Official Samsung PNxxF8500 Series Discussion Thread [No Street Price Talk] - Page 427 - AVS Forum | Home Theater Discussions And Reviews
 217Likes
post #12781 of 13194 Old 11-24-2014, 04:29 AM
dsskid's Avatar
Quoted: 271 Post(s)
Liked: 258
The Oled does look better, but not without it's own issues.
Screen uniformity, some image retention and motion issues, is curved, and is 55".
The 65" is $9,000.
Also, it's o it's own loop. Ask them to put something other than that loop on when you look at it.
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #12782 of 13194 Old 11-24-2014, 05:34 AM
AMartin56's Avatar
Quoted: 2156 Post(s)
Liked: 1130
Personally I couldn't justify a OLED right now due to what dsskid points out. The F8500 is a great set until OLED matures a bit.
AMartin56 is online now
post #12783 of 13194 Old 11-24-2014, 08:48 AM
JRWalker's Avatar
Quoted: 41 Post(s)
Liked: 54
@Halimali From your picture and posted information, your 64" TV is in a cabinet that does not provide Samsung's minimum ventilation requirements.
The most common cause of capacitor failure is environmental heat. The plague of bad capacitors have not be used in electronics for several years before your set was built. The components in electronic equipment need a flow of cool air while operating. In your TV, air enters the vents along the bottom of the back of the set, the air picks up heat from the electronics, then exits the vents at the back top. If there is not adequate air flow in and out of the cabinet then the temperature of the air entering the set will increase to above the maximum recommended operation temperature of 104 degrees F.
I can not advise you what must be done to bring the cabinet's ventilation up to the minimum ventilation level. There are ways that air flow can be increased in a cabinet such as:
o adding fans to push cool air in and other fans to blow hot air out (providing flow both in and out is important), and/or
o cutting vent holes in the sides and/or shelves above and/or below the set, while maintaining structural integrity.
Others on this forum are invited post their views to help Halimali.
Halimali likes this.
JRWalker is offline
post #12784 of 13194 Old 11-24-2014, 03:48 PM
Salacak's Avatar
Quoted: 353 Post(s)
Liked: 83
After several attempts to get good 4K tv i just gave up on it and decided to wait for technology to correct LED / Edge lid problems.
Any of you can tell me on black levels and picture quality differences between Samsung PN60F8500 and Samsung PN60F5300 B version panel.
Salacak is online now
post #12785 of 13194 Old 11-24-2014, 09:22 PM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 217
Black levels are pretty much the same in a dark room. F5300 may measure a little lower if you have a newer F8500 with updated firmware.
StinDaWg is offline
post #12786 of 13194 Old 11-24-2014, 09:35 PM
WPWoodJr's Avatar
Quoted: 97 Post(s)
Can anyone tell me where the Eco Sensor is on the 60" F8500? I don't want to block it inadvertently. I like having it on (you can set the minimum cell light that it will go to), so you can have one setting that works for day and night.
Samsung PN60F8500, TiVo Roamio, ASRock Vision 3D HTPC, Chromecast
WPWoodJr is offline
post #12787 of 13194 Old 11-25-2014, 04:48 AM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
zoyd is offline
post #12788 of 13194 Old 11-25-2014, 10:49 AM
Halimali's Avatar
Liked: 50
Today I got the TV back after the repair.
I want to thank you for your input and advise.
I'm going to do what you advised me.
I'm ditching the whole cabinet and will replace it with a TV stand so that the whole TV will be exposed to air from all the sides.
I would also be interested to know how to add fans to the set. Would really appreciate your help in guiding me how that can be done.
I love this TV and don't want it to fail on me again.
As of June 2013:
2,712 Bluray movies
1,593 DVD movies
356 bluray+DVD series
1,322 bluray+DVD Anime
Halimali is offline
post #12789 of 13194 Old 11-25-2014, 12:10 PM
p5browne's Avatar
Quoted: 3132 Post(s)
Liked: 2447
Model Mobile Fan 12 (P/N: AF0007) - plug into lowest USB Port and adjust to about 50% speed. Will lower the temp about 10 or more degrees.
Blue Rain and Halimali like this.
p5browne is offline
post #12790 of 13194 Old 11-27-2014, 03:17 AM
Halimali's Avatar
Liked: 50
Thank you very much.
Would one fan be enough? I see from the picture that you have placed it in the middle. How about fixing it on the left spot where the TV gets hotter?
Does the fan make any noise?
As of June 2013:
2,712 Bluray movies
1,593 DVD movies
Halimali is offline
post #12791 of 13194 Old 11-27-2014, 07:18 AM
p5browne's Avatar
Liked: 2447
The fan is actually on the back left, over the hot spot. Found fan at 50% more than adequate, and can't be heard. At 100%, fan can be heard, but whether from your seating position I don't know. I adjust right at the fan by turning up to I just hear it. Being plugged into the lowest USB Port, it turns On and Off with the set.
p5browne is offline
post #12792 of 13194 Old 11-27-2014, 09:57 AM
cooknl's Avatar
Quoted: 23 Post(s)
Liked: 25
Halimali here are some more pics to give u some ideas for mounting the fan(s).
I used small tiewraps to mount thru the existing vent holes, the tiewraps fit just through the holes.
As u see in my pics I used 4 fans 2 x 120mm and 2 x 80mm the small ones are mounted in the middle and the bigger ones on the outside as seen from the back, the way my pics were taken.
As far as noise is concerned all 3 fans not above the hotspot are turned all the way down (slowest fan speed) only the one above the main board with all the hdmi and USB plugs is set to medium speed, you will hear some fan noise when the sound of the TV is muted but when you are watching a program or video with sound there is no additional noise detectable in my case.
Anyway these fans both the big ones and the smaller ones are avavailable from amazon and are very inexpensive for the money thy save u in repairs.
Hope this info helps you a bit.
Rob
ID:	388785   Click image for larger version
ID:	388793   Click image for larger version
ID:	388801   Click image for larger version
ID:	388809   Click image for larger version
cooknl is offline
post #12793 of 13194 Old 11-27-2014, 11:07 AM
HLdan's Avatar
Quoted: 497 Post(s)
Liked: 228
Repairs? Was it confirmed by Samsung or any trained professional that the F8500's overheat to a point of defect and recommending people to install fans? The F8500 should be able to dissipate heat on it's own quite well. It's only fault from what I've seen is heating up the room, but I know nothing of fans needing to be installed to protect it from becoming defective from overheating. Please clarify this.
HLdan is offline
post #12794 of 13194 Old 11-27-2014, 12:13 PM
p5browne's Avatar
Liked: 2447
Are you at sea level, or up in the Mountains? The higher, the harder on Plasmas. The ventilation does make a difference - just make sure the fan is blowing out, not in.
p5browne is offline
post #12795 of 13194 Old 11-27-2014, 12:18 PM
HLdan's Avatar
Quoted: 497 Post(s)
Liked: 228
I'm at sea level. I wasn't aware it would get that much hotter in the mountains. I do know Samsung said that's why the buzz gets louder, due to the elevation levels.
HLdan is offline
post #12796 of 13194 Old 11-27-2014, 01:50 PM
p5browne's Avatar
Liked: 2447
I'm going to assume that the atmospheric pressure somehow affects the plasma cell walls?
p5browne is offline
post #12797 of 13194 Old 11-27-2014, 01:56 PM
cooknl's Avatar
Quoted: 23 Post(s)
Liked: 25
P5browne, i think what you mean(just to clarify for the other readers) that the fan should be sucking the air out, NOT blowing into the tv.
The reason for it having to suck the air through is so that it pulls cold air from the bottom part of the TV.
Then its doing the same as the convection cooling as designed by Samsung, only then moves more air and therefore is more efficient at cooling.
Rob
cooknl is offline
post #12798 of 13194 Old 11-27-2014, 02:08 PM
HLdan's Avatar
Quoted: 497 Post(s)
Liked: 228
I'm going to say I agree? Because it sounds good enough.
HLdan is offline
post #12799 of 13194 Old 11-28-2014, 08:13 AM
Halimali's Avatar
Liked: 50
I apprecitae your help. Thank you
As of June 2013:
2,712 Bluray movies
1,593 DVD movies
Halimali is offline
post #12800 of 13194 Old 11-28-2014, 08:17 AM
Halimali's Avatar
Liked: 50
Rob
Hey Rob
Thanks a lot for sharing the pics and info.
Are you using a USB Hub? How do you power it up? Using the TV or a separate power supply?
I know I can power two fans using the TV's two USBs. How can I add more?
Another question: Do all the fans need to blow air out of the set?
As of June 2013:
2,712 Bluray movies
1,593 DVD movies
Halimali is offline
post #12801 of 13194 Old 11-28-2014, 09:16 AM
WantsNWarrants's Avatar
Quoted: 84 Post(s)
Liked: 50
Hali,
You need just one fan because you've moved the set to a stand from the cabinet.
Use p5browne's setup.
I'm the guy with 8 fans (see my signature) and I can definitely tell you that one is enough!
Yes, all out. Look at the intakes at the bottom under the main board to see why one fan in the hot spot is critical for restrited airflow environments.
WantsNWarrants is offline
post #12802 of 13194 Old 11-28-2014, 09:47 AM
cooknl's Avatar
Quoted: 23 Post(s)
Liked: 25
Hey Rob
Hi Halimali, yep sorry I forgot to mention it but YES i am using a 4 plug USB hub. the USB plug from the hub goes to the bottom USB port on the TV the one that states 1 amp (HDD 1.0A). And all 4 of these fans are plugged in to the HUB.
An IMO by using 4 fans you ave aprox. the similar temparature across the width of the panel less hot spot and I think that is better for the overall performance of the circuit boards involved.
Also I read somewhere once (dont remmember where, was in the beginning of this thread i believe) that statistcs show that dropping electronics circuits temperature by 10degree C will double the life of the afected components.
Anyway hope this helps .
Rob
EDIT: I forgot to mention that ALL fans should SUCK air OUT OF THE SET through the top air vents, as pictured in my previous post.
cooknl is offline
post #12803 of 13194 Old 11-28-2014, 12:14 PM
Jimdish255's Avatar
My 51F8500 is up and running for a couple of days now and I still haven't fully explored all it's options. Right now I'm mostly concerned with basic viewing of Satellite and Blu-Ray material so here's my question. Do I need to run a firmware update? And have any of the updates affected PQ in a positive of negative way? Obviously it would always seem to be a good idea to go with the newest firmware but I just want to be sure. My current version is 1202.
Jimdish255 is offline
post #12804 of 13194 Old 11-28-2014, 11:49 PM
Quoted: 84 Post(s)
Liked: 50
If your firmware is at least version 1116 then NO, you do not need to upgrade. All FW upgrades post 1116 are related to apps, not PQ.
Therefore, 1202 is fine.
post #12805 of 13194 Old 11-29-2014, 11:01 PM
Daud's Avatar
Hello,
I scored a Best Buy display model in the 64" size but with out the original stand. The hardware as ordered from Samsung costs $220 plus shipping. Due to my setting, I have to place the display on a cabinet. Tried to search for an universal stand, but they are ugly and for smaller sizes. Maybe somebody here has a suggestion or has the stand in the garage ?
Daud is offline
post #12806 of 13194 Old 11-30-2014, 06:58 AM
JRWalker's Avatar
Quoted: 41 Post(s)
Liked: 54
If you bought your F8500 with an American Express Card it may be covered by the FREE American Express Extended Warranty. Info here: https://www.americanexpress.com/us/content/card-benefits/extended-warranty.html
Summary from above: “Why is it that as soon as a manufacturer's warranty runs out, something always seems to happen? Use your Card for your eligible purchases and you can have warranty protection for longer.
Use Your Eligible Card - Extended Warranty can provide up to one extra year added to the original U.S. manufacturer’swarranty. Applies to warranties of 5 years or less when the eligible purchase is charged to the Card.
Coverage - You will only be covered up to the actual amount charged to your Card for the item up to a maximum of $10,000; not to exceed $50,000 per Card Member account per calendar year. Please read important exclusions and restrictions.”
If you buy extended warranty on an item then I believe the AMEX Extended Warranty starts when your purchased warranty ends. You should check on that.
Lost or stolen purchases are also insured. Claims can be made over the phone by calling AMEX customer support number on the back of your card.
If you have questions you should visit link above first for more information. AMEX advertised this feature a lot in the past but have not seen it mentioned in a while. I have only made one claim, when my son’s new digital camera and accessories were stolen from his university room. Called and got full credit and he bought another camera.
JRWalker is offline
post #12807 of 13194 Old 11-30-2014, 01:12 PM
Quoted: 84 Post(s)
Liked: 50
Since there are lots of people jumping in on the current price reductions, were I you I'd haunt Ebay. Stands there, when available, normally run about $125.
You might want to post to the owners thread also:
Official Samsung PNxxF8500 Owners Thread (No Street Price Talk)
post #12808 of 13194 Old 11-30-2014, 02:20 PM
Quoted: 12 Post(s)
Liked: 3
I was home for Thanksgiving and had to watch the Sony XBR LCD....it was making me sick. Color was just awful. The F8500 PQ is simply stunning.
Video: Samsung PN50C550 & PN64F8500
Audio: Infinity Kappa 8.1's powered by a Yamaha HTR-5590
wfarrell4 is offline
post #12809 of 13194 Old 11-30-2014, 03:38 PM
AMartin56's Avatar
Liked: 1130
First world problems.
Geekpryde likes this.
post #12810 of 13194 Old 11-30-2014, 04:04 PM
Liked: 0
Fuzzy
Hello all,
I always wanted to participate here, but unfortunate that it had to be in this circumstance.
I upgraded to the 60" F8500 from a 42" Samsung plasma this year and I never expected the change to be this drastic. I'm having some issues with the picture. I've gotten use to the new panel, but there is a certain amount of fuzzy noise (coloured sparkles across brighter sections) that has been bothering me. All I want to know is, if it's exclusive to me or if it's normal.
-- Unable to post images or links yet --
I'll try my best to describe; there is a noticeable amount of grain, primarily against brighter images. It's a fuzzy static which has floating colours even if the image is pure white. I initially thought it was the TV signal, but it's evident even with blu-rays.
Sorting this out means so much to me. Thank you in advance.
romus is offline
Samsung Pn51f8500 51 Inch 3d Smart Plasma Hdtv
