were connected to. Granted, the content wasn't exactly the greatest PQ, the graininess was there again. And again, I played around with the various settings and features, but couldn't find anything that made the graininess go away.
In all honesty, the 8500 series still sits outside of what I'm willing to pay for a TV right now, yet I still can't stop myself from considering it. But now I'm a bit concerned since I noticed this grainy issue on both TVs, regardless of the generic store feed, or the directly connected Blu-ray player feed. Is there something I'm missing in the settings to get rid of this, or is it just the way this display looks?
RagingTorrent is offline
post #12581 of 12600 Old Yesterday, 10:34 AM
Ph8te's Avatar
Quoted: 860 Post(s)
Liked: 532
Some of what you are talking about is film grain. I posted in the owners thread last week I think with 2 good links discussing this. The other may be signal feed and how close you were to the TV. The closer you are the more likely you are to see the flaws in the source material. Depending on what size of TV you are used to you may be surprised about just how bad some "feeds" are.
Sent from an system/360
HLdan likes this.
Ph8te is online now
post #12582 of 12600 Old Yesterday, 01:12 PM
AMartin56's Avatar
I have to turn of my Darbee when watching TF4...the grain on that film slays it. And TF4 looked better on my softer 50ST60. I think with this film the sharpness of the F8500 works against it. All my other blurays look great though. I'll be very satisfied with the F8500 if I can get a working set!
post #12583 of 12600 Old Yesterday, 01:15 PM
TheyCallMeD1's Avatar
PN64F8500 usage
Hello. I apologize to everyone if this has been answered within the tread earlier! But, I recently purchased what's supposed to be a brand new F8500 and have some suspicion that maybe it isn't new after all. One way I was going to check was by seeing how many hours that TV shows as being in use (or has been used). I've only had it on for about 10 hours so anything that's more than a few hours over that would be of some concern to my I suppose. Can someone please tell me how to check or see how many hours my TV has been used or been on up until this point? Thanks in advance for your help. -David
TheyCallMeD1 is offline
post #12584 of 12600 Old Yesterday, 01:20 PM
AMartin56's Avatar
With the TV on press MUTE 7 3 7 ENTER on the remote. You have to do it pretty quickly....it took me a few tries.
MRT shows the hours on the set. My NIB had a MRT of 2. I assume this is a factory test because the box was sealed. Turn off the TV with the power button on the remote to get rid of the menu and don't mess with anything else in there!
post #12585 of 12600 Old Yesterday, 03:10 PM
ozzfan84's Avatar
Quoted: 26 Post(s)
Liked: 0
For those who are just getting these now, does yours have a horizontal band in the middle of the screen? I'm trying to decide if it's worth trying to swap for one without one.
ozzfan84 is online now
post #12586 of 12600 Old Yesterday, 03:17 PM
Cozmo85's Avatar
Quoted: 155 Post(s)
Liked: 59
A BNIB tv should have had 2 heavy plastic straps surrounding it. My tv had zero minutes on it.
Cozmo85 is online now
post #12587 of 12600 Old Yesterday, 09:00 PM
Are you saying the 8500 series brings this out more on pictures? Because the graininess wasn't there on the surrounding TVs, including the H5000 just 2 or 3 TVs down from it. I know the feeds and content aren't the greatest at stores, but I'm saying the 8500 was displaying a graininess that none of the other TVs showed with the same feed, and on the 1st TV, the feed was from a Blu-ray player connected directly to only that TV.
post #12588 of 12600 Old Yesterday, 09:54 PM
Ph8te's Avatar
Quoted: 860 Post(s)
Liked: 532
No I'm saying that the F8500 is usually showing what is supposed to be seen. Film grain is not something you usually want removed. Unless you know the settings the f8500 and the other TVs were on as well as verified the connections and every connection between the TVs and the source the comparison is largely meaningless. This is why I bring a USB loaded with content as well as either bring my harmony or ask for the remote so I can control as much as possible.
Ph8te is online now
post #12589 of 12600 Old Yesterday, 11:30 PM
Liked: 0
Picked up a 60" F8500 last week. Tried to get past the buzzing but during movies with dialogue it was just too annoying... Other than that the set was fantastic.
Paul Trinh is offline
post #12590 of 12600 Old Today, 02:26 AM
igreg's Avatar
Quoted: 108 Post(s)
Liked: 27
Other than my new car pinging and ponging and sounding like a dump truck, I love it!! Are you being sarcastic?
igreg is online now
post #12591 of 12600 Old Today, 10:13 AM
Liked: 0
I'm not. The picture was amazing but I couldn't get over the buzz. Ended up swapping it yesterday for a the 55" LG EC9300.
post #12592 of 12600 Old Today, 10:23 AM
AVS Club Gold
Keenan's Avatar
Quoted: 403 Post(s)
Liked: 428
I've been using my aged and calibrated 64" F8500 for a few days now and I have to say this display is amazing, it actually allows you to see "mistakes" in the production of some content. Things like lighting changes and contact lens color variations mid-scene, probably due to editing different takes together. Camera filters being changed mid-scene resulting in unintentional tone/hue changes. This display is very much like a true monitor that critical inspection of content and even other displays can be measured against.
As you've noted, it very much allows you to see the deficiencies in the source material whether you want to see them or not, personally I prefer to have a display that shows me exactly what's there over one that masks those deficiencies with less than perfect reproduction of the source content. There is no perfect display, but I'm extremely happy with the F8500 as it comes pretty darn close to perfect for me.
As a data point, I have no discernible buzzing at all, and it doesn't get all that warm either. I can run an IR gun around the display later today to spot check areas for temperature if anyone wants to compare with what they think may be an issue with theirs.
Keenan is online now
post #12593 of 12600 Old Today, 10:31 AM
AVS Club Gold
Keenan's Avatar
Quoted: 403 Post(s)
Liked: 428
I do have one problem I'm trying to solve though. Anyone using a Roku 3 with this display and observing what looks to be a color space problem in that the blacks are washed out? Specifically with the Amazon Prime Instant video streaming. Doing some research it seems that, for reasons unknown, the Roku 3 outputs and RGB signal rather than the usual YCbCr and apparently it doesn't play nice with all devices in the chain. I tried hooking it through the Denon X4000 with passthrough and then directly to HDMI 2 and have the same problem. I can use the Dynamic picture setting and the saturation and blacks return but it over-blown, far too vibrant and bright. Any suggestions? Thanks.
P.S. It works perfectly with my old PS3 fattie.
post #12594 of 12600 Old Today, 10:44 AM
Quoted: 145 Post(s)
Liked: 195
Does your prepro allow you to monkey with the color space? i.e. On my Marantz 8801, you can change the output color space so if it was getting RGB it could convert it to YCbCr. How well it would convert it is another matter.
JimP is offline
post #12595 of 12600 Old Today, 10:58 AM
AMartin56's Avatar
Still waiting to hear back from my dealer regarding what they are going to do. I still want a F8500 but hopefully the third time is the charm.
My first set was damn near perfect with an amazing picture other than the stuck green pixel. This current one still acts oddly. I can throw up a full screen white slide and get no buzz. But occasionally it will starting ticking like crazy on a black screen. Which of course is completely opposite of what I would expect.
post #12596 of 12600 Old Today, 12:04 PM
AVS Club Gold
Keenan's Avatar
Quoted: 403 Post(s)
Liked: 428
That's something I just started to look at. It's a Denon X4000 and it does have 3 picture modes for when processing is engaged, Auto(based on what the HDMI signal indicates), Game and Movie. I have not tried Game or Movie, but I'm guessing Game might do the trick as I believe Game would be set to work with a 0-255 range versus the 16-235 or regular YCbCr. I prefer not to have the AVR do anything with the video signal, but if it fixes the Roku problem and leaves everything else untouched I can be happy with that as I'm not looking for studio quality video from $100 streaming device, a proper color space rendition will be just fine!
post #12597 of 12600 Old Today, 01:00 PM
igreg's Avatar
Quoted: 108 Post(s)
Liked: 27
How do you like thr 55" OLED LG EC9300 so far (or has it yet to arrive). Don't really care for the curved screen, but may do the same as you if I don't like the F8500 after it arrives. Tx.
(Consider the 65" OLED model coming out? Big chuck of change, though reports it can be had for $6,2500. What did you pay for the LG EC9300; Best Buy had it down to $2,999 for a while, now back to $3,499.)
igreg is online now
post #12598 of 12600 Old Today, 01:14 PM
Quoted: 145 Post(s)
Liked: 195
Look around the Denon's menu to see if it doesn't show up somewhere else.
JimP is offline
post #12599 of 12600 Old Today, 01:28 PM
ozzfan84's Avatar
Quoted: 26 Post(s)
Liked: 0
Did any of your sets have a horizontal band in the middle of the screen? I'm thinking of rolling the dice to exchange my set that has it because it's very disstracting.
post #12600 of 12600 Old Today, 01:30 PM
DanF8500's Avatar
Quoted: 127 Post(s)
Liked: 166
I do have one problem I'm trying to solve though. Anyone using a Roku 3 with this display and observing what looks to be a color space problem in that the blacks are washed out? Specifically with the Amazon Prime Instant video streaming. Any suggestions? Thanks.
Have you tried using "hdmi black level" on your 8500 when using the Roku 3? HDMI black level setting is active for RGB color space input to the 8500.
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
Gear in this thread - Pn51f8500 by PriceGrabber.com
