Official Samsung PNxxF8500 Series Discussion Thread [No Street Price Talk] - Page 426 - AVS Forum
post #12751 of 12772 Old 11-02-2014, 01:06 AM
Liked: 0
Hi everyone. So I'm a bit bummed here. I bought the Samsung 51 inch 8500 series. For the first 100 hours, I broke it in using the dl disc that I got from this site that shows colors every so often. It took me awhile to do since I was away from the house so it took almost 2 weeks. So I set up my tv 3 days ago and was planning to watch 100 hours of hd movies with no static imaging before I calibrate it. Getting excited about setting up arguably Samsung's best tv ever. But than...
After just an hour or so of watching an HD movie without messing with the settings, I got some major eye strain, headache, and overall puky feeling. Now this is my second Samsung plasma. I owned a 42 inch Samsung Plasma before with no problems. This is the kind of feeling I get when I watch LED. It's the reason why I purchased this last Plasma because I thought I wouldn't get this.
I turned off Dejudder and all the other fancy settings. I think it's a bit better but I still get eye strain from it. So my question is.... Is this something I can correct with messing with the settings? Do I need to just get used to this? Will a lamp behind the tv help?
Thanks everybody. I'm kinda screwed here since I can't return it anymore. I only had 15 days to return it.
Johnny Chingas is offline
post #12752 of 12772 Old 11-02-2014, 01:34 AM
Liked: 0
Originally Posted by conan48 View Post
Looking to pull the trigger on the 64" model.
Can you guys just help me with a couple of questions?
Keep seeing different reports everywhere on input lag. I will be using this display for lots of gaming, and I'm wondering what is the best possible input lag that is achievable on this display. I have heard that renaming the input to PC drops the input lag, but AVforums review said it was still high at 60ms
Also, I'm a huge 3D fan, and I'm looking for experienced 3D fanatics to give me the lowdown on 3D quality. How would you rate the 3D in comparison to all other displays you've tried?
Depends if you're a hardcore competitive gamer. If you're a casual gamer, than the input lag on PC will be non-existent. If you play a lot of FPS multiplayer games, than those 1 on 1 battles may be slightly unfair if your opponent has a better monitor.
post #12753 of 12772 Old 11-02-2014, 05:57 AM
AMartin56's Avatar
Quoted: 120 Post(s)
Liked: 35
I suppose it's possible that some sort of flicker is bothering you but I'm sensitive to flicker and my F8500 doesn't bother me.
You might try feeding it a 1080p24 bluray with Cinema Smooth on to see if that makes you sick.
AMartin56 is online now
post #12754 of 12772 Old 11-02-2014, 06:00 AM
AMartin56's Avatar
Quoted: 120 Post(s)
Liked: 35
Also Google 'motion sickness with plasma tv'. Plenty of people talking about it.
post #12755 of 12772 Old 11-02-2014, 06:32 AM
zoyd's Avatar
Quoted: 378 Post(s)
Liked: 409
The F8500 does produce more noticeable flicker in very bright scenes than my D series, try sitting a little further away and lowering cell light (or adding more room light) until you find a comfortable viewing level.
zoyd is online now
post #12756 of 12772 Old 11-02-2014, 11:50 PM
Liked: 0
Thanks guys. So doing some research, it looks like it's something that can be corrected which is a big relief because i like this tv.
Would the feed off my Comcast box also cause a problem? Will Blurays be a better viewing experience? How is the refresh rate on this set? The only hd i watched was from Encore which i know is not full HD.
A friend messaged me about a light that helps by putting it behind the set. Thanks man. I wasn't able to message you back. Helps with eye strain.
post #12757 of 12772 Old 11-04-2014, 12:38 PM - Thread Starter
Cleveland Plasma's Avatar
Quoted: 520 Post(s)
Liked: 689
Good thing I do not get that, one more thing to be grateful for......
Cleveland Plasma is offline
post #12758 of 12772 Old 11-20-2014, 09:11 AM
p5browne's Avatar
Quoted: 152 Post(s)
Liked: 200
Might not be the TV, there's a vertigo virus going around. Quite a few people that I've reference to have been complaining about it, including me. (Just great when you're trying to shovel the snow in the driveway, and make a quick turn to go back the other way.)
p5browne is online now
post #12759 of 12772 Old 11-21-2014, 12:35 AM
Halimali's Avatar
Liked: 49
Thumbs down
After 18 months of owning this TV it stopped working.
There is no picture, black screen but sound is working when I press the volume buttons or menu buttons.
When I turn it on the red light blinks 10 times with 3-4 seconds intervals and then after that it blinks 4 fast blinks.
The problem started few weeks ago and I had to switch the TV on and off several times until the picture comes up. Now it does not come up.
I called Samsung, they came and took the TV to repair it. The technician who came said it might be a problem with the power supply or the panel itself. Yesterday they called me to say that it will take one week to get the faulty part replaced but before that they will give me the estimated cost of reparing it.
This really sucks big time, a Premium TV like that should be problem free at least for the first 3 years. I have LCD and LED TVs from Sony, some are more than 10 years and none of them ever had any problem and went for a repair! This TV is my first Samsung TV & first Plasma and this is my experience!! The picture quality is great but what is the use if the build quality of what is inside is like that?
Did anybody face anything like my problem with this TV?
As of June 2013:
2,712 Bluray movies
1,593 DVD movies
356 bluray+DVD series
1,322 bluray+DVD Anime
Halimali is offline
post #12760 of 12772 Old 11-21-2014, 09:28 AM
JRWalker's Avatar
Liked: 37
Originally Posted by Halimali View Post
After 18 months of owning this TV it stopped working. . . .
Samsung's Manual at http://media.datatail.com/docs/manual/145730_en.pdf Page 26 in the "Providing Proper Ventilation for Your TV" section states:
"When you install your TV, maintain a distance of at least 4 inches between the TV and other objects (walls, cabinet sides, etc.) to ensure proper ventilation. Failing to maintain proper ventilation may result in a fire or a problem with the product caused by an increase in its internal temperature."
You once posted a picture of your new TV in a solid backed cabinet with a narrow gap around the screen. I warned you about the ventilation problem and 4" requirements at the time. If you put your repaired TV back in the same cabinet then you can expect it will work for about 18 months, maybe less.
JRWalker is online now
post #12761 of 12772 Old 11-21-2014, 10:36 AM
dsskid's Avatar
Quoted: 116 Post(s)
Liked: 163
You once posted a picture of your new TV in a solid backed cabinet with a narrow gap around the screen. I warned you about the ventilation problem and 4" requirements at the time. If you put your repaired TV back in the same cabinet then you can expect it too will work for about 18 months, maybe less.
Good point. I have mine wall mounted with an older mount that keeps it roughly 4" away, just for that reason.
What puzzles me is why they list one of those ultra-flush mounting kits (two circles? with a cable) as an accessory for this tv, which contradicts the manual.
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #12762 of 12772 Old 11-21-2014, 10:44 AM
JRWalker's Avatar
Liked: 37
Marketing always trumps Engineering!
Can't imagine using the ultra-flush mounting kit with an EVO kit.
Added 5 fans to my TV and the entire back of the set stays at room temperature. The fan exhaust temperatures stabilize at about 7 degrees F above inlet temperature with the fans set to a speed which makes them inaudible at viewing distance.
I posted pictures and instructions in one of my first posts to this thread:
Forum conversion broke links in above post. Trying to fix old links corrupts post. Continued here:
post #12763 of 12772 Old 11-21-2014, 11:21 AM
breezy2012's Avatar
Quoted: 68 Post(s)
Liked: 26
I guess I'm glad I have mine sitting on a TV table.
breezy2012 is online now
post #12764 of 12772 Old 11-21-2014, 12:00 PM
p5browne's Avatar
Quoted: 152 Post(s)
Liked: 200
Have a single fan after losing a MB in the first month.
Why Members refuse to take preventative action, and instead quote `There's nothing in the Manual about a fan!'. There's different elevations - the higher you go, the harder it is on a Plasma. There's different climatic degree variations. There's different power fluctuations. Clean/dirty power issues. There's electrical and electronic interferences. A good 750 VA or greater UPS, plus a ventilation fan at least over the upper left hand corner, does wonders. Why are Members so opposed to safe guarding a few thousand dollar investment - got me?
post #12765 of 12772 Old 11-21-2014, 12:05 PM
pitviper33's Avatar
Quoted: 66 Post(s)
Liked: 39
My interpretation of the photo in the manual was that there was to be minimum clearance on the sides, top, and bottom of the display. I didn't read it as minimum space behind the panel. To me, the suggested mounting kit confirmed this idea. Now you've got me wondering if I interpreted it incorrectly.
pitviper33 is offline
post #12766 of 12772 Old 11-21-2014, 12:14 PM
JRWalker's Avatar
Liked: 37
Following the manufacture's minimum recommendations to me means that unit is not likely to fail in the warranty period. But of course I am a cynic who believe that Murphy was an optimist.
post #12767 of 12772 Old 11-21-2014, 12:24 PM
pitviper33's Avatar
Quoted: 66 Post(s)
Liked: 39
You could be right. I come from a very different industry. One where I don't even know what the warranty period is on the products I'm developing. I design for and recommend service intervals for infinite life. Probably for that reason, my first instinct is "Do what they said in the manual and you'll be fine." I should maybe be more careful/skeptical about assuming other industries do the same.
Oh well. I know they didn't design for forced convection. Hopefully whatever impediment to natural convection I've created is offset by the fans.
post #12768 of 12772 Old 11-21-2014, 01:07 PM
dsskid's Avatar
Quoted: 116 Post(s)
Liked: 163
After taking a look, perhaps I was wrong. The clearance in the manual may just be referring to top and sides and not rear.
ISF Calibrator
Samsung PN64F8500
dsskid is offline
post #12769 of 12772 Old 11-21-2014, 01:47 PM
Halimali's Avatar
Liked: 49
@JRWalker Thank you for your reply. That was the first thing I asked the technician who came to check the TV and he said my ventilation is more than enough.
Let me tell you how the cabient is:
The back of the cabient is not solid it has many circular 4 inch holes. There is another 3-4 inch between the wall and back of the cabient. The space between the back of the TV and the back of the cabient is 9 inch.
Then there is 3 inch space on the left and 3 inches on the right side.
There is another 12 inches space from the upper side of the TV until the upper end of the cabient.
So the TV has enough space on all sides. Even the technician who brought the TV said my setup would give the TV better ventilation from the back than mounting it on the wall.
Whenever the TV is on the air conditioner in that room is on too. Touching the metal stand or the back of the tv shows how cool it is when it is switched on even for long hours.
The fault is still unknown, I just hope it is not the panel because it is hard to look for another good TV. I don't want a LED TV. Plasma choices are limited and this TV suits my needs more than any other plasma TV.
Hopefully I will know in a week of time what needs to be done.
As of June 2013:
2,712 Bluray movies
1,593 DVD movies
Halimali is offline
post #12770 of 12772 Old 11-21-2014, 02:59 PM
JRWalker's Avatar
Liked: 37
@Halimali Below is your picture that I remembered. It does not show if your drapes cover the cabinet back on the left, which is always the hottest area of the set, nor the distance the cabinet is from the wall.
Hope that get your set fixed soon.
post #12771 of 12772 Old 11-21-2014, 05:13 PM
Ice That Jaw's Avatar
Quoted: 13 Post(s)
All of sudden, about 3 days ago, the anynet+ stopped working and now I can't get it to recognize my receiver! This is extremely frustrating and now my receiver and speakers are useless and I can't use headphones late at night.
Maybe it was part of the last update?
Djohm likes this.
LNT-4665F
T-TULPAUS0-1036, Aug 24 2007
T-TULPAUS5-1011 CS[D652] [46(AMV)-inch]
PS3
XBOX 360
Crappy Sound Reciever
Ice That Jaw is offline
post #12772 of 12772 Old Today, 10:15 AM
hpp8140's Avatar
Quoted: 14 Post(s)
1203 is causing my tv to lockup randomly. Never happened before the update....sigh
hpp8140 is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
Gear in this thread - Pn51f8500 by PriceGrabber.com
