Official Samsung PNxxF8500 Series Discussion Thread [No Street Price Talk] - Page 425 - AVS Forum
post #12721 of 12747 Old 10-28-2014, 07:30 PM
KONICA TECH's Avatar
Quoted: 13 Post(s)
Liked: 50
Originally Posted by rlebenson View Post
I've had my 64f8500 for about 4 months. When I watch a movie on my blu-ray player, the picture usually goes to black for a second or two, then comes right back. This happens at least once, most times I watch a blu-ray and has happened ever since I bought the tv. I've swapped hdmi cables and even blu ray players (both are Oppo bdp-93s) The problem still persists. In the last week, this same momentary blackout issue has occurred when I watch recorded shows on my Tivo. A different hdmi port entirely. it's weird, but I haven't noticed this problem watching live tv on the tivo. I am dealing with Samsung right now, but wanted to know whether anyone has had a similar problem. I'm assuming it has something to do with faulty electronics around the hdmi ports inside the tv, but I really don't know what to think.
Try disconnecting the A/C power to the Samsung for about ten minutes then power up. May reset the HDMI ports, otherwise copy all your settings down and try a factory reset in the service menu.
KONICA TECH is offline
post #12722 of 12747 Old 10-28-2014, 07:42 PM
rlebenson's Avatar
Samsung reset the ports yesterday via remote management. I think the issue is beyond a reset, but I will try the unplugging for 10 minutes
rlebenson is offline
post #12723 of 12747 Old 10-28-2014, 08:43 PM
DanF8500's Avatar
Quoted: 181 Post(s)
Liked: 182
When do the 1-2 second blackouts occur? Only once following the pressing of the play button, or throughout the movie?
DanF8500 is offline
post #12724 of 12747 Old 10-29-2014, 04:31 AM
rlebenson's Avatar
When watching a blu ray, the couple seconds of black usually starts shortly after the movie begins. I'd say in the first 5 minutes. If I pause the blu-ray (and shut the tv down) to briefly do something else, the Samsung will repeat the blackout, once again, in the first 5 minutes after replay. I haven't noticed any pattern while watching the tivo, other than it's only happened when i watch a recorded show. This second issue started within the last week.
post #12725 of 12747 Old 10-29-2014, 06:30 AM
DanF8500's Avatar
Quoted: 181 Post(s)
Liked: 182
Ok, thanks for the additional info. What you're describing actually may be normal behavior of the hdmi connection. Have you ever heard of an "hdmi handshake"? It's a standard protocol that's carried out between source components on an hdmi connection to establish a compatible list of settings the two components will use to communicate. A handshake will last a second or so, and when it involves a change of video resolution and/or frame rate on your tv, the video will blank. This happens all the time for me when I change a channel on my native video output FIOS DVR. Every time my 8500 receives a "change" of video resolution from a broadcasted channel from my DVR (i.e. from 720p to 1080i or vice versa), an hdmi handshake will be carried out, and the video will blank for a second or two before displaying the new channel. Your cable box (Tivo) may set its video channel output at a defined resolution (i.e. 1080i), so there would be no hdmi handshake necessary between your tv and cable box from one channel change to the next, thus no blanking screen will be seen. On your blu-ray player, I suspect when your player outputs 24Hz frame rate (typical for blu-ray movies), while your tv is presently in a 1080/60 Hz video resolution, an hdmi handshake will happen when your tv has to switch to the 24Hz frame rate. Once the tv has switched to the 24Hz frame rate (while watching your movie), no additional hdmi handshakes are needed. I would try turning off 24Hz output from your Oppo player (let Oppo player convert movie to 60Hz output), and that may stop the initial video blank upon playing your blu-ray movies because your 8500's standard/native frame rate on power up is 60Hz.
DanF8500 is offline
post #12726 of 12747 Old 10-29-2014, 07:32 AM - Thread Starter
Cleveland Plasma's Avatar
Quoted: 485 Post(s)
Liked: 654
Originally Posted by dsskid View Post
But there are plenty of reviews between the two that can be found online.
The most important thing is the VT60 are a rip off now.
However to answer the question, more or less a tie. The Panasonic does better in some area's and the Samsung does better in other area's. Seeing how the samsung's are priced, easy choice now........
dsskid and eric3316 like this.
Cleveland Plasma is offline
post #12727 of 12747 Old 10-29-2014, 08:18 AM
rlebenson's Avatar
DanF8500, I think it could be a handshake issue, but this tv replaced a Samsung 63c8000. I never had this momentary dip to black with the older Samsung and the same Tivo or Oppo. Also, I currently also own a 60e7000, with a tivo and Oppo hooked up to the tv. I have never had a that tv go to black while watching a blu ray or tivo, either. So, I wonder whether it's faulty ports inside the 8500. I just want to try and figure this out before I call Samsung again. My fear is that the hdmi ports inside the tv may eventually stop working altogether. I hope to figure this out before the warranty period ends. Thanks for your commens.
post #12728 of 12747 Old 10-29-2014, 08:29 AM
DanF8500's Avatar
Quoted: 181 Post(s)
Liked: 182
^ If it was a faulty port on your tv, I suspect your Tivo connection (all your connected devices) would be blanking also. The fact that it functions fine watching tv broadcasts suggests your hdmi ports are not going bad. I've seen a good number of owners complaining about 1-2 second blanking video on the Oppo forums. Almost every one of those posts was the result of hdmi handshaking.
DanF8500 is offline
post #12729 of 12747 Old 10-29-2014, 11:20 PM
oddmania's Avatar
Thinking of buying Darbee 5100,connecting it from my oppo 103 to the f8500.
Any idea if it will enhance picture quality or I won't see much difference.
oddmania is offline
post #12730 of 12747 Old 10-30-2014, 04:40 AM
AMartin56's Avatar
Quoted: 31 Post(s)
I LOVED my Darbee when I had a ST60.To me the F8500 is noticeably sharper than the Panny and putting the Darbee effect on top of this sharpness looks bad to me. I haven't experimented with the Darbee set at less than what I ran before (45%) but for now I leave it off. I'll save it in case I ever get a projector.
AMartin56 is offline
post #12731 of 12747 Old 10-30-2014, 08:29 AM
mightymouseusf's Avatar
Quoted: 21 Post(s)
Liked: 30
I get the same thing sometimes and I'm pretty sure it's not handshake related as it happens to me mid-gaming session when there is no change in resolution. I just always figured it was my receiver hdmi port being wonky, but if it's happening to other users then I may need to reevaluate.
While the game doesn't change resolution mid session, frame rate can dip and rise depending on how taxed the console is being. That might cause the tv to request a new handshake. That wouldn't explain your issue during blu ray watching though.
mightymouseusf is offline
post #12732 of 12747 Old 10-30-2014, 09:01 AM
pochoboy's Avatar
I was thinking 103d, could you experiment a bit further for us?
pochoboy is offline
post #12733 of 12747 Old 10-30-2014, 09:42 AM
AMartin56's Avatar
Quoted: 31 Post(s)
I'm not sure how helpful I can be beyond the opinion I gave above.
None of my observations will be scientific... Being based upon my perception and preferences... And if I have to lower the Darbee setting below what many consider the 45% sweet spot IMO you might as well leave it off or save the money.
I DO like the Darbee. Just not with this TV. The F8500 already shows enough detail IMO and the Darbee seemed to make film grain pop more than I like. For me the Darbee effect was much more pleasing with the softer ST60.
post #12734 of 12747 Old 10-30-2014, 08:13 PM
Liked: 0
Would you think that since the Darbee is not needed then just a Samsung Blu Ray player (or equivalent) would produce as good of image on Blu Ray as an Oppo?
I ask because I ordered this TV and I was also thinking of an Oppo 103D, but then I thought I may not see a difference over just a say a BD-H5900?
Wyatt Earpe is offline
post #12735 of 12747 Old 10-30-2014, 08:26 PM
CJayB's Avatar
Liked: 38
I agree that the Darbee seems to be more effective with the Panasonics, the ST50, that I sold, in my case. On the 8500 I still use the Darbee, but keep it at 30%, barely noticeable, and once in awhile at 35%. By 40% I don't like it at all, at least for blu-rays. If I didn't already own a Darbee I doubt I would now feel the need for it at $300.
CJayB is offline
post #12736 of 12747 Old 10-30-2014, 08:27 PM
DanF8500's Avatar
Quoted: 181 Post(s)
Liked: 182
Don't decide to buy an Oppo player if your only criteria is better image for blu-ray disks. Most blu-ray players on the market are very competitive in their ability to read HD digital media and stream (bitstream or LPCM) it out hdmi . Buy an Oppo player for their build quality (built to last), for their superior support (phone and email), great resale value, superior upscaler of standard def video (i.e. DVD's), not to mention a great network media player that plays just about every audio/video format/codec you can throw at it via DLNA, SMB, or attached usb thumb drive.
DanF8500 is offline
post #12737 of 12747 Old Yesterday, 04:44 AM
AMartin56's Avatar
Quoted: 31 Post(s)
Good summary of the benefits of an Oppo.
post #12738 of 12747 Old Yesterday, 06:20 AM
dsskid's Avatar
Quoted: 97 Post(s)
Liked: 158
Originally Posted by pitviper33 View Post
Maybe somebody with soundbar experience can step in. I've never used one or even looked at them, so this is speculation. I imagine you'll get sound to the soundbar via the optical port on the TV. If that's the case, I don't think the TV will have any way to control power state or volume. Maybe there's a soundbar out there that can hook up via HDMI and then communicate power state and volume level using HDMI CEC protocol. I don't know, but that's what I'd look into.
I'm looking at getting one of these.....Denon DHT-S514. From the few reviews I've read, it sounded like a good option.
You can hook it up via ARC HDMI, Optical, etc. Comes with a wireless sub.
The thing I really like about it is that the unit can learn/be programmed to go on and off with the display, and volume control with any remote (Display/Fios/Cable/Universal), so it can really be seamless, which will make my wife happy. When I want to use my existing 5.1 system, I can just power off the soundbar seperate from the display, and power up the receiver. Anyone have any first-hand knowledge/experience with this item?
By the way, my wife turned to me last night and told me how good she thought the new Samsung looked (not yet calibrated). Normally she would say she didn't know why I upgraded, the old one was fine. Last night she said it was an excellent choice and she was happy I bought it. Woo Hoo for the WAF.
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #12739 of 12747 Old Yesterday, 07:11 AM
marcelo19lp's Avatar
Quoted: 13 Post(s)
The noise on the TV is not that bad. Sounds louder than my Samsung 5054 plasma, but then again that model is like 3 inches thicker, who knows? Actually my old plasma makes no buzz or anything. It now sits wrapped up underneath my bed jajaja. I read here, that since its so narrow like LED, that can lead to the buzz to be more louder. Doesn't bother me, I could hear it, of course if you put your ears in the back. My has a built date of 8/2014. The sound is louder in the right rear upper panel, as oppose to the left upper rear panel. I sit about 8 feet away and on mute, I hear the buzz, but I could also hear my PC's fan on. I guess it comes down to me to how sensitive you are to it. I saw SEVEN last night, and boy that thing is pitch BLACK and the colors just pop up! I did notice while in mute at the sitting position, the center buzz, than again, I don't watch tv in mute, so once the soundbar kicks in, its out of the way. I didn't change anything, or look into the TV too much. To me, its perfect the way it is. I have comcast, trying to figure out how the IR works? Its connecteed, but I still have to use my cable box to change channels, info etc. One thing I like with the previous Plasma, once I hit INFO, I would get the info on the screen resolution and hz. Here you get a one time view once the tv recognizes the signal, I tried hiting info on the control, all i get is a red light blinking from the TV. I have my computer, cable box and ps3 connected to the Sony HT-CT660 sounbar and one HDMI output to the TV, so i'm just using the HDMI 1/ARC connection on the TV. My soundbar connects to the TV, when I press sound up on the sounbar, it goes up, but I also see the volume up on the screen as well, anyway to turn this off? I adjusted the resolution and pan scan on my video card. Looks pretty normal, but when I transfer the web browser such as Chrome to the plasma and blow it up, I can see the entire thing, however the upper controls such as go back, forward, adjust screen, cannot be seen, looks like it enter full mode? This wasn't a problem on my previous plasma? Do I have to set this up to PC mode, and if so, how do I do that, since I Read about re-naming it. I can't rename it, because everthing is connected to the soundbar and has only one outuput? Any suggestions? Also this came with 3 ferrite cores, in which none, fit the power cable fit and tight, very loose and falls down. The width is like twice as big as the power cable?
marcelo19lp is offline
post #12740 of 12747 Old Yesterday, 07:38 AM
dsskid's Avatar
Quoted: 97 Post(s)
Liked: 158
Yes, go to Screen Menu > Sound> Speaker Settings > Speaker Select .....then select the external speakers
ISF Calibrator
Samsung PN64F8500
dsskid is offline
post #12741 of 12747 Old Yesterday, 07:47 AM
Quoted: 13 Post(s)
Yes, go to Screen Menu > Sound > Speaker Settings > Speaker Select. Then select external speakers.
Thanks! This TV is awesome! 2 many things to play with, 2 little time. My smart TV is actually my PC, which I use to do all my things i7-4790K, having it connected to the TV is great. Just have to figure out this PC mode thing. For me this works amazing. Will the SEK 2000 only update smart features? Any hardware update to that. The SEK 2000 Came with the TV package I got.
post #12742 of 12747 Old Yesterday, 08:05 AM
pitviper33's Avatar
Quoted: 49 Post(s)
Liked: 35
Do you plan to put the display on top of that? It's only 24" wide. Just be careful if you are. I temporarily placed my (previous) F8500 on a stand that was slightly too narrow, and it was quite unstable without the ends of the stand supported.
I'm not into "thumbs upping" or "liking". Don't take it personally. Just assume that I found your post helpful. Unless it wasn't.
pitviper33 is offline
post #12743 of 12747 Old Yesterday, 08:12 AM
dsskid's Avatar
Quoted: 97 Post(s)
Liked: 158
Right now I have my Front speakers for my 5.1 below the TV (no room/placement for towers unfortunately), so I'm going to mount the soundbar above.
I apologize for the crappy pic, but it was from my cellphone.
ISF Calibrator
Samsung PN64F8500
dsskid is offline
post #12744 of 12747 Old Yesterday, 08:17 AM
pitviper33's Avatar
Quoted: 49 Post(s)
Liked: 35
No room for towers is right!
Just an idea: The soundbar is under 10 pounds. You could probably support it from the TV itself. I did this with a center speaker in my previous house. I built a simple shelf off of the VESA mounting points on my D8000. I thought it created a cleaner look than mounting a shelf to the wall and running wires to that shelf.
post #12745 of 12747 Old Yesterday, 08:27 AM
dsskid's Avatar
Quoted: 97 Post(s)
Liked: 158
I used to have the three speakers on top, utilizing three of these, but I think they may be too deep now:
ISF Calibrator
Samsung PN64F8500
dsskid is offline
post #12746 of 12747 Old Yesterday, 09:02 AM - Thread Starter
Quoted: 485 Post(s)
Liked: 654
Very few complaints, most like it.
post #12747 of 12747 Old Yesterday, 03:29 PM
rlebenson's Avatar
DanF8500, I believe I solved much of this hdmi handshake riddle, thanks to you. When I originally setup the Oppo, I set the Output resolution to 1080p and set 1080p24 output to On. Sometime, during a recent firmware update, the settings reverted back to Auto on both those settings. After I changed the settings back to my original settings, the blackouts stopped. Now, I will work on the Tivo hdmi port, that infrequently blacks out. Still, I no longer think it a problem with the Samsung F8500.
post #12748 of 12747 Old Yesterday, 03:55 PM
DanF8500's Avatar
Quoted: 181 Post(s)
Liked: 182
That's good to hear! Yeah, gotta watch out for those settings on the Oppo player. There's a feature in the Oppo firmware where you can save your current Oppo settings to a usb drive for safe keeping, and then restore them if you need to in the future. Maybe you've been using that feature, but it saves you from having to input each one in case your machine gets reset to factory defaults.
Edit: Sorry, I forgot you have 2 BDP-93's. I think the 103/105 series only have the save/restore feature. My bad.
DanF8500 is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
Gear in this thread - Pn51f8500 by PriceGrabber.com
